SAADC configure V(p)
I am using nrf52840 and I have successfully uploaded the SAADC example. I do not understand why is V(p) = VDD? How can I configure Vp to be equal to voltage that I input to pin AIN0 (P0.02)? The simple example code is in the description. I am looking forward to someone answering me. Best regards.
#include <nrf.h>
  volatile int16_t result = 0;
  volatile float precise_result = 0;
  // Start HFCLK from crystal oscillator, this will give the SAADC higher accuracy
  while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
  // Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/6 gain.
  NRF_SAADC->CH[0].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6    << SAADC_CH_CONFIG_GAIN_Pos) |
                            (SAADC_CH_CONFIG_MODE_SE         << SAADC_CH_CONFIG_MODE_Pos) |
                            (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
                            (SAADC_CH_CONFIG_RESN_Bypass     << SAADC_CH_CONFIG_RESN_Pos) |
                            (SAADC_CH_CONFIG_RESP_Bypass     << SAADC_CH_CONFIG_RESP_Pos) |
                            (SAADC_CH_CONFIG_TACQ_3us        << SAADC_CH_CONFIG_TACQ_Pos);
  // Configure the SAADC channel with VDD as positive input, no negative input(single ended).
  NRF_SAADC->CH[0].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos;
  NRF_SAADC->CH[0].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
  // Configure the SAADC resolution.
  NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos;
  // Configure result to be put in RAM at the location of "result" variable.
  NRF_SAADC->RESULT.MAXCNT = 1;
  NRF_SAADC->RESULT.PTR = (uint32_t)&result;
  // No automatic sampling, will trigger with TASKS_SAMPLE.
  NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
  // Enable SAADC (would capture analog pins if they were used in CH[0].PSELP)
  NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
  // Calibrate the SAADC (only needs to be done once in a while)
  NRF_SAADC->TASKS_CALIBRATEOFFSET = 1;
  while (NRF_SAADC->EVENTS_CALIBRATEDONE == 0);
  NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
  while (NRF_SAADC->STATUS == (SAADC_STATUS_STATUS_Busy <<SAADC_STATUS_STATUS_Pos));
  // Start the SAADC and wait for the started event.
  NRF_SAADC->TASKS_START = 1;
  while (NRF_SAADC->EVENTS_STARTED == 0);
  NRF_SAADC->EVENTS_STARTED = 0;
  // Do a SAADC sample, will put the result in the configured RAM buffer.
  NRF_SAADC->TASKS_SAMPLE = 1;
  while (NRF_SAADC->EVENTS_END == 0);
  NRF_SAADC->EVENTS_END = 0;
  // Convert the result to voltage
  // Result = [V(p) - V(n)] * GAIN/REFERENCE * 2^(RESOLUTION)
  // Result = (VDD - 0) * ((1/6) / 0.6) * 2^14
  // VDD = Result / 4551.1
  precise_result = (float)result / 4551.1f;
  precise_result; // to get rid of set but not used warning
  // Stop the SAADC, since it's not used anymore.
  NRF_SAADC->TASKS_STOP = 1;
  while (NRF_SAADC->EVENTS_STOPPED == 0);
  NRF_SAADC->EVENTS_STOPPED = 0;
  while (1)
    __WFE();
