nRF52832 - SDK 15.3 - RTC example: Dummy_Handler loop
Hi all,
I am using the nRF52832 and Segger Studio for developing a project.
My code is based on saadc, spi and rtc examples from 15.3 SDK. The saadc and spi work fine but when I use the code of the rtc example, especifically when I execute "nrf_drv_clock_lfclk_request(NULL)" function, after the subfunction "nrfx_clock_lfclk_start();" the program stops at this point and never exits from here:
.thumb_func
.weak Dummy_Handler
Dummy_Handler:
b .
I am using the same code of rtc example, and I have configured my sdk_config.h according to saadc, spi and rtc clocks, even though I use more peripherals. I have tried to use XTAL and RC for LF clock (changing NRFX_CLOCK_CONFIG_LF_SRC macro at sdk_config.h). RC is used by default for HF clock. I have both externals HF and LF clocks, but I have removed them also.
I have compared the codes, sdk_config.h, etc. and I don't know whats is the reason why my code doesn't work and it is blocked at "Dummy_Handler".
Please, can anybody help me with this? What is exactly the problem?
Finally I would like to share my functions, config file and CPU registers in order to give to the community more info.
Thanks.
Joaquim.
sdk_config.h
#include "globals.h"
#include "hal_ioexp.h"
#include "hal_buzzer.h"
#include "hal_button.h"
#include "hal_adc.h"
#include "app_timer.h"
#include "nrf_drv_clock.h"
#include "hal_timer.h"
#include "nrf_gpio.h"
#include "nrf_drv_rtc.h"
* CONSTANTS AND DEFINES
* ENUMS
* MACROS
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
* TYPEDEFS
* GLOBALS
* LOCALS
uint8_t Timer_ID;
* FUNCTIONS
/** @brief Function initialization and configuration of RTC driver instance.
static void rtc_config(void)
    uint32_t err_code;
    //Initialize RTC instance
    nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
    config.prescaler = 4095;
    err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
    //Enable tick event & interrupt
    nrf_drv_rtc_tick_enable(&rtc,true);
    //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
    err_code = nrf_drv_rtc_cc_set(&rtc, 0, 1, true);
    //Power on RTC instance
    nrf_drv_rtc_enable(&rtc);
* Hal_Timer_Init
void Hal_Timer_Init(void)
ret_code_t err_code = nrf_drv_clock_init();
//  nrfx_clock_lfclk_start();
//  while (!nrf_drv_clock_lfclk_is_running());
  rtc_config();
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
  if (int_type == NRF_DRV_RTC_INT_COMPARE0)
    EventsApp.RTC |= Event_RTC_Timeout;
  else if (int_type == NRF_DRV_RTC_INT_TICK)
* Hal_Timer_Blink_RGB
void Hal_Timer_Blink_RGB(void)
static bool toogle = true;
  EventsApp.RTC &= ~Event_RTC_Timeout;
  if (toogle)
    encenLedRGB(RGB_WARNING, VERMELL, false, false);
    bitClearAll();
  toogle = !toogle;
hal_timer.h
CLOCK
    TASKS_HFCLKSTART
    TASKS_HFCLKSTOP
    TASKS_LFCLKSTART
    TASKS_LFCLKSTOP
    TASKS_CAL
    TASKS_CTSTART
    TASKS_CTSTOP
    EVENTS_HFCLKSTARTED          0x00000000
    EVENTS_LFCLKSTARTED          0x00000001
    EVENTS_DONE                  0x00000000
    EVENTS_CTTO                  0x00000000
    INTENSET                     0x00000002
        HFCLKSTARTED             0
        LFCLKSTARTED             1
        DONE                     0
        CTTO                     0
    INTENCLR                     0x00000002
        HFCLKSTARTED             0
        LFCLKSTARTED             1
        DONE                     0
        CTTO                     0
    HFCLKRUN                     0x00000000
        STATUS                   0
    HFCLKSTAT                    0x00010000
        SRC                      0
        STATE                    1
    LFCLKRUN                     0x00000001
        STATUS                   1
    LFCLKSTAT                    0x00010000
        SRC                      0
        STATE                    1
    LFCLKSRCCOPY                 0x00000000
        SRC                      0
    LFCLKSRC                     0x00000000
        SRC                      0
        BYPASS                   0
        EXTERNAL                 0
    CTIV                         0x00000000
        CTIV                     0x00
    TRACECONFIG                  0x00000000
        TRACEPORTSPEED           0
        TRACEMUX                 0
GPIOTE
    TASKS_OUT[0]
    TASKS_OUT[1]
    TASKS_OUT[2]
    TASKS_OUT[3]
    TASKS_OUT[4]
    TASKS_OUT[5]
    TASKS_OUT[6]
    TASKS_OUT[7]
    TASKS_SET[0]
    TASKS_SET[1]
    TASKS_SET[2]
    TASKS_SET[3]
    TASKS_SET[4]
    TASKS_SET[5]
    TASKS_SET[6]
    TASKS_SET[7]
    TASKS_CLR[0]
    TASKS_CLR[1]
    TASKS_CLR[2]
    TASKS_CLR[3]
    TASKS_CLR[4]
    TASKS_CLR[5]
    TASKS_CLR[6]
    TASKS_CLR[7]
    EVENTS_IN[0]                 0x00000000
    EVENTS_IN[1]                 0x00000000
    EVENTS_IN[2]                 0x00000000
    EVENTS_IN[3]                 0x00000000
    EVENTS_IN[4]                 0x00000000
    EVENTS_IN[5]                 0x00000000
    EVENTS_IN[6]                 0x00000000
    EVENTS_IN[7]                 0x00000000
    EVENTS_PORT                  0x00000000
    INTENSET                     0x80000007
        IN0                      1
        IN1                      1
        IN2                      1
        IN3                      0
        IN4                      0
        IN5                      0
        IN6                      0
        IN7                      0
        PORT                     1
    INTENCLR                     0x80000007
        IN0                      1
        IN1                      1
        IN2                      1
        IN3                      0
        IN4                      0
        IN5                      0
        IN6                      0
        IN7                      0
        PORT                     1
    CONFIG[0]                    0x00020501
        MODE                     1
        PSEL                     0x05
        POLARITY                 2
        OUTINIT                  0
    CONFIG[1]                    0x00021701
        MODE                     1
        PSEL                     0x17
        POLARITY                 2
        OUTINIT                  0
    CONFIG[2]                    0x00021f01
        MODE                     1
        PSEL                     0x1f
        POLARITY                 2
        OUTINIT                  0
    CONFIG[3]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[4]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[5]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[6]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[7]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
SAADC
    TASKS_START
    TASKS_SAMPLE
    TASKS_STOP
    TASKS_CALIBRATEOFFSET
    EVENTS_STARTED               0x00000001
    EVENTS_END                   0x00000001
    EVENTS_DONE                  0x00000001
    EVENTS_RESULTDONE            0x00000001
    EVENTS_CALIBRATEDONE         0x00000000
    EVENTS_STOPPED               0x00000000
    INTEN                        0x00000002
        STARTED                  0
        END                      1
        DONE                     0
        RESULTDONE               0
        CALIBRATEDONE            0
        STOPPED                  0
        CH0LIMITH                0
        CH0LIMITL                0
        CH1LIMITH                0
        CH1LIMITL                0
        CH2LIMITH                0
