data saved different to data read
Hi, I want to save settings in the memory. In my case, the softdevice is enabled, there is no ble advertising. I use pstorage functions. Problem: I stored 0x12, 0x23, 0x45,0x67. But I read 0xFF, 0xFF, 0xFF, 0xFF.
Initialization
  void init_app_data_flash_manager(void)
		pstorage_module_param_t param;
		uint32_t retval1;
		uint32_t retval;
		// Initialize persistent storage module.
		retval1 = pstorage_init();
		APP_ERROR_CHECK(retval1);
		param.block_size = 0x10;
		param.block_count = 8;
		param.cb = app_data_flash_manager_cb_handler;
		retval = pstorage_register(&param, &app_data_flash_manager_handle);
		if (retval == NRF_SUCCESS)
			 UART_TXT("successful register..\r\n\0");
			// Failed to register, take corrective action.
			simple_uart_put((uint8_t)retval1);
			simple_uart_put((uint8_t)retval);
Data saving
  void save_settings_to_flash()
	pstorage_handle_t block_handle;
	uint32_t retval1;
	uint32_t retval;
	retval1 = pstorage_block_identifier_get(&app_data_flash_manager_handle, 4, &block_handle);
 	dataToStore[0] = 0x12;
	dataToStore[1] = 0x23;
	dataToStore[2] = 0x45;
	dataToStore[3] = 0x67;
	retval = pstorage_update(&block_handle, dataToStore, 4, 0);
	// Store successfully requested. Wait for operation result.
		UART_TXT("stored\n");
	// Failed to request store, take corrective action.
data reading
    void read_settings_from_flash(void)
	uint32_t retval;
	uint8_t p_encode_data_read[4];
	retval = pstorage_block_identifier_get(&app_data_flash_manager_handle, 4, &block_handle);
  	retval = pstorage_load(p_encode_data_read, &block_handle, 4, 0);
		UART_TXT("Loaded\n");
		simple_uart_put(0xAA);
		simple_uart_put(p_encode_data_read[0]);
		simple_uart_put(p_encode_data_read[1]);
		simple_uart_put(p_encode_data_read[2]);
		simple_uart_put(p_encode_data_read[3]);
		simple_uart_put(0xBB);
	// Load successful. Consume data.
		UART_TXT("Loading failed");
	// Failed to load, take corrective action.
static pstorage_handle_t 					app_data_flash_manager_handle;
static uint8_t dataToStore[4] __attribute__((aligned(4)));
  • The 0xFF values are typically erased NVRAM. Best guess without seeing how your actually invoke your two functions is that you are calling your readings_from_flash function before the pstorage_update operation has completed. Are you waiting for the NRF_EVT_FLASH_OPERATION_SUCCESS event before calling your readings_from_flash function?
  • Firstly, I called the functions read_setting_from_flash() just after save_settings_to_flash(). It gave me the previous result. Then I tried with a callback function like below:
    static void app_data_flash_manager_cb_handler(pstorage_handle_t * handle, uint8_t op_code, uint32_t result, uint8_t * p_data, uint32_t data_len)
    	switch(op_code)
    		case PSTORAGE_STORE_OP_CODE:
    			if (result == NRF_SUCCESS)
    				 UART_TXT("Storage successful..\r\n\0");
    			// Store operation successful.
    				 UART_TXT("Storage failed..\r\n\0");
    			// Store operation failed.
    		case PSTORAGE_ERROR_OP_CODE:
    			// Operation successful.
    			// Error! Operation failed.
    		case PSTORAGE_LOAD_OP_CODE:
    			// Source memory can now be reused or freed.
    		case PSTORAGE_UPDATE_OP_CODE:
    			// Update operation successful.
    			// Update operation failed.
    		case PSTORAGE_CLEAR_OP_CODE:
    				 UART_TXT("Storage cleared..\r\n\0");
    				 save_settings_to_flash();
    				 UART_TXT("j'ai pas reussi à effacer..\r\n\0");
    But the function is never called....
  • Hi, if you are calling the read immediately after the write, the 0xFF return is to be expected. The update operation takes time, but the pstorage update function is non-blocking. So, the update was not complete when you read the memory back. This thread shows one solution to the problem Wait for event.
    It isn't elegant but it is effective. I do not know why the callback wasn't called, its hard to tell without seeing all of the code invoking these functions.
  • Thank you for your help! I did not work, because I forgot this part:
    static void sys_evt_dispatch(uint32_t sys_evt)
        pstorage_sys_event_handler(sys_evt);
    void body_ble_stack_init(void) {
    	uint32_t err_code;
    	// Initialize the SoftDevice handler module.
    	SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM , false);
    	err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
  • where is declaration of "NRF_CLOCK_LFCLKSRC_XTAL_20_PPM"?
