Invalid Object error with OTA DFU using both example and self generated packages.
I inherited an active project with regrettably little support from the previous developer.
I have been trying to download a copy of the application firmware that I generated to get to a basic starting point.  I have followed the many slightly varying nrfutil commands to generate a DFU package.  I do not have access to the private key used to originally setup the device, so I have generated my own new priv.pem file and placed the resulting DFU_Pulic_key.c file into the proper project folder.
I consistently get the error "Invalid object" when trying to download.  Using nrfutil pkg display, I can see that I have the same version numbers and same file size as the original source DFU package from the previous developer that I am trying to replicate.   I have even tried using nrfutil with the option --debug-mode to see if that would work: it doesn't.
So, I next tried to use example DFU packages from Nordic.  Specifically an unmodified version of DFU_TEST_APP_HRM_S132.zip  This too returns the error "Invalid Object".
Next I tried to download the bootlloader and softdevice from the same example folder: DFU_TEST_BOOTLOADER_S132.zip and DFU_TEST_SOFTDEVICE_BOOTLOADER_S132.zip These return a slightly different error - "DFU FILE ERROR"
So what is going on that even straight up Nordic examples are failing?
Note that when I try to download the original DFU package from the previous developer, that still works so the hardware and OTA DFU is still functional.
I am using Keil MDK-ARM v5.27.1.0 to compile; nrfutil v5.2.0; and Android nRF Toolbox v2.7.2
