Not able to scan TWI sensors when pins are changed
I am using nRF52832, SDK_15.3.0, S132 SoftDevice and Segger for flashing the image.
I am using "twi_scanner" example code on Development kit. I connected HDC2010 sensor and I got 0x40 as address.
Since "Production specification" says any GPIO can be used, I just changed settings as below so that SCL is on P0.21 and SDA is on P0.22.
#define ARDUINO_SCL_PIN 21//27 // SCL signal pin
#define ARDUINO_SDA_PIN 22//26 // SDA signal pin
With this changes, never code executes and hangs in nrf_twim_event_check(). Any reason behind this ? Do I need to configure any other settings ?
Thanks & Regards
Vishnu Beema
