Hello
I have a setup with 3 nrf6310 dev kit and with a nrf24LE1 module on each of them.
1 acts as a transmitter and the other 2 act as a receivers. What I specifically want is for the transmitter to send the packed on 2 different channels as each receiver is configured with a different channel frequency.
Note that I don't want the multiciever setup. The requirement is to have 2 different channels.
So my questions are:
1. Is the above possible?
2. If it is then what needs to happen at the time of transmit such the packets are trasnmitted on the respective channels?
3. What Data rate, ack retry and other parameters I should consider?
I have spent a lot of time on the datasheet and tried a few combinations. Also checked the forums but haven't found anything that specifically addresses the above.
Your help would be appreciated.
reagrds
Ankit
