First and second transmission fails in nRF9160
hardware: nRF9160 DK 0.8.2
firmware: 0.7.0-29.alpha
I want to send data every a few seconds through MQTT. It fails in the first and second Tx after MQTT client initiation, and succeeds after that. It releases error = -57.
Why does it fails in the first and second Tx after initiation?
I tested the code below. I added four lines to mqtt_simple.
mqtt_simple: https://github.com/NordicPlayground/fw-nrfconnect-nrf/blob/master/samples/nrf9160/mqtt_simple/src/main.c
<main.c>
void main(void)
	int err;
	printk("The MQTT simple sample started\n");
	modem_configure();
	client_init(&client);
	err = mqtt_connect(&client);
	if (err != 0) {
		printk("ERROR: mqtt_connect %d\n", err);
		return;
	err = fds_init(&client);
	if (err != 0) {
		printk("ERROR: fds_init %d\n", err);
		return;
        k_sleep(20*1000); // ADD HERE
        err = data_publish(&client, MQTT_QOS_0_AT_MOST_ONCE, "a", strlen("a"));  // ADD HERE
        printk("err=%d\n", err); // ADD HERE
        printk("Send reset message\n"); // ADD HERE
	while (1) {
and the result is here. err=-57
***** Booting Zephyr OS v1.14.99-ncs1 *****
LTE Link Connecting ...
LTE Link Connected!
IPv4 Address found 0x????????
Publishing: a
to topic: myPubTopic len: 10
err=-57
Send reset message
mqtt_input start
[mqtt_evt_handler:168] MQTT client connected!
Subscribing to: mySubTopic len 10
mqtt_input end
mqtt_input start
[mqtt_evt_handler:218] SUBACK packet id: 1234
mqtt_input end
Any advice?
  • Hi.
    Looking in the SDK from when you call data_publish(&client, MQTT_QOS_0_AT_MOST_ONCE, "a", strlen("a")); I end up in the function verify_tx_state(client):
    (in mqtt.c)
    This returns -ENOTCONN which is -57.
    So it seems that this is the error. What values and so on does the client struct have?
    Andreas
  • Thank you for your reply!
    It's hard to check all the params of mqtt_client as it has a lot of params.....
    I compared my code with the lates mqtt_simple code
    https://github.com/NordicPlayground/fw-nrfconnect-nrf/tree/master/samples/nrf9160/mqtt_simple
    There are two differences.
    1. Line 264 inet_ntop is added in the latest code.
    2. I add password and username in my code. Also I change MQTT version to 3.1.0
    <main.c>
    #define MQTT_PASSWORD "password"
    #define MQTT_USERNAME "username"
    /**@brief Initialize the MQTT client structure
    static void client_init(struct mqtt_client *client)
    	mqtt_client_init(client);
    	broker_init();
            /* Add from here */
            static struct mqtt_utf8 password;
    	static struct mqtt_utf8 user_name;
    	password.utf8 = (u8_t *)MQTT_PASSWORD;
    	password.size = strlen(MQTT_PASSWORD);
    	user_name.utf8 = (u8_t *)MQTT_USERNAME;
    	user_name.size = strlen(MQTT_USERNAME);
            /* to here */
    	/* MQTT client configuration */
    	client->broker = &broker;
    	client->evt_cb = mqtt_evt_handler;
    	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
    	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
    	client->password = &password; // Add here
    	client->user_name = &user_name; // Add here
    	client->protocol_version = MQTT_VERSION_3_1_0; // originally MQTT_VERSION_3_1_1
    	/* MQTT buffers configuration */
    	client->rx_buf = rx_buffer;
    	client->rx_buf_size = sizeof(rx_buffer);
    	client->tx_buf = tx_buffer;
    	client->tx_buf_size = sizeof(tx_buffer);
    	/* MQTT transport configuration */
    	client->transport.type = MQTT_TRANSPORT_NON_SECURE;
    Do you have any advice?
  • I added data_publish function to the original mqtt_simple program tested it. It doesn't work.
    <main.c>
    	broker_init();
    	client->password = NULL;
    	client->user_name = NULL;
    	client->protocol_version = MQTT_VERSION_3_1_1;
    void main(void)
    	int err;
    	modem_configure();
    	if (err != 0) {
    		return;
    	if (err != 0) {
    		return;
            err = data_publish(&client, MQTT_QOS_0_AT_MOST_ONCE, "a", strlen("a")); // TODO ADD HERE. Does not work
    	while (1) {
    		err = poll(&fds, 1, K_SECONDS(CONFIG_MQTT_KEEPALIVE));
    		if (err < 0) {
    			printk("ERROR: poll %d\n", errno);
    		err = mqtt_live(&client);
    		if (err != 0) {
    			printk("ERROR: mqtt_live %d\n", err);
    		if ((fds.revents & POLLIN) == POLLIN) {
    			err = mqtt_input(&client);
    			if (err != 0) {
    				printk("ERROR: mqtt_input %d\n", err);
    		if ((fds.revents & POLLERR) == POLLERR) {
    			printk("POLLERR\n");
    		if ((fds.revents & POLLNVAL) == POLLNVAL) {
    			printk("POLLNVAL\n");
    	printk("Disconnecting MQTT client...\n");
    	err = mqtt_disconnect(&client);
    	if (err) {
    		printk("Could not disconnect MQTT client. Error: %d\n", err);
    <prj.conf>
    # Appliaction
    #CONFIG_MQTT_PUB_TOPIC="/my/publish/topic"
    #CONFIG_MQTT_SUB_TOPIC="/my/subscribe/topic"
    #CONFIG_MQTT_CLIENT_ID="my-client-id"
    #CONFIG_MQTT_BROKER_HOSTNAME="iot.eclipse.org"
    #CONFIG_MQTT_BROKER_PORT=1883
    LTE Link Connected!
    IPv4 Address found ������������UUUU
    Publishing: a
    to topic: my/publish/topic len: 16
    err=-57
    Send reset message
    mqtt_input start
    [mqtt_evt_handler:166] MQTT client connected!
    Subscribing to: my/subscribe/topic len 18
    mqtt_input end
    mqtt_input start
    [mqtt_evt_handler:216] SUBACK packet id: 1234
    mqtt_input end
    mqtt_input start
    mqtt_input end
    So this issue should not be related to a broker.
    I'm confused....
  • Hi again.
    Can you check that you have the latest modem firmware installed?
    Can you also check that you are in the v0.4.0 branch?
    Andreas
  • same here.
    $ git branch
    * (HEAD detached at v0.4.0)
      master
    Can you try the same program above with your nRF9160 DK board?