        CH2LIMITL                0
        CH3LIMITH                0
        CH3LIMITL                0
        CH4LIMITH                0
        CH4LIMITL                0
        CH5LIMITH                0
        CH5LIMITL                0
        CH6LIMITH                0
        CH6LIMITL                0
        CH7LIMITH                0
        CH7LIMITL                0
    INTENSET                     0x00000002
        STARTED                  0
        END                      1
        DONE                     0
        RESULTDONE               0
        CALIBRATEDONE            0
        STOPPED                  0
        CH0LIMITH                0
        CH0LIMITL                0
        CH1LIMITH                0
        CH1LIMITL                0
        CH2LIMITH                0
        CH2LIMITL                0
        CH3LIMITH                0
        CH3LIMITL                0
        CH4LIMITH                0
        CH4LIMITL                0
        CH5LIMITH                0
        CH5LIMITL                0
        CH6LIMITH                0
        CH6LIMITL                0
        CH7LIMITH                0
        CH7LIMITL                0
    INTENCLR                     0x00000002
        STARTED                  0
        END                      1
        DONE                     0
        RESULTDONE               0
        CALIBRATEDONE            0
        STOPPED                  0
        CH0LIMITH                0
        CH0LIMITL                0
        CH1LIMITH                0
        CH1LIMITL                0
        CH2LIMITH                0
        CH2LIMITL                0
        CH3LIMITH                0
        CH3LIMITL                0
        CH4LIMITH                0
        CH4LIMITL                0
        CH5LIMITH                0
        CH5LIMITL                0
        CH6LIMITH                0
        CH6LIMITL                0
        CH7LIMITH                0
        CH7LIMITL                0
    STATUS                       0x00000000
        STATUS                   0
    ENABLE                       0x00000001
        ENABLE                   1
    RESOLUTION                   0x00000002
        VAL                      2
    OVERSAMPLE                   0x00000001
        OVERSAMPLE               1
    SAMPLERATE                   0x00000000
        CC                       0x000
        MODE                     0
    EVENTS_CH[0].LIMITH          0x00000000
    EVENTS_CH[0].LIMITL          0x00000000
    EVENTS_CH[1].LIMITH          0x00000000
    EVENTS_CH[1].LIMITL          0x00000000
    EVENTS_CH[2].LIMITH          0x00000000
    EVENTS_CH[2].LIMITL          0x00000000
    EVENTS_CH[3].LIMITH          0x00000000
    EVENTS_CH[3].LIMITL          0x00000000
    EVENTS_CH[4].LIMITH          0x00000000
    EVENTS_CH[4].LIMITL          0x00000000
    EVENTS_CH[5].LIMITH          0x00000000
    EVENTS_CH[5].LIMITL          0x00000000
    EVENTS_CH[6].LIMITH          0x00000000
    EVENTS_CH[6].LIMITL          0x00000000
    EVENTS_CH[7].LIMITH          0x00000000
    EVENTS_CH[7].LIMITL          0x00000000
    CH[0].PSELP                  0x00000001
        PSELP                    1
    CH[0].PSELN                  0x00000000
        PSELN                    0
    CH[0].CONFIG                 0x01040400
        RESP                     0
        RESN                     0
        GAIN                     4
        REFSEL                   0
        TACQ                     4
        MODE                     0
        BURST                    1
    CH[0].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[1].PSELP                  0x00000000
        PSELP                    0
    CH[1].PSELN                  0x00000000
        PSELN                    0
    CH[1].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[1].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[2].PSELP                  0x00000000
        PSELP                    0
    CH[2].PSELN                  0x00000000
        PSELN                    0
    CH[2].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[2].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[3].PSELP                  0x00000000
        PSELP                    0
    CH[3].PSELN                  0x00000000
        PSELN                    0
    CH[3].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[3].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[4].PSELP                  0x00000000
        PSELP                    0
    CH[4].PSELN                  0x00000000
        PSELN                    0
    CH[4].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[4].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[5].PSELP                  0x00000000
        PSELP                    0
    CH[5].PSELN                  0x00000000
        PSELN                    0
    CH[5].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[5].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[6].PSELP                  0x00000000
        PSELP                    0
    CH[6].PSELN                  0x00000000
        PSELN                    0
    CH[6].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[6].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[7].PSELP                  0x00000000
        PSELP                    0
    CH[7].PSELN                  0x00000000
        PSELN                    0
    CH[7].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[7].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    RESULT.PTR                   0x20000030
        PTR                      0x20000030
    RESULT.MAXCNT                0x00000001
        MAXCNT                   0x0001
    RESULT.AMOUNT                0x00000001
        AMOUNT                   0x0001
TIMER0
    TASKS_START
    TASKS_STOP
    TASKS_COUNT
    TASKS_CLEAR
    TASKS_SHUTDOWN
    TASKS_CAPTURE[0]
    TASKS_CAPTURE[1]
    TASKS_CAPTURE[2]
    TASKS_CAPTURE[3]
    TASKS_CAPTURE[4]
    TASKS_CAPTURE[5]
    EVENTS_COMPARE[0]            0x00000001
    EVENTS_COMPARE[1]            0x00000000
    EVENTS_COMPARE[2]            0x00000000
    EVENTS_COMPARE[3]            0x00000000
    EVENTS_COMPARE[4]            0x00000000
    EVENTS_COMPARE[5]            0x00000000
    SHORTS                       0x00000001
        COMPARE0_CLEAR           1
        COMPARE1_CLEAR           0
        COMPARE2_CLEAR           0
        COMPARE3_CLEAR           0
        COMPARE4_CLEAR           0
        COMPARE5_CLEAR           0
        COMPARE0_STOP            0
        COMPARE1_STOP            0
        COMPARE2_STOP            0
        COMPARE3_STOP            0
        COMPARE4_STOP            0
        COMPARE5_STOP            0
    INTENSET                     0x00000000
        COMPARE0                 0
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
        COMPARE4                 0
        COMPARE5                 0
    INTENCLR                     0x00000000
        COMPARE0                 0
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
        COMPARE4                 0
        COMPARE5                 0
    MODE                         0x00000000
        MODE                     0
    BITMODE                      0x00000003
        BITMODE                  3
    PRESCALER                    0x00000000
        PRESCALER                0x0
