Problem with BLE
// Idle state
void idle_state() {
  bsp_board_led_on(0);
  bsp_board_led_off(1);
  bsp_board_led_off(2);
  bsp_board_led_off(3);
  flag = 0;
  stop = 0;
  nrf_drv_gpiote_in_event_disable(QDE_IN);
  nrf_drv_gpiote_in_event_enable(button_IN, true);
  nrf_gpio_pin_set(idle_front_end);
  __WFI();
  __SEV();
  __WFI();
//Initializing the timer module.
static void timers_init(void) {
static void gap_params_init(void) {
  uint32_t err_code;
  ble_gap_conn_params_t gap_conn_params;
      (const uint8_t *)DEVICE_NAME,
      strlen(DEVICE_NAME));
  gap_conn_params.slave_latency = SLAVE_LATENCY;
  gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
static void nrf_qwr_error_handler(uint32_t nrf_error) {
  APP_ERROR_HANDLER(nrf_error);
static void services_init(void) {
  uint32_t err_code;
  ble_nus_init_t nus_init;
  // Initialize NUS.
  //nus_init.data_handler = nus_data_handler;
  nus_init.data_handler = tx_ready_handler;
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
  uint32_t err_code;
  if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
static void conn_params_error_handler(uint32_t nrf_error) {
static void conn_params_init(void) {
  uint32_t err_code;
  cp_init.p_conn_params = NULL;
  cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
  cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
  cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
  cp_init.disconnect_on_fail = false;
  cp_init.evt_handler = on_conn_params_evt;
  cp_init.error_handler = conn_params_error_handler;
static void sleep_mode_enter(void) {
  // Prepare wakeup buttons.
static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
  uint32_t err_code;
  switch (ble_adv_evt) {
  case BLE_ADV_EVT_FAST:
    //     APP_ERROR_CHECK(err_code);
  case BLE_ADV_EVT_IDLE:
    sleep_mode_enter();
static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
  uint32_t err_code;
  switch (p_ble_evt->header.evt_id) {
  case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connected");
    NRF_LOG_INFO("Disconnected");
  case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
    ble_gap_phys_t const phys =
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
  } break;
    // Pairing not supported
  case BLE_GATTC_EVT_TIMEOUT:
  case BLE_GATTS_EVT_TIMEOUT:
    // No implementation needed.
static void ble_stack_init(void) {
  ret_code_t err_code;
  uint32_t ram_start = 0;
  // Enable BLE stack.
//Function for handling events from the GATT library.
void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
  if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)) {
    m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
    NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
  NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
      p_gatt->att_mtu_desired_central,
      p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void) {
  err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
  err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
static void advertising_init(void) {
  uint32_t err_code;
  ble_advertising_init_t init;
  init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
  init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
  init.srdata.uuids_complete.p_uuids = m_adv_uuids;
  init.config.ble_adv_fast_enabled = true;
  init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void log_init(void) {
static void advertising_start(void) {
  // Initialize BLE connection
  log_init();
  timers_init();
  ble_stack_init();
  gap_params_init();
  gatt_init();
  services_init();
  advertising_init();
  conn_params_init();
  stop = 1; // idle condition
  for (;;)
    if (stop == 1)
    idle_state();
    advertising_start();
    bsp_board_led_off(0);
  bsp_board_led_on(1); // check if board works
  meas_state();
return (0);
I have a problem I'm using nrf52840 DK. The task i want perform is start from idle state, wait for a button signal and the go out from idle, start with a loop where the code performs some measurements and send data via BLE (the measurement and the data send work well)  and then return in idle when i press a button. The problem is that when I'm in idle and in __WFI, arrives some interrupt that moves me out. The only way i found to avoid this is write before __ WFI:  nrf_sdh_disable_request();. The problem is that with this code line then the BLE doesn't work even if after idle i write nrf_sdh_enable_request();.
Any solution to remain in idle also in other way ?
