nRF9160 DK SPI Example causing hard fault.
I am trying to get a simple spi setup working. Through the dev zone I found a link to this https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/spi repository.
I was successful in getting the uart example from the same repository to build and run on my nRF9160 DK. However when I attempt to run the spi example it results in the ***** HARD FAULT **** that can be seen in the serial output below. I have attached my nrf9160_pca10090.overlay prj.conf and main.c files
Serial output
***** Booting Zephyr OS v1.14.99-ncs1 *****
Flash region..Domain..Permissions
00 0x00000 0x08000 .Secure..rwxl
01 0x08000 0x10000 .Non-Secure.rwxl
02 0x10000 0x18000 .Non-Secure.rwxl
03 0x18000 0x20000 .Non-Secure.rwxl
04 0x20000 0x28000 .Non-Secure.rwxl
05 0x28000 0x30000 .Non-Secure.rwxl
06 0x30000 0x38000 .Non-Secure.rwxl
07 0x38000 0x40000 .Non-Secure.rwxl
08 0x40000 0x48000 .Non-Secure.rwxl
09 0x48000 0x50000 .Non-Secure.rwxl
10 0x50000 0x58000 .Non-Secure.rwxl
11 0x58000 0x60000 .Non-Secure.rwxl
12 0x60000 0x68000 .Non-Secure.rwxl
13 0x68000 0x70000 .Non-Secure.rwxl
14 0x70000 0x78000 .Non-Secure.rwxl
15 0x78000 0x80000 .Non-Secure.rwxl
16 0x80000 0x88000 .Non-Secure.rwxl
17 0x88000 0x90000 .Non-Secure.rwxl
18 0x90000 0x98000 .Non-Secure.rwxl
19 0x98000 0xa0000 .Non-Secure.rwxl
20 0xa0000 0xa8000 .Non-Secure.rwxl
21 0xa8000 0xb0000 .Non-Secure.rwxl
22 0xb0000 0xb8000 .Non-Secure.rwxl
23 0xb8000 0xc0000 .Non-Secure.rwxl
24 0xc0000 0xc8000 .Non-Secure.rwxl
25 0xc8000 0xd0000 .Non-Secure.rwxl
26 0xd0000 0xd8000 .Non-Secure.rwxl
27 0xd8000 0xe0000 .Non-Secure.rwxl
28 0xe0000 0xe8000 .Non-Secure.rwxl
29 0xe8000 0xf0000 .Non-Secure.rwxl
30 0xf0000 0xf8000 .Non-Secure.rwxl
31 0xf8000 0x100000 .Non-Secure.rwxl
SRAM region..Domain..Permissions
00 0x00000 0x02000.Secure..rwxl
01 0x02000 0x04000.Secure..rwxl
02 0x04000 0x06000.Secure..rwxl
03 0x06000 0x08000.Secure..rwxl
04 0x08000 0x0a000.Secure..rwxl
05 0x0a000 0x0c000.Secure..rwxl
06 0x0c000 0x0e000.Secure..rwxl
07 0x0e000 0x10000.Secure..rwxl
08 0x10000 0x12000.Non-Secure.rwxl
09 0x12000 0x14000.Non-Secure.rwxl
10 0x14000 0x16000.Non-Secure.rwxl
11 0x16000 0x18000.Non-Secure.rwxl
12 0x18000 0x1a000.Non-Secure.rwxl
13 0x1a000 0x1c000.Non-Secure.rwxl
14 0x1c000 0x1e000.Non-Secure.rwxl
15 0x1e000 0x20000.Non-Secure.rwxl
16 0x20000 0x22000.Non-Secure.rwxl
17 0x22000 0x24000.Non-Secure.rwxl
18 0x24000 0x26000.Non-Secure.rwxl
19 0x26000 0x28000.Non-Secure.rwxl
20 0x28000 0x2a000.Non-Secure.rwxl
21 0x2a000 0x2c000.Non-Secure.rwxl
22 0x2c000 0x2e000.Non-Secure.rwxl
23 0x2e000 0x30000.Non-Secure.rwxl
24 0x30000 0x32000.Non-Secure.rwxl
25 0x32000 0x34000.Non-Secure.rwxl
26 0x34000 0x36000.Non-Secure.rwxl
27 0x36000 0x38000.Non-Secure.rwxl
28 0x38000 0x3a000.Non-Secure.rwxl
29 0x3a000 0x3c000.Non-Secure.rwxl
30 0x3c000 0x3e000.Non-Secure.rwxl
31 0x3e000 0x40000.Non-Secure.rwxl
Peripheral..Domain..Status
00 NRF_P0..Non-Secure.OK
01 NRF_CLOCK..Non-Secure.OK
02 NRF_RTC1..Non-Secure.OK
03 NRF_NVMC..Non-Secure.OK
04 NRF_UARTE1..Non-Secure.OK
05 NRF_UARTE2..Secure..SKIP
06 NRF_IPC..Non-Secure.OK
