Adding NUS to my central code causes fatal error
Details: SDK v15.2.0 using ble_app_hrs_c example. Windows 8.1, uploading to nRF52 DK.
This screenshot shows the device operating in working (green) and broken states (red).
The difference between the working/broken code is when I un-comment line 1036
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE Heart Rate Collector application main file.
 * This file contains the source code for a sample heart rate collector.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdm.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_db_discovery.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "app_util.h"
#include "app_error.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "ble_hrs_c.h"
#include "ble_bas_c.h"
#include "ble_nus_c.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_ble_scan.h"
#define APP_BLE_CONN_CFG_TAG        1                                   /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO       3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_SOC_OBSERVER_PRIO       1                                   /**< Applications' SoC observer priority. You shouldn't need to modify this value. */
#define LESC_DEBUG_MODE             0                                   /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND              1                                   /**< Perform bonding. */
#define SEC_PARAM_MITM              0                                   /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC              1                                   /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS          0                                   /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES   BLE_GAP_IO_CAPS_NONE                /**< No I/O capabilities. */
#define SEC_PARAM_OOB               0                                   /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE      7                                   /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE      16                                  /**< Maximum encryption key size in octets. */
#define SCAN_DURATION_WITELIST      3000                                /**< Duration of the scanning in units of 10 milliseconds. */
#define TARGET_UUID                 BLE_UUID_HEART_RATE_SERVICE         /**< Target device uuid that application is looking for. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
/**@brief Macro to unpack 16bit unsigned UUID from octet stream. */
#define UUID16_EXTRACT(DST, SRC) \
    do                           \
        (*(DST))   = (SRC)[1];   \
        (*(DST)) <<= 8;          \
        (*(DST))  |= (SRC)[0];   \
    } while (0)
BLE_NUS_C_DEF(m_ble_nus_c);
BLE_HRS_C_DEF(m_hrs_c);                                             /**< Structure used to identify the heart rate client module. */
BLE_BAS_C_DEF(m_bas_c);                                             /**< Structure used to identify the Battery Service client module. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                    /**< DB discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                           /**< Scanning module instance. */
static uint16_t m_conn_handle;                                      /**< Current connection handle. */
static bool     m_whitelist_disabled;                               /**< True if whitelist has been temporarily disabled. */
static bool     m_memory_access_in_progress;                        /**< Flag to keep track of ongoing operations on persistent memory. */
/**< Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_param =
    .active        = 1,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
    .timeout       = SCAN_DURATION_WITELIST,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
/**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
 *  if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = "";      /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
static bool is_connect_per_addr = false;            /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
    /* Possible values for addr_type:
       BLE_GAP_ADDR_TYPE_PUBLIC,
       BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
       BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
       BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
    .addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
    .addr      = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}
static void scan_start(void);
/**@brief Function for asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
    ble_bas_on_db_disc_evt(&m_bas_c, p_evt);
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    // ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    // for (uint32_t i = 0; i < data_len; i++)
    //     do
    //         ret_val = app_uart_put(p_data[i]);
    //         if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
    //             NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
    //             APP_ERROR_CHECK(ret_val);
    //     } while (ret_val == NRF_ERROR_BUSY);
    // if (p_data[data_len-1] == '\r')
    //     while (app_uart_put('\n') == NRF_ERROR_BUSY);
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    ret_code_t err_code;
    NRF_LOG_INFO("ble nus event");
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            // Bonds are deleted. Start scanning.
            scan_start();
 * @brief Function for shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            // Discover peer's services.
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
            if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                scan_start();
        } break;
            NRF_LOG_INFO("Disconnected, reason 0x%x.",
                         p_gap_evt->params.disconnected.reason);
                scan_start();
        } break;
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
         case BLE_GAP_EVT_AUTH_STATUS:
             NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
/**@brief SoftDevice SoC event handler.
 * @param[in]   evt_id      SoC event.
 * @param[in]   p_context   Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
    switch (evt_id)
        case NRF_EVT_FLASH_OPERATION_SUCCESS:
            /* fall through */
        case NRF_EVT_FLASH_OPERATION_ERROR:
            if (m_memory_access_in_progress)
                m_memory_access_in_progress = false;
                scan_start();
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
    // Register handlers for BLE and SoC events.
    NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/** @brief Clear bonding information from persistent storage
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for disabling the use of whitelist for scanning.
static void whitelist_disable(void)
    if (!m_whitelist_disabled)
        NRF_LOG_INFO("Whitelist temporarily disabled.");
        m_whitelist_disabled = true;
        nrf_ble_scan_stop();
        scan_start();
 * @param[in]   event   Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
            whitelist_disable();
/**@brief Heart Rate Collector Handler.
static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
    switch (p_hrs_c_evt->evt_type)
        case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_DEBUG("Heart rate service discovered.");
            err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                p_hrs_c_evt->conn_handle,
                                                &p_hrs_c_evt->params.peer_db);
            // Initiate bonding.
            err_code = pm_conn_secure(p_hrs_c_evt->conn_handle, false);
            if (err_code != NRF_ERROR_BUSY)
            // Heart rate service discovered. Enable notification of Heart Rate Measurement.
            err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
        } break;
        case BLE_HRS_C_EVT_HRM_NOTIFICATION:
            NRF_LOG_INFO("Heart Rate = %d.", p_hrs_c_evt->params.hrm.hr_value);
            if (p_hrs_c_evt->params.hrm.rr_intervals_cnt != 0)
                uint32_t rr_avg = 0;
                for (uint32_t i = 0; i < p_hrs_c_evt->params.hrm.rr_intervals_cnt; i++)
                    rr_avg += p_hrs_c_evt->params.hrm.rr_intervals[i];
                rr_avg = rr_avg / p_hrs_c_evt->params.hrm.rr_intervals_cnt;
                NRF_LOG_DEBUG("rr_interval (avg) = %d.", rr_avg);
        } break;
/**@brief Battery level Collector Handler.
static void bas_c_evt_handler(ble_bas_c_t * p_bas_c, ble_bas_c_evt_t * p_bas_c_evt)
    switch (p_bas_c_evt->evt_type)
        case BLE_BAS_C_EVT_DISCOVERY_COMPLETE:
            err_code = ble_bas_c_handles_assign(p_bas_c,
                                                p_bas_c_evt->conn_handle,
                                                &p_bas_c_evt->params.bas_db);
            // Battery service discovered. Enable notification of Battery Level.
            NRF_LOG_DEBUG("Battery Service discovered. Reading battery level.");
            err_code = ble_bas_c_bl_read(p_bas_c);
            NRF_LOG_DEBUG("Enabling Battery Level Notification.");
            err_code = ble_bas_c_bl_notif_enable(p_bas_c);
        } break;
        case BLE_BAS_C_EVT_BATT_NOTIFICATION:
            NRF_LOG_INFO("Battery Level received %d %%.", p_bas_c_evt->params.battery_level);
        case BLE_BAS_C_EVT_BATT_READ_RESP:
            NRF_LOG_INFO("Battery Level Read as %d %%.", p_bas_c_evt->params.battery_level);
 * @brief Heart rate collector initialization.
static void hrs_c_init(void)
    ble_hrs_c_init_t hrs_c_init_obj;
    hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
    ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
 * @brief Battery level collector initialization.
static void bas_c_init(void)
    ble_bas_c_init_t bas_c_init_obj;
    bas_c_init_obj.evt_handler = bas_c_evt_handler;
    ret_code_t err_code = ble_bas_c_init(&m_bas_c, &bas_c_init_obj);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
 * @brief Database discovery collector initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
/**@brief Retrieve a list of peer manager peer IDs.
 * @param[inout] p_peers   The buffer where to store the list of peer IDs.
 * @param[inout] p_size    In: The size of the @p p_peers buffer.
 *                         Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
    pm_peer_id_t peer_id;
    uint32_t     peers_to_copy;
    peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
                     *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
    *p_size = 0;
    while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
        p_peers[(*p_size)++] = peer_id;
        peer_id = pm_next_peer_id_get(peer_id);
static void whitelist_load()
    ret_code_t   ret;
    pm_peer_id_t peers[8];
    uint32_t     peer_cnt;
    memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
    peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
    // Load all peers from flash and whitelist them.
    peer_list_get(peers, &peer_cnt);
    ret = pm_whitelist_set(peers, peer_cnt);
    APP_ERROR_CHECK(ret);
    // Setup the device identies list.
