nRF52832 - SDK 15.3 - RTC example: Dummy_Handler loop
Hi all,
I am using the nRF52832 and Segger Studio for developing a project.
My code is based on saadc, spi and rtc examples from 15.3 SDK. The saadc and spi work fine but when I use the code of the rtc example, especifically when I execute "nrf_drv_clock_lfclk_request(NULL)" function, after the subfunction "nrfx_clock_lfclk_start();" the program stops at this point and never exits from here:
.thumb_func
.weak Dummy_Handler
Dummy_Handler:
b .
I am using the same code of rtc example, and I have configured my sdk_config.h according to saadc, spi and rtc clocks, even though I use more peripherals. I have tried to use XTAL and RC for LF clock (changing NRFX_CLOCK_CONFIG_LF_SRC macro at sdk_config.h). RC is used by default for HF clock. I have both externals HF and LF clocks, but I have removed them also.
I have compared the codes, sdk_config.h, etc. and I don't know whats is the reason why my code doesn't work and it is blocked at "Dummy_Handler".
Please, can anybody help me with this? What is exactly the problem?
Finally I would like to share my functions, config file and CPU registers in order to give to the community more info.
Thanks.
Joaquim.
sdk_config.h
#include "globals.h"
#include "hal_ioexp.h"
#include "hal_buzzer.h"
#include "hal_button.h"
#include "hal_adc.h"
#include "app_timer.h"
#include "nrf_drv_clock.h"
#include "hal_timer.h"
#include "nrf_gpio.h"
#include "nrf_drv_rtc.h"
* CONSTANTS AND DEFINES
* ENUMS
* MACROS
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
* TYPEDEFS
* GLOBALS
* LOCALS
uint8_t Timer_ID;
* FUNCTIONS
/** @brief Function initialization and configuration of RTC driver instance.
static void rtc_config(void)
    uint32_t err_code;
    //Initialize RTC instance
    nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
    config.prescaler = 4095;
    err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
    //Enable tick event & interrupt
    nrf_drv_rtc_tick_enable(&rtc,true);
    //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
    err_code = nrf_drv_rtc_cc_set(&rtc, 0, 1, true);
    //Power on RTC instance
    nrf_drv_rtc_enable(&rtc);
* Hal_Timer_Init
void Hal_Timer_Init(void)
ret_code_t err_code = nrf_drv_clock_init();
//  nrfx_clock_lfclk_start();
//  while (!nrf_drv_clock_lfclk_is_running());
  rtc_config();
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
  if (int_type == NRF_DRV_RTC_INT_COMPARE0)
    EventsApp.RTC |= Event_RTC_Timeout;
  else if (int_type == NRF_DRV_RTC_INT_TICK)
* Hal_Timer_Blink_RGB
void Hal_Timer_Blink_RGB(void)
static bool toogle = true;
  EventsApp.RTC &= ~Event_RTC_Timeout;
  if (toogle)
    encenLedRGB(RGB_WARNING, VERMELL, false, false);
    bitClearAll();
  toogle = !toogle;
hal_timer.h
CLOCK
    TASKS_HFCLKSTART
    TASKS_HFCLKSTOP
    TASKS_LFCLKSTART
    TASKS_LFCLKSTOP
    TASKS_CAL
    TASKS_CTSTART
    TASKS_CTSTOP
    EVENTS_HFCLKSTARTED          0x00000000
    EVENTS_LFCLKSTARTED          0x00000001
    EVENTS_DONE                  0x00000000
    EVENTS_CTTO                  0x00000000
    INTENSET                     0x00000002
        HFCLKSTARTED             0
        LFCLKSTARTED             1
        DONE                     0
        CTTO                     0
    INTENCLR                     0x00000002
        HFCLKSTARTED             0
        LFCLKSTARTED             1
        DONE                     0
        CTTO                     0
    HFCLKRUN                     0x00000000
        STATUS                   0
    HFCLKSTAT                    0x00010000
        SRC                      0
        STATE                    1
    LFCLKRUN                     0x00000001
        STATUS                   1
    LFCLKSTAT                    0x00010000
        SRC                      0
        STATE                    1
    LFCLKSRCCOPY                 0x00000000
        SRC                      0
    LFCLKSRC                     0x00000000
        SRC                      0
        BYPASS                   0
        EXTERNAL                 0
    CTIV                         0x00000000
        CTIV                     0x00
    TRACECONFIG                  0x00000000
        TRACEPORTSPEED           0
        TRACEMUX                 0
GPIOTE
    TASKS_OUT[0]
    TASKS_OUT[1]
    TASKS_OUT[2]
    TASKS_OUT[3]
    TASKS_OUT[4]
    TASKS_OUT[5]
    TASKS_OUT[6]
    TASKS_OUT[7]
    TASKS_SET[0]
    TASKS_SET[1]
    TASKS_SET[2]
    TASKS_SET[3]
    TASKS_SET[4]
    TASKS_SET[5]
    TASKS_SET[6]
    TASKS_SET[7]
    TASKS_CLR[0]
    TASKS_CLR[1]
    TASKS_CLR[2]
    TASKS_CLR[3]
    TASKS_CLR[4]
    TASKS_CLR[5]
    TASKS_CLR[6]
    TASKS_CLR[7]
    EVENTS_IN[0]                 0x00000000
    EVENTS_IN[1]                 0x00000000
    EVENTS_IN[2]                 0x00000000
    EVENTS_IN[3]                 0x00000000
    EVENTS_IN[4]                 0x00000000
    EVENTS_IN[5]                 0x00000000
    EVENTS_IN[6]                 0x00000000
    EVENTS_IN[7]                 0x00000000
    EVENTS_PORT                  0x00000000
    INTENSET                     0x80000007
        IN0                      1
        IN1                      1
        IN2                      1
        IN3                      0
        IN4                      0
        IN5                      0
        IN6                      0
        IN7                      0
        PORT                     1
    INTENCLR                     0x80000007
        IN0                      1
        IN1                      1
        IN2                      1
        IN3                      0
        IN4                      0
        IN5                      0
        IN6                      0
        IN7                      0
        PORT                     1