07 NRF_VMC..Non-Secure.OK
08 NRF_FPU..Non-Secure.OK
09 NRF_EGU1..Non-Secure.OK
10 NRF_EGU2..Non-Secure.OK
11 NRF_TWIM2..Non-Secure.OK
12 NRF_SPIM3..Non-Secure.OK
13 NRF_TIMER0..Non-Secure.OK
14 NRF_TIMER1..Non-Secure.OK
15 NRF_TIMER2..Non-Secure.OK
16 NRF_SAADC..Non-Secure.OK
17 NRF_GPIOTE1..Non-Secure.OK
SPM: NS image at 0x8000
SPM: NS MSP at 0x20022258
SPM: NS reset vector at 0xa191
SPM: prepare to jump to Non-Secure image.
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
***** Hardware exception *****
Current thread ID = 0x20020178
Faulting instruction address = 0x0
Fatal fault in ISR! Spinning...
&spi3 {
	status = "ok";
	sck-pin = <9>;
	mosi-pin = <8>;
	miso-pin = <7>;
	ss-pin = <10>;
	spi-max-frequency = <4000000>;
prj.conf
CONFIG_SERIAL=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_UART_0_NRF_UARTE=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=n
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# BSD library
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
# network
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_NETWORKING=y
CONFIG_NET_BUF_USER_DATA_SIZE=1
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_RAW_MODE=y
CONFIG_HEAP_MEM_POOL_SIZE=1024
# SPI
CONFIG_SPI=y
CONFIG_SPI_3=y
CONFIG_SPI_3_NRF_SPIM=y
CONFIG_SPI_3=y
CONFIG_SPI_NRFX=y
main.c
* Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr.h>
#include <misc/printk.h>
#include <spi.h>
static const struct spi_config spi_cfg = {
	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB |
		     SPI_MODE_CPOL | SPI_MODE_CPHA,
	.frequency = 4000000,
	.slave = 0,
struct device * spi_dev;
static void spi_init(void)
	const char* const spiName = "SPI_3";
	spi_dev = device_get_binding(spiName);
	if (spi_dev == NULL) {
		printk("Could not get %s device\n", spiName);
		return;
void spi_test_send(void)
	int err;
	static u8_t tx_buffer[1];
	static u8_t rx_buffer[1];
	const struct spi_buf tx_buf = {
		.buf = tx_buffer,
		.len = sizeof(tx_buffer)
	const struct spi_buf_set tx = {
		.buffers = &tx_buf,
		.count = 1
	struct spi_buf rx_buf = {
		.buf = rx_buffer,
		.len = sizeof(rx_buffer),
	const struct spi_buf_set rx = {
		.buffers = &rx_buf,
		.count = 1
	err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
	if (err) {
		printk("SPI error: %d\n", err);
	} else {
		/* Connect MISO to MOSI for loopback */
		printk("TX sent: %x\n", tx_buffer[0]);
		printk("RX recv: %x\n", rx_buffer[0]);
		tx_buffer[0]++;
void main(void)
	printk("SPIM Example\n");
	spi_init();
	while (1) {
		spi_test_send();
		k_sleep(1000);
For building the solution I am using SEGGER V4.16 on Windows 10. I use Build Solution under the Build menu. The build succeeds. Then I Connect J-link under the Target menu and finally, I upload the merged.hex file using the Download Intel hex file... command under the Download submenu of the Target menu. The upload is successful.
1. Is there something simple I am overlooking in the example that is causing the hard fault?
2. Is there a different example to test the spi with? My ultimate goal of being able to connect an adxl372 accelerometer.