    // Some SoftDevices do not support this feature.
    ret = pm_device_identities_list_set(peers, peer_cnt);
    if (ret != NRF_ERROR_NOT_SUPPORTED)
static void on_whitelist_req(void)
    // Whitelist buffers.
    ble_gap_addr_t whitelist_addrs[8];
    ble_gap_irk_t  whitelist_irks[8];
    memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
    memset(whitelist_irks,  0x00, sizeof(whitelist_irks));
    uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
    uint32_t irk_cnt  = (sizeof(whitelist_irks)  / sizeof(ble_gap_irk_t));
    // Reload the whitelist and whitelist all peers.
    whitelist_load();
    // Get the whitelist previously set using pm_whitelist_set().
    err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                whitelist_irks,  &irk_cnt);
    if (((addr_cnt == 0) && (irk_cnt == 0)) ||
        (m_whitelist_disabled))
        // Don't use whitelist.
        err_code = nrf_ble_scan_params_set(&m_scan, NULL);
/**@brief Function to start scanning.
    if (nrf_fstorage_is_busy(NULL))
        m_memory_access_in_progress = true;
        return;
    NRF_LOG_INFO("Starting scan.");
    err_code = nrf_ble_scan_start(&m_scan);
    err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
/**@brief Function for initializing the power management module. */
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
            NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                         p_evt->conn_handle,
                         p_evt->params.att_mtu_effective);
        } break;
        case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
            NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
                         p_evt->conn_handle,
                         p_evt->params.data_length);
        } break;
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
            on_whitelist_req();
            m_whitelist_disabled = false;
        } break;
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
        case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
            NRF_LOG_INFO("Scan timed out.");
            scan_start();
        } break;
        case NRF_BLE_SCAN_EVT_FILTER_MATCH:
        case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
/**@brief Function for initialization scanning and setting filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.p_scan_param     = &m_scan_param;
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    ble_uuid_t uuid =
        .uuid = TARGET_UUID,
        .type = BLE_UUID_TYPE_BLE,
    err_code = nrf_ble_scan_filter_set(&m_scan,
                                       SCAN_UUID_FILTER,
                                       &uuid);
    if (strlen(m_target_periph_name) != 0)
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
    if (is_connect_per_addr)
                                          SCAN_ADDR_FILTER,
                                          m_target_periph_addr.addr);
    err_code = nrf_ble_scan_filters_enable(&m_scan,
                                           NRF_BLE_SCAN_ALL_FILTER,
                                           false);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
    err_code = nrf_ble_lesc_request_handler();
    NRF_LOG_FLUSH();
    nrf_pwr_mgmt_run();
/**@brief Function for starting a scan, or instead trigger it from peer manager (after
 *        deleting bonds).
 * @param[in] p_erase_bonds Pointer to a bool to determine if bonds will be deleted before scanning.
void scanning_start(bool * p_erase_bonds)
    // Start scanning for peripherals and initiate connection
    // with devices that advertise GATT Service UUID.
    if (*p_erase_bonds == true)
        // Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
        delete_bonds();
        scan_start();
    bool erase_bonds;
    // Initialize.
    log_init();
    if (NRF_LOG_DEFAULT_LEVEL == 4)
        NRF_LOG_INFO("!!! This is a debug build !!!");
    timer_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    peer_manager_init();
    db_discovery_init();
    hrs_c_init();
    bas_c_init();
    nus_c_init();
    scan_init();
    // Start execution.
    NRF_LOG_INFO("Heart Rate collector example started.");
    scanning_start(&erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
I am working on getting more verbose debugging. For some reason OpenOCD is giving me headaches and I am unable to pinpoint the exact function causing the problem at this time.
With debugging on, I'm surprised I'm not getting something like this with "<error> app: ERROR 4 [NRF_ERROR_NO_MEM] at .//main.c:395"? This example is from here. I made sure my debug flag was set.
<info> app: Multiperipheral example started.
<error> nrf_ble_gatt: sd_ble_gap_data_length_update() (request) on connection 0x0 returned NRF_ERROR_RESOURCES.
<error> nrf_ble_gatt: The requested TX/RX packet length is too long by 165/165 octets.
<info> app: Connection with link 0x0 established.
PC at: 0x0002CAF7
<error> app: End of error report
Looking for insight on debugging steps while I fix my VSCode-OpenOCD issue.