    CC[0]                        0x02dc6c00
        CC                       0x02dc6c00
    CC[1]                        0x00000000
        CC                       0x00000000
    CC[2]                        0x00000000
        CC                       0x00000000
    CC[3]                        0x00000000
        CC                       0x00000000
    CC[4]                        0x00000000
        CC                       0x00000000
    CC[5]                        0x00000000
        CC                       0x00000000
P0
    OUT                          0x00001000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    OUTSET                       0x00001000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    OUTCLR                       0x00001000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    IN                           0x80a00030
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     1
        PIN5                     1
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    0
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    1
        PIN22                    0
        PIN23                    1
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    1
    DIR                          0x08115100
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     1
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    1
        PIN15                    0
        PIN16                    1
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    1
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    1
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    DIRSET                       0x08115100
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     1
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    1
        PIN15                    0
        PIN16                    1
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    1
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    1
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    DIRCLR                       0x08115100
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     1
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    1
        PIN15                    0
        PIN16                    1
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    1
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    1
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    LATCH                        0x00000000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    0
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    DETECTMODE                   0x00000000
        DETECTMODE               0
    PIN_CNF[0]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[1]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[2]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[3]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[4]                   0x00000000
        DIR                      0
        INPUT                    0
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[5]                   0x0000000c
        DIR                      0
        INPUT                    0
        PULL                     3
        DRIVE                    0
        SENSE                    0
    PIN_CNF[6]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[7]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[8]                   0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[9]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[10]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[11]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[12]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[13]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[14]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[15]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[16]                  0x00000001
        DIR                      1
        INPUT                    0
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[17]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[18]                  0x00000004
        DIR                      0
        INPUT                    0
        PULL                     1
        DRIVE                    0
        SENSE                    0
    PIN_CNF[19]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[20]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[21]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[22]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[23]                  0x0000000c
        DIR                      0
        INPUT                    0
        PULL                     3
        DRIVE                    0
        SENSE                    0
    PIN_CNF[24]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[25]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[26]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[27]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[28]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[29]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[30]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[31]                  0x0000000c
        DIR                      0
        INPUT                    0
        PULL                     3
        DRIVE                    0
        SENSE                    0
RTC0
    TASKS_START
    TASKS_STOP
    TASKS_CLEAR
    TASKS_TRIGOVRFLW
    EVENTS_TICK                  0x00000000
    EVENTS_OVRFLW                0x00000000
    EVENTS_COMPARE[0]            0x00000000
    INTENSET                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    INTENCLR                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    EVTEN                        0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    EVTENSET                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    EVTENCLR                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    COUNTER                      0x00000000
        COUNTER                  0x000000
    PRESCALER                    0x00000fff
        PRESCALER                0xfff
    CC[0]                        0x00000001
        COMPARE                  0x000001
    CC[1]                        0x00000000
        COMPARE                  0x000000
    CC[2]                        0x00000000
        COMPARE                  0x000000
    CC[3]                        0x00000000
        COMPARE                  0x000000
    I couldn't find the CPU registers in your attachment. I'm interested in the xPSR register when you have entered the dummy handler. The last bits tell us the ISR number.
  • Hi Vidar,
    Please, find attached CPU and others registers.
    I have done some changes (I use RTC1 and LF is XTAL) and now RTC is generating some interrupt under these conditions;
    RTC1
    Prescaler = 4095.
    Channel compare = 0.
    Compare counter time = 1, 2 or 3.
    If compare counter time is 1 (rtc feq 125ms) RTC handler is executed 2 times. If counter is 2, rtc handler is executed 1 time, and for 3 or more times no execution. Then my code goes to dummy handler.
    In the rtc handler I set the counter compare time and counter clear as below:
    Thanks.
    uint32_t err_code;
    err_code = nrf_drv_rtc_cc_set(&rtc, 0, COMPARE_COUNTERTIME, true); //Set RTC compare value. This needs to be done every time as the nrf_drv_rtc clears the compare register on every compare match
