I WANT ADD THE NFC EXAMPLE AT ble_app_beacon EXAMPLE.
Hi, i'm using nrf52832 uploaded ble_app_beacon example.
I want nrf52832 to work as a beacon and as a nfc tag.
Thus, I added some nfc example code. nfc_t2t_lib.h also added in bla_app_beacon project file.
But, compile result have 2 errors.
 Error: L6218E: Undefined symbol nfc_t2t_emulation_start (referred from main.o).
 Error: L6218E: Undefined symbol nfc_t2t_setup (referred from main.o).
PLZ Can anyone solve this? thank you
  • These are different errors, indicating that you have not included source files for nfc_platform and nrfx_nfct driver. I see you have included nfc_platform.c in your project, also make sure you add the following file:
    modules\nrfx\drivers\src\nrfx_nfct.c
    You also need to add this to your sdk_config.h file to enable the modules:
    // <e> NRFX_NFCT_ENABLED - nrfx_nfct - NFCT peripheral driver
    #ifndef NRFX_NFCT_ENABLED
    #define NRFX_NFCT_ENABLED 1
    // <o> NRFX_NFCT_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef NRFX_NFCT_CONFIG_IRQ_PRIORITY
    #define NRFX_NFCT_CONFIG_IRQ_PRIORITY 6
    // <e> NRFX_NFCT_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRFX_NFCT_CONFIG_LOG_ENABLED
    #define NRFX_NFCT_CONFIG_LOG_ENABLED 0
    // <o> NRFX_NFCT_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRFX_NFCT_CONFIG_LOG_LEVEL
    #define NRFX_NFCT_CONFIG_LOG_LEVEL 3
    // <o> NRFX_NFCT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRFX_NFCT_CONFIG_INFO_COLOR
    #define NRFX_NFCT_CONFIG_INFO_COLOR 0
    // <o> NRFX_NFCT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRFX_NFCT_CONFIG_DEBUG_COLOR
    #define NRFX_NFCT_CONFIG_DEBUG_COLOR 0
    // </e>
    // </e>
    // <e> NFC_PLATFORM_ENABLED - nfc_platform - NFC platform module for Clock control.
    #ifndef NFC_PLATFORM_ENABLED
    #define NFC_PLATFORM_ENABLED 1
    // <e> NFC_PLATFORM_LOG_ENABLED - Enables logging in the module.
    #ifndef NFC_PLATFORM_LOG_ENABLED
    #define NFC_PLATFORM_LOG_ENABLED 0
    // <o> NFC_PLATFORM_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NFC_PLATFORM_LOG_LEVEL
    #define NFC_PLATFORM_LOG_LEVEL 3
    // <o> NFC_PLATFORM_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NFC_PLATFORM_INFO_COLOR
    #define NFC_PLATFORM_INFO_COLOR 0
    // <o> NFC_PLATFORM_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NFC_PLATFORM_DEBUG_COLOR
    #define NFC_PLATFORM_DEBUG_COLOR 0
    // </e>
    // </e>
  • Jorgen, Thank you so much for kindly letting me know.
    I added several Paths and C files as you told me, and l got an error, but it was BUILD correctly after modifying it in sdk_config.h!
    I learned a lot about keil because of you. Thank you.