    CONFIG[0]                    0x00020501
        MODE                     1
        PSEL                     0x05
        POLARITY                 2
        OUTINIT                  0
    CONFIG[1]                    0x00021701
        MODE                     1
        PSEL                     0x17
        POLARITY                 2
        OUTINIT                  0
    CONFIG[2]                    0x00021f01
        MODE                     1
        PSEL                     0x1f
        POLARITY                 2
        OUTINIT                  0
    CONFIG[3]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[4]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[5]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[6]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
    CONFIG[7]                    0x00000000
        MODE                     0
        PSEL                     0x00
        POLARITY                 0
        OUTINIT                  0
SAADC
    TASKS_START
    TASKS_SAMPLE
    TASKS_STOP
    TASKS_CALIBRATEOFFSET
    EVENTS_STARTED               0x00000001
    EVENTS_END                   0x00000001
    EVENTS_DONE                  0x00000001
    EVENTS_RESULTDONE            0x00000001
    EVENTS_CALIBRATEDONE         0x00000000
    EVENTS_STOPPED               0x00000000
    INTEN                        0x00000002
        STARTED                  0
        END                      1
        DONE                     0
        RESULTDONE               0
        CALIBRATEDONE            0
        STOPPED                  0
        CH0LIMITH                0
        CH0LIMITL                0
        CH1LIMITH                0
        CH1LIMITL                0
        CH2LIMITH                0
        CH2LIMITL                0
        CH3LIMITH                0
        CH3LIMITL                0
        CH4LIMITH                0
        CH4LIMITL                0
        CH5LIMITH                0
        CH5LIMITL                0
        CH6LIMITH                0
        CH6LIMITL                0
        CH7LIMITH                0
        CH7LIMITL                0
    INTENSET                     0x00000002
        STARTED                  0
        END                      1
        DONE                     0
        RESULTDONE               0
        CALIBRATEDONE            0
        STOPPED                  0
        CH0LIMITH                0
        CH0LIMITL                0
        CH1LIMITH                0
        CH1LIMITL                0
        CH2LIMITH                0
        CH2LIMITL                0
        CH3LIMITH                0
        CH3LIMITL                0
        CH4LIMITH                0
        CH4LIMITL                0
        CH5LIMITH                0
        CH5LIMITL                0
        CH6LIMITH                0
        CH6LIMITL                0
        CH7LIMITH                0
        CH7LIMITL                0
    INTENCLR                     0x00000002
        STARTED                  0
        END                      1
        DONE                     0
        RESULTDONE               0
        CALIBRATEDONE            0
        STOPPED                  0
        CH0LIMITH                0
        CH0LIMITL                0
        CH1LIMITH                0
        CH1LIMITL                0
        CH2LIMITH                0
        CH2LIMITL                0
        CH3LIMITH                0
        CH3LIMITL                0
        CH4LIMITH                0
        CH4LIMITL                0
        CH5LIMITH                0
        CH5LIMITL                0
        CH6LIMITH                0
        CH6LIMITL                0
        CH7LIMITH                0
        CH7LIMITL                0
    STATUS                       0x00000000
        STATUS                   0
    ENABLE                       0x00000001
        ENABLE                   1
    RESOLUTION                   0x00000002
        VAL                      2
    OVERSAMPLE                   0x00000001
        OVERSAMPLE               1
    SAMPLERATE                   0x00000000
        CC                       0x000
        MODE                     0
    EVENTS_CH[0].LIMITH          0x00000000
    EVENTS_CH[0].LIMITL          0x00000000
    EVENTS_CH[1].LIMITH          0x00000000
    EVENTS_CH[1].LIMITL          0x00000000
    EVENTS_CH[2].LIMITH          0x00000000
    EVENTS_CH[2].LIMITL          0x00000000
    EVENTS_CH[3].LIMITH          0x00000000
    EVENTS_CH[3].LIMITL          0x00000000
    EVENTS_CH[4].LIMITH          0x00000000
    EVENTS_CH[4].LIMITL          0x00000000
    EVENTS_CH[5].LIMITH          0x00000000
    EVENTS_CH[5].LIMITL          0x00000000
    EVENTS_CH[6].LIMITH          0x00000000
    EVENTS_CH[6].LIMITL          0x00000000
    EVENTS_CH[7].LIMITH          0x00000000
    EVENTS_CH[7].LIMITL          0x00000000
    CH[0].PSELP                  0x00000001
        PSELP                    1
    CH[0].PSELN                  0x00000000
        PSELN                    0
    CH[0].CONFIG                 0x01040400
        RESP                     0
        RESN                     0
        GAIN                     4
        REFSEL                   0
        TACQ                     4
        MODE                     0
        BURST                    1
    CH[0].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[1].PSELP                  0x00000000
        PSELP                    0
    CH[1].PSELN                  0x00000000
        PSELN                    0
    CH[1].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[1].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[2].PSELP                  0x00000000
        PSELP                    0
    CH[2].PSELN                  0x00000000
