Questions about adding "characteristics". (soft device: S132 5.00 SDK: 14.2.0 nRF52832)
I'm trying to realize the behavior of "BLE peripheral" that implements 20 "characteristics". While I was in the process of implementation, when I added 18 pieces, the return value of "sd_ble_gatts_characteristic_add ()" got an error.
When I investigated the cause of the error myself, I thought it was as follows. However, no confirmation was obtained. Would you please confirm that the recognition is correct?
-The RAM size that can be used to add "characteristic" can be changed by the definition of "NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE" described in "sdk_config.h". If you try to add a "characteristic" that exceeds the defined size, the return value of "sd_ble_gatts_characteristic_add ()" results in an error.
-Changing the value of "NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE" changes the amount of RAM used for "SoftDevice".
-The RAM usable area of ​​"SoftDevice" is from "0x2000 0000" to "Appication RAM start". If the amount of RAM used by "SoftDevice" exceeds this range, an error occurs.
    By changing “NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE” to fit within the range, it is possible to change the RAM size that can be used to add the characteristic without affecting other operations.