    nrf_drv_rtc_counter_clear(&rtc);
    CLOCK
        TASKS_HFCLKSTART
        TASKS_HFCLKSTOP
        TASKS_LFCLKSTART
        TASKS_LFCLKSTOP
        TASKS_CAL
        TASKS_CTSTART
        TASKS_CTSTOP
        INTENSET                                 0x00000002
            HFCLKSTARTED                         0
            LFCLKSTARTED                         1
            DONE                                 0
            CTTO                                 0
        INTENCLR                                 0x00000002
            HFCLKSTARTED                         0
            LFCLKSTARTED                         1
            DONE                                 0
            CTTO                                 0
        HFCLKRUN                                 0x00000000
            STATUS                               0
            SRC                                  0
            STATE                                1
        LFCLKRUN                                 0x00000001
            STATUS                               1
        LFCLKSTAT                                0x00010001
            SRC                                  1
            STATE                                1
        LFCLKSRCCOPY                             0x00000001
            SRC                                  1
        LFCLKSRC                                 0x00000001
            SRC                                  1
            BYPASS                               0
            EXTERNAL                             0
        CTIV                                     0x00000000
            CTIV                                 0x00
            TRACEPORTSPEED                       0
            TRACEMUX                             0
    RTC1
        TASKS_START
        TASKS_STOP
        TASKS_CLEAR
        TASKS_TRIGOVRFLW
        EVENTS_TICK                              0x00000001
        INTENSET                                 0x00010001
            TICK                                 1
            OVRFLW                               0
            COMPARE0                             1
            COMPARE1                             0
            COMPARE2                             0
            COMPARE3                             0
        INTENCLR                                 0x00010001
            TICK                                 1
            OVRFLW                               0
            COMPARE0                             1
            COMPARE1                             0
            COMPARE2                             0
            COMPARE3                             0
        EVTEN                                    0x00010001
            TICK                                 1
            OVRFLW                               0
            COMPARE0                             1
            COMPARE1                             0
            COMPARE2                             0
            COMPARE3                             0
        EVTENSET                                 0x00010001
            TICK                                 1
            OVRFLW                               0
            COMPARE0                             1
            COMPARE1                             0
            COMPARE2                             0
            COMPARE3                             0
        EVTENCLR                                 0x00010001
            TICK                                 1
            OVRFLW                               0
            COMPARE0                             1
            COMPARE1                             0
            COMPARE2                             0
            COMPARE3                             0
        COUNTER                                  0x0000000d
            COUNTER                              0x00000d
            PRESCALER                            0xfff
        CC[0]                                    0x00000001
            COMPARE                              0x000001
        CC[1]                                    0x00000000
            COMPARE                              0x000000
        CC[2]                                    0x00000000
            COMPARE                              0x000000
        CC[3]                                    0x00000000
            COMPARE                              0x000000
    CPU - Current Context
        r0                                       0x00000000
        r1                                       0x00000040
        r2                                       0x00000001
        r3                                       0x20000000
        r4                                       0x00000000
        r5                                       0x00000000
        r6                                       0x00000000
        r7                                       0x00000000
        r8                                       0x00000000
        r9                                       0x00000000
        r10                                      0x00000000
        r11                                      0x00000000
        r12                                      0x2000ffc8
        sp(r13)                                  0x2000ffd0
        lr(r14)                                  0xfffffff9
        pc(r15)                                  0x0000036e
        apsr                                     0x61000010
            GE                                   0x0
            Q                                    0
            V                                    0
            C                                    1
            Z                                    1
            N                                    0
    CPU
        r0                                       0x00000000
        r1                                       0x00000040
        r2                                       0x00000001
        r3                                       0x20000000
        r4                                       0x00000000
        r5                                       0x00000000
        r6                                       0x00000000
        r7                                       0x00000000
        r8                                       0x00000000
        r9                                       0x00000000
        r10                                      0x00000000
        r11                                      0x00000000
        r12                                      0x2000ffc8
        sp(r13)                                  0x2000ffd0
        lr(r14)                                  0xfffffff9
        pc(r15)                                  0x0000036e
        xpsr                                     0x61000010
            ISR                                  16
            IT[7:2]                              0x00
            GE                                   0x0
            T                                    1
            IT[1:0]                              0x0
            Q                                    0
            V                                    0
            C                                    1
            Z                                    1
            N                                    0
        msp                                      0x2000ffd0