        PSELN                    0
    CH[2].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[2].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[3].PSELP                  0x00000000
        PSELP                    0
    CH[3].PSELN                  0x00000000
        PSELN                    0
    CH[3].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[3].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[4].PSELP                  0x00000000
        PSELP                    0
    CH[4].PSELN                  0x00000000
        PSELN                    0
    CH[4].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[4].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[5].PSELP                  0x00000000
        PSELP                    0
    CH[5].PSELN                  0x00000000
        PSELN                    0
    CH[5].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[5].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[6].PSELP                  0x00000000
        PSELP                    0
    CH[6].PSELN                  0x00000000
        PSELN                    0
    CH[6].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[6].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    CH[7].PSELP                  0x00000000
        PSELP                    0
    CH[7].PSELN                  0x00000000
        PSELN                    0
    CH[7].CONFIG                 0x00020000
        RESP                     0
        RESN                     0
        GAIN                     0
        REFSEL                   0
        TACQ                     2
        MODE                     0
        BURST                    0
    CH[7].LIMIT                  0x7fff8000
        LOW                      0x8000
        HIGH                     0x7fff
    RESULT.PTR                   0x20000030
        PTR                      0x20000030
    RESULT.MAXCNT                0x00000001
        MAXCNT                   0x0001
    RESULT.AMOUNT                0x00000001
        AMOUNT                   0x0001
TIMER0
    TASKS_START
    TASKS_STOP
    TASKS_COUNT
    TASKS_CLEAR
    TASKS_SHUTDOWN
    TASKS_CAPTURE[0]
    TASKS_CAPTURE[1]
    TASKS_CAPTURE[2]
    TASKS_CAPTURE[3]
    TASKS_CAPTURE[4]
    TASKS_CAPTURE[5]
    EVENTS_COMPARE[0]            0x00000001
    EVENTS_COMPARE[1]            0x00000000
    EVENTS_COMPARE[2]            0x00000000
    EVENTS_COMPARE[3]            0x00000000
    EVENTS_COMPARE[4]            0x00000000
    EVENTS_COMPARE[5]            0x00000000
    SHORTS                       0x00000001
        COMPARE0_CLEAR           1
        COMPARE1_CLEAR           0
        COMPARE2_CLEAR           0
        COMPARE3_CLEAR           0
        COMPARE4_CLEAR           0
        COMPARE5_CLEAR           0
        COMPARE0_STOP            0
        COMPARE1_STOP            0
        COMPARE2_STOP            0
        COMPARE3_STOP            0
        COMPARE4_STOP            0
        COMPARE5_STOP            0
    INTENSET                     0x00000000
        COMPARE0                 0
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
        COMPARE4                 0
        COMPARE5                 0
    INTENCLR                     0x00000000
        COMPARE0                 0
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
        COMPARE4                 0
        COMPARE5                 0
    MODE                         0x00000000
        MODE                     0
    BITMODE                      0x00000003
        BITMODE                  3
    PRESCALER                    0x00000000
        PRESCALER                0x0
    CC[0]                        0x02dc6c00
        CC                       0x02dc6c00
    CC[1]                        0x00000000
        CC                       0x00000000
    CC[2]                        0x00000000
        CC                       0x00000000
    CC[3]                        0x00000000
        CC                       0x00000000
    CC[4]                        0x00000000
        CC                       0x00000000
    CC[5]                        0x00000000
        CC                       0x00000000
P0
    OUT                          0x00001000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    OUTSET                       0x00001000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    OUTCLR                       0x00001000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    IN                           0x80a00030
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     1
        PIN5                     1
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    0
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    1
        PIN22                    0
        PIN23                    1
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    1
    DIR                          0x08115100
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     1
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    1
        PIN15                    0
        PIN16                    1
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    1
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    1
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    DIRSET                       0x08115100
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     1
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    1
        PIN15                    0
        PIN16                    1
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    1
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    1
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    DIRCLR                       0x08115100
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     1
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    1
