Program SoftDevice
I am using the link below
https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/getting_started_softdevice.html#getting_started_sd
with 3 options for programming the softdevice.  I do not have Keil or GCC software, I do have nRFgo Studio.  I have my board connected via J-Link (have programmed several of the examples but now BLE states to program the softdevice with link above).
I can press recover and the Log shows "Recover completed"
I am stuck at step 3 from the link above :
  1. Open nRFgo Studio.
  2. In the Device Manager, select the nRF5 Development board that you are working with (identified by the SEGGER serial number).
  3. Select the Program SoftDevice tab.
  4. Click Browse and navigate to the SoftDevice file that you want to use.
  5. Click Program.
I have loaded BLE examples to the development boards successfully so figured I didnt need to program the softdevice but plugged in the USB to see what it would look like:
and end  up in the same situation.
Is there a way to do it with J-link command or even Segger studio?
I have located s140_nrf52_6.1.1_softdevice.hex
in C:\Users\E729128\Documents\MCM\Nordic Development Kit\nRF5 SKD v15.3.0 Developing Environment\nRF5_SDK_15.3.0_59ac345\components\softdevice\s140\hex
but it doesnt seem to help me much.
  • sounds good...
    I downloaded the install file, executed it, restarted my computer and went to
    C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin\nrfjprog
    i open nrfjprog and a black box opens, some text quickly scrolls, and it closes. I dont know how to open the command line to enter the text above. also dont i have to put the hex files into a specific folder for the command line to be able to access them
  • nRFgo Studio just started working all the sudden.  there may be a glitch/bug so if it doesnt work for you just keep trying, close studio open retry, unplug device replug in, reset device, etc.
    Plug in development board, double click on Segger 683928426. Press Erase all and wait for it to complete.  In the program soft device tab, load the softdevice hex and press program and once complete, verify.
    Repeat the process on the program application tab with the client hex file
    With the battery in the sensor, Do the same for the sensor via the J-link ultra+ cable, programming the softdevice and server hex files (you will need to double click on the nRF5x Programming
    (note that I got an error when programming the server hex but repeated the programming server hex step a couple times and although the error persisted, it was programmed successfully)
    Unplug the jlink but keep the battery in.
    2 for 2 of answering my own questions, not sure if this "tech support" is the greatest as it is almost a week later and a basic question could not be answered. hopefully my 3rd question will get an answer.