        psp                                      0x00000000
        cfbp                                     0x00000000
            PRIMASK                              0
            BASEPRI                              0x00
            FAULTMASK                            0
            nPRIV                                0
            SPSEL                                0
            FPCA                                 0
        internal                                 0x00000001
            mode                                 1
    NVIC
        NVIC_ISER0                               0x000201c9
            POWER_CLOCK                          1
            RADIO                                0
            UARTE0_UART0                         0
            SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0    1
            SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1    0
            NFCT                                 0
            GPIOTE                               1
            SAADC                                1
            TIMER0                               1
            TIMER1                               0
            TIMER2                               0
            RTC0                                 0
            TEMP                                 0
            RNG                                  0
            ECB                                  0
            CCM_AAR                              0
            WDT                                  0
            RTC1                                 1
            QDEC                                 0
            COMP_LPCOMP                          0
            SWI0_EGU0                            0
            SWI1_EGU1                            0
            SWI2_EGU2                            0
            SWI3_EGU3                            0
            SWI4_EGU4                            0
            SWI5_EGU5                            0
            TIMER3                               0
            TIMER4                               0
            PWM0                                 0
            PDM                                  0
        NVIC_ISER1                               0x00000000
            MWU                                  0
            PWM1                                 0
            PWM2                                 0
            SPIM2_SPIS2_SPI2                     0
            RTC2                                 0
            I2S                                  0
            FPU                                  0
        NVIC_ICER0                               0x000201c9
            POWER_CLOCK                          1
            RADIO                                0
            UARTE0_UART0                         0
            NFCT                                 0
            GPIOTE                               1
            SAADC                                1
            TIMER0                               1
            TIMER1                               0
            TIMER2                               0
            RTC0                                 0
            TEMP                                 0
            RNG                                  0
            ECB                                  0
            CCM_AAR                              0
            WDT                                  0
            RTC1                                 1
            QDEC                                 0
            COMP_LPCOMP                          0
            SWI0_EGU0                            0
            SWI1_EGU1                            0
            SWI2_EGU2                            0
            SWI3_EGU3                            0
            SWI4_EGU4                            0
            SWI5_EGU5                            0
            TIMER3                               0
            TIMER4                               0
            PWM0                                 0
            PDM                                  0
        NVIC_ICER1                               0x00000000
            MWU                                  0
            PWM1                                 0
            PWM2                                 0
            SPIM2_SPIS2_SPI2                     0
            RTC2                                 0
            I2S                                  0
            FPU                                  0
        NVIC_ISPR0                               0x00020000
            POWER_CLOCK                          0
            RADIO                                0
            UARTE0_UART0                         0
            SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0    0
            NFCT                                 0
            GPIOTE                               0
            SAADC                                0
            TIMER0                               0
            TIMER1                               0
            TIMER2                               0
            RTC0                                 0
            TEMP                                 0
            RNG                                  0
            ECB                                  0
            CCM_AAR                              0
            WDT                                  0
            RTC1                                 1
            QDEC                                 0
            COMP_LPCOMP                          0
            SWI0_EGU0                            0
            SWI1_EGU1                            0
            SWI2_EGU2                            0
            SWI3_EGU3                            0
            SWI4_EGU4                            0
            SWI5_EGU5                            0
            TIMER3                               0
            TIMER4                               0
            PWM0                                 0
            PDM                                  0
        NVIC_ISPR1                               0x00000000
            MWU                                  0
            PWM1                                 0
            PWM2                                 0
            SPIM2_SPIS2_SPI2                     0
            RTC2                                 0
            I2S                                  0
            FPU                                  0
        NVIC_ICPR0                               0x00020000
            POWER_CLOCK                          0
            RADIO                                0
            UARTE0_UART0                         0
            NFCT                                 0
            GPIOTE                               0
            SAADC                                0
            TIMER0                               0
            TIMER1                               0
            TIMER2                               0
            RTC0                                 0
            TEMP                                 0
            RNG                                  0
            ECB                                  0
            CCM_AAR                              0
            WDT                                  0
            RTC1                                 1
            QDEC                                 0
            COMP_LPCOMP                          0