        PIN13                    0
        PIN14                    1
        PIN15                    0
        PIN16                    1
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    1
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    1
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    LATCH                        0x00000000
        PIN0                     0
        PIN1                     0
        PIN2                     0
        PIN3                     0
        PIN4                     0
        PIN5                     0
        PIN6                     0
        PIN7                     0
        PIN8                     0
        PIN9                     0
        PIN10                    0
        PIN11                    0
        PIN12                    0
        PIN13                    0
        PIN14                    0
        PIN15                    0
        PIN16                    0
        PIN17                    0
        PIN18                    0
        PIN19                    0
        PIN20                    0
        PIN21                    0
        PIN22                    0
        PIN23                    0
        PIN24                    0
        PIN25                    0
        PIN26                    0
        PIN27                    0
        PIN28                    0
        PIN29                    0
        PIN30                    0
        PIN31                    0
    DETECTMODE                   0x00000000
        DETECTMODE               0
    PIN_CNF[0]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[1]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[2]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[3]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[4]                   0x00000000
        DIR                      0
        INPUT                    0
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[5]                   0x0000000c
        DIR                      0
        INPUT                    0
        PULL                     3
        DRIVE                    0
        SENSE                    0
    PIN_CNF[6]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[7]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[8]                   0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[9]                   0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[10]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[11]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[12]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[13]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[14]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[15]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[16]                  0x00000001
        DIR                      1
        INPUT                    0
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[17]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[18]                  0x00000004
        DIR                      0
        INPUT                    0
        PULL                     1
        DRIVE                    0
        SENSE                    0
    PIN_CNF[19]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[20]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[21]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[22]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[23]                  0x0000000c
        DIR                      0
        INPUT                    0
        PULL                     3
        DRIVE                    0
        SENSE                    0
    PIN_CNF[24]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[25]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[26]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[27]                  0x00000003
        DIR                      1
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[28]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[29]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[30]                  0x00000002
        DIR                      0
        INPUT                    1
        PULL                     0
        DRIVE                    0
        SENSE                    0
    PIN_CNF[31]                  0x0000000c
        DIR                      0
        INPUT                    0
        PULL                     3
        DRIVE                    0
        SENSE                    0
RTC0
    TASKS_START
    TASKS_STOP
    TASKS_CLEAR
    TASKS_TRIGOVRFLW
    EVENTS_TICK                  0x00000000
    EVENTS_OVRFLW                0x00000000
    EVENTS_COMPARE[0]            0x00000000
    INTENSET                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    INTENCLR                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    EVTEN                        0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    EVTENSET                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    EVTENCLR                     0x00010001
        TICK                     1
        OVRFLW                   0
        COMPARE0                 1
        COMPARE1                 0
        COMPARE2                 0
        COMPARE3                 0
    COUNTER                      0x00000000
        COUNTER                  0x000000
    PRESCALER                    0x00000fff
        PRESCALER                0xfff
    CC[0]                        0x00000001
        COMPARE                  0x000001
    CC[1]                        0x00000000
        COMPARE                  0x000000
    CC[2]                        0x00000000
        COMPARE                  0x000000
    CC[3]                        0x00000000
        COMPARE                  0x000000
