publising big MQTT msgs
I have modyfied the MQTT example to, so I can send data to my own AWS account.
I'm trying to publish big packets of data, (> 7K) without luck .
what I have done is :
1. change CONFIG_MQTT_MAX_PACKET_LENGTH to 8500
2. modify client_write, the following way,
static int client_write(struct mqtt_client *client, const u8_t *data,
                        u32_t datalen)
        int err_code=0;
        u32_t tmplen=datalen;
        u8_t* tmpdata=data;
        MQTT_TRC("[%p]: Transport writing %d bytes.", client, datalen);
        MQTT_SET_STATE(client, MQTT_STATE_PENDING_WRITE);
        do {
        if (tmplen > MAX_SEND_SIZE_SCK)
                err_code += mqtt_transport_write(client, tmpdata, MAX_SEND_SIZE_SCK);
                tmplen -= MAX_SEND_SIZE_SCK;
                tmpdata += MAX_SEND_SIZE_SCK;
                if (err_code) printk("failed with errorcode : %d\n",err_code);
                        printk("all_ok!\n");
                err_code += mqtt_transport_write(client, tmpdata, tmplen);
        } while (1);
        MQTT_RESET_STATE(client, MQTT_STATE_PENDING_WRITE);
        if (err_code != 0) {
                printk("TCP write failed, errno = %d, "
                         "closing connection\n", errno);
                client_disconnect(client, err_code);
                return -EIO;
        MQTT_TRC("[%p]: Transport write complete.", client);
        client->last_activity = mqtt_sys_tick_in_ms_get();
        return 0;
I still get :
TCP write failed, errno = 12, closing connection
any idea why?