            SWI0_EGU0                            0
            SWI1_EGU1                            0
            SWI2_EGU2                            0
            SWI3_EGU3                            0
            SWI4_EGU4                            0
            SWI5_EGU5                            0
            TIMER3                               0
            TIMER4                               0
            PWM0                                 0
            PDM                                  0
        NVIC_ICPR1                               0x00000000
            MWU                                  0
            PWM1                                 0
            PWM2                                 0
            SPIM2_SPIS2_SPI2                     0
            RTC2                                 0
            I2S                                  0
            FPU                                  0
        NVIC_IABR0                               0x00000001
            POWER_CLOCK                          1
            RADIO                                0
            UARTE0_UART0                         0
            NFCT                                 0
            GPIOTE                               0
            SAADC                                0
            TIMER0                               0
            TIMER1                               0
            TIMER2                               0
            RTC0                                 0
            TEMP                                 0
            RNG                                  0
            ECB                                  0
            CCM_AAR                              0
            WDT                                  0
            RTC1                                 0
            QDEC                                 0
            COMP_LPCOMP                          0
            SWI0_EGU0                            0
            SWI1_EGU1                            0
            SWI2_EGU2                            0
            SWI3_EGU3                            0
            SWI4_EGU4                            0
            SWI5_EGU5                            0
            TIMER3                               0
            TIMER4                               0
            PWM0                                 0
            PDM                                  0
        NVIC_IABR1                               0x00000000
            MWU                                  0
            PWM1                                 0
            PWM2                                 0
            SPIM2_SPIS2_SPI2                     0
            RTC2                                 0
            I2S                                  0
            FPU                                  0
        NVIC_IPR0                                0xc00000c0
            POWER_CLOCK                          0x6
            RADIO                                0x0
            UARTE0_UART0                         0x0
            SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0    0x6
        NVIC_IPR1                                0xc0c00000
            SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1    0x0
            NFCT                                 0x0
            GPIOTE                               0x6
            SAADC                                0x6
        NVIC_IPR2                                0x000000c0
            TIMER0                               0x6
            TIMER1                               0x0
            TIMER2                               0x0
            RTC0                                 0x0
        NVIC_IPR3                                0x00000000
            TEMP                                 0x0
            RNG                                  0x0
            ECB                                  0x0
            CCM_AAR                              0x0
        NVIC_IPR4                                0x0000c000
            WDT                                  0x0
            RTC1                                 0x6
            QDEC                                 0x0
            COMP_LPCOMP                          0x0
        NVIC_IPR5                                0x00000000
            SWI0_EGU0                            0x0
            SWI1_EGU1                            0x0
            SWI2_EGU2                            0x0
            SWI3_EGU3                            0x0
        NVIC_IPR6                                0x00000000
            SWI4_EGU4                            0x0
            SWI5_EGU5                            0x0
            TIMER3                               0x0
            TIMER4                               0x0
        NVIC_IPR7                                0x00000000
            PWM0                                 0x0
            PDM                                  0x0
        NVIC_IPR8                                0x00000000
            MWU                                  0x0
            PWM1                                 0x0
            PWM2                                 0x0
            SPIM2_SPIS2_SPI2                     0x0
        NVIC_IPR9                                0x00000000
            RTC2                                 0x0
            I2S                                  0x0
            FPU                                  0x0
    NVMC
        READY                                    0x00000001
            READY                                1
        CONFIG                                   0x00000000
            WEN                                  0
        ERASEPAGE                                0x00000000
        ERASEPCR1                                0x00000000
        ERASEALL                                 0x00000000
            ERASEALL                             0
        ERASEPCR0                                0x00000000
        ERASEUICR                                0x00000000
            ERASEUICR                            0
        ICACHECNF                                0x00000000
            CACHEEN                              0
            CACHEPROFEN                          0
        IHIT                                     0x00000000
            HITS                                 0x00000000
        IMISS                                    0x00000000
            MISSES                               0x00000000
    SPI0
        EVENTS_READY                             0x00000001
        INTENSET                                 0x00000040
            READY                                0
        INTENCLR                                 0x00000040
            READY                                0
        ENABLE                                   0x00000007
            ENABLE                               7
        RXD
            RXD
        TXD                                      0x00000000
            TXD                                  0x00
        FREQUENCY                                0x08000000
            FREQUENCY                            134217728
        CONFIG                                   0x00000000
            ORDER                                0
            CPHA                                 0
            CPOL                                 0
        PSEL.SCK                                 0x00000010
            PSELSCK                              16
        PSEL.MOSI                                0x00000014
            PSELMOSI                             20
        PSEL.MISO                                0x00000012
            PSELMISO                             18
    SAADC
        TASKS_START
        TASKS_SAMPLE
        TASKS_STOP
        INTEN                                    0x00000002
            STARTED                              0
            END                                  1
            DONE                                 0
            RESULTDONE                           0
            CALIBRATEDONE                        0
            STOPPED                              0
            CH0LIMITH                            0
            CH0LIMITL                            0
            CH1LIMITH                            0
            CH1LIMITL                            0
            CH2LIMITH                            0
            CH2LIMITL                            0
            CH3LIMITH                            0
            CH3LIMITL                            0
            CH4LIMITH                            0
            CH4LIMITL                            0
            CH5LIMITH                            0
            CH5LIMITL                            0
            CH6LIMITH                            0
            CH6LIMITL                            0
            CH7LIMITH                            0
            CH7LIMITL                            0
        INTENSET                                 0x00000002
            STARTED                              0
            END                                  1
            DONE                                 0
            RESULTDONE                           0
            CALIBRATEDONE                        0
            STOPPED                              0
            CH0LIMITH                            0
            CH0LIMITL                            0
            CH1LIMITH                            0
            CH1LIMITL                            0
            CH2LIMITH                            0
            CH2LIMITL                            0
            CH3LIMITH                            0
            CH3LIMITL                            0
            CH4LIMITH                            0
            CH4LIMITL                            0
            CH5LIMITH                            0
            CH5LIMITL                            0
            CH6LIMITH                            0
            CH6LIMITL                            0
            CH7LIMITH                            0
            CH7LIMITL                            0
        INTENCLR                                 0x00000002
            STARTED                              0
            END                                  1
            DONE                                 0
            RESULTDONE                           0
            CALIBRATEDONE                        0
            STOPPED                              0
            CH0LIMITH                            0
            CH0LIMITL                            0
            CH1LIMITH                            0
            CH1LIMITL                            0
            CH2LIMITH                            0
            CH2LIMITL                            0
            CH3LIMITH                            0
            CH3LIMITL                            0
            CH4LIMITH                            0
            CH4LIMITL                            0
            CH5LIMITH                            0
            CH5LIMITL                            0
            CH6LIMITH                            0
            CH6LIMITL                            0
            CH7LIMITH                            0
            CH7LIMITL                            0
        STATUS                                   0x00000000
            STATUS                               0
        ENABLE                                   0x00000001
            ENABLE                               1
            VAL                                  2
            OVERSAMPLE                           1
            CC                                   0x000
            MODE                                 0
            PSELP                                1
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 4
            REFSEL                               0
            TACQ                                 4
            MODE                                 0
            BURST                                1
            LOW                                  0x8000
            HIGH                                 0x7fff
            PSELP                                0
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 0
            REFSEL                               0
            TACQ                                 2
            MODE                                 0
            BURST                                0
            LOW                                  0x8000
            HIGH                                 0x7fff
            PSELP                                0
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 0
            REFSEL                               0
            TACQ                                 2
            MODE                                 0
            BURST                                0
            LOW                                  0x8000
            HIGH                                 0x7fff
            PSELP                                0
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 0
            REFSEL                               0
            TACQ                                 2
            MODE                                 0
            BURST                                0
            LOW                                  0x8000
            HIGH                                 0x7fff
            PSELP                                0
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 0
            REFSEL                               0
            TACQ                                 2
            MODE                                 0
            BURST                                0
            LOW                                  0x8000
            HIGH                                 0x7fff
            PSELP                                0
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 0
            REFSEL                               0
            TACQ                                 2
            MODE                                 0
            BURST                                0
            LOW                                  0x8000
            HIGH                                 0x7fff
            PSELP                                0
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 0
            REFSEL                               0
            TACQ                                 2
            MODE                                 0
            BURST                                0
            LOW                                  0x8000
            HIGH                                 0x7fff
            PSELP                                0
            PSELN                                0
            RESP                                 0
            RESN                                 0
            GAIN                                 0
            REFSEL                               0
            TACQ                                 2
            MODE                                 0
            BURST                                0
            LOW                                  0x8000
            HIGH                                 0x7fff
            PTR                                  0x20000030
            MAXCNT                               0x0001
            AMOUNT                               0x0001
    GPIOTE
        TASKS_OUT[0]
        TASKS_OUT[1]
        TASKS_OUT[2]
        TASKS_OUT[3]
        TASKS_OUT[4]
        TASKS_OUT[5]
        TASKS_OUT[6]
        TASKS_OUT[7]
        TASKS_SET[0]
        TASKS_SET[1]
        TASKS_SET[2]
        TASKS_SET[3]
        TASKS_SET[4]
        TASKS_SET[5]
        TASKS_SET[6]
        TASKS_SET[7]
        TASKS_CLR[0]
        TASKS_CLR[1]
        TASKS_CLR[2]
        TASKS_CLR[3]
        TASKS_CLR[4]
        TASKS_CLR[5]
        TASKS_CLR[6]
        TASKS_CLR[7]
        INTENSET                                 0x80000007
            IN0                                  1
            IN1                                  1
            IN2                                  1
            IN3                                  0
            IN4                                  0
            IN5                                  0
            IN6                                  0
            IN7                                  0
            PORT                                 1
        INTENCLR                                 0x80000007
            IN0                                  1
            IN1                                  1
            IN2                                  1
            IN3                                  0
            IN4                                  0
            IN5                                  0
            IN6                                  0
            IN7                                  0
            PORT                                 1
            MODE                                 1
            PSEL                                 0x05
            POLARITY                             2
            OUTINIT                              0
            MODE                                 1
            PSEL                                 0x17
            POLARITY                             2
            OUTINIT                              0
            MODE                                 1
            PSEL                                 0x1f
            POLARITY                             2
            OUTINIT                              0
            MODE                                 0
            PSEL                                 0x00
            POLARITY                             0
            OUTINIT                              0
            MODE                                 0
            PSEL                                 0x00
            POLARITY                             0
            OUTINIT                              0
            MODE                                 0
            PSEL                                 0x00
            POLARITY                             0
            OUTINIT                              0
            MODE                                 0
            PSEL                                 0x00
            POLARITY                             0
            OUTINIT                              0
            MODE                                 0
            PSEL                                 0x00
            POLARITY                             0
            OUTINIT                              0
    SPIM0
        TASKS_START
        TASKS_STOP
        TASKS_SUSPEND
        TASKS_RESUME
        EVENTS_ENDRX                             0x00000001
        EVENTS_END                               0x00000000
        EVENTS_ENDTX                             0x00000001
        SHORTS                                   0x00000000
            END_START                            0
        INTENSET                                 0x00000040
            STOPPED                              0
            ENDRX                                0
            END                                  1
            ENDTX                                0
            STARTED                              0
        INTENCLR                                 0x00000040
            STOPPED                              0
            ENDRX                                0
            END                                  1
            ENDTX                                0
            STARTED                              0
        ENABLE                                   0x00000007
            ENABLE                               7
            FREQUENCY                            134217728
        CONFIG                                   0x00000000
            ORDER                                0
            CPHA                                 0
            CPOL                                 0
        ORC                                      0x000000ff
            ORC                                  0xff
        PSEL.SCK                                 0x00000010
            PIN                                  0x10
            CONNECT                              0
            PIN                                  0x14
            CONNECT                              0
            PIN                                  0x12
            CONNECT                              0
        RXD.PTR                                  0x2000ffc8
            PTR                                  0x2000ffc8
        RXD.MAXCNT                               0x00000003
            MAXCNT                               0x03
        RXD.AMOUNT                               0x00000003
            AMOUNT                               0x03
        RXD.LIST                                 0x00000000
            LIST                                 0
        TXD.PTR                                  0x2000ffcc
            PTR                                  0x2000ffcc
        TXD.MAXCNT                               0x00000003
            MAXCNT                               0x03
        TXD.AMOUNT                               0x00000003
            AMOUNT                               0x03
        TXD.LIST                                 0x00000000
            LIST                                 0
  • Thanks for the additional info. The problem is likely that the POWER_CLOCK_IRQHandler is not defined. Have you included nrfx_power_clock.c in your project?
    I only have nrfx_power_clock.h header file. I can't found the .c source in SDK nRF5_SDK_15.3.0_59ac345 version, which I use, but in the nRF5_SDK_15.0.0_a53641a it is...
    I have copied it and I get an error when compiling "undefined reference to `nrfx_power_irq_handler'". I had defined POWER_ENABLED macro but without configuring the driver and including the .c. This is why I could compile without errors.
    If I disable power macro, RTC works fine.
    Thank you very much.
    I was looking at SDK 15.2.0, sorry. Have you included both nrf_drv_clock.c and nrftx_clock.c in your project?
