unexpected sd_app_evt_wait() returning
I have a BLE application, running a GATT server on a nrf52832. The main loop, is basically an endless loop, starting with a call to `sd_app_evt_wait()`, then handling events provided by `sd_ble_evt_get()`. I toggle a debug pin at the beginning and the end of the main loops body.
When I connect with a BLE client to the GATT server, the debug pin starts to toggle very quickly, with a period of ~12.5µs. I use a counter to ignore the first 1000 runs through the main loop, after which I insert a break point. No call to `sd_ble_evt_get()` returns any event. Before hitting the breakpoint, I store NVIC->ISPR[0] in a variable. The value of this variable is 1, which indicates, that `sd_app_evt_wait()` returned doe to a pending radio interrupt.
How can I avoid, to have `sd_app_evt_wait()` returning, even when there is no event to handle? How can I further investigate what happens here? (Softdevice in use is S132 Version 6.1.0).
Thanks in advance,
Torsten
  • Hi Torsten
     This is not Radio, but POWER/Clock. You should also check NVIC->ISPR[1] as the nRF52 have more than 32 interrupt sources. I'm guessing there is an interrupt that isn't configured correctly in there that is preventing your application from going to sleep.
    Simon
  • Hi Simon,
    thank you for having a look into my issue. I've played a little with the static counter, that I use to have the break point a little bit later in time. I've used 50000, 50010 and 55000. `ISPR[0]` is always `0x400000` and `ISPR[1]` is always 0. This would map to `SWI2_EGU2_IRQn`. As far, as I can see, I'm using neither the SWI, nor the EGU peripheral.
    I wonder if there is something wrong with the method, I'm using to track down the interrupt, I'm looking for. This is the head of the body of my main loop:
    I'm setting the breakpoint at the body of the for loop. As I see that my collected client is interacting with the GATT server, I'm pretty sure, that delaying the break point works.
    kind regards,
    Torsten
  • This is strange. Do you experience this on a DK or a custom board, and what SDK version are you using? During research I found this post, which suggests removing the softdevice_handler.c file from the project when you encounter this error. Could you try that?
    Simon
  • I'm on a DK (PCA10040 V0.9.0), with some GPIOs and mainly SPIs and Timers in use. From the SDK, only system_nrf52.c, gcc_startup_nrf52.S and the softdevice is in use. SDK Version is 15.2.0_9412b96.
  • Hi Torsten
    I've checked this out with my colleagues, and we would like you to check NVIC->ISER registers as we suspect SWI2 is enabled somewhere, which causes the SWI2_EGU2_IRQn.
    Another solution would be that the application is trying to go to sleep somewhere else than the main.c file. Can you confirm whether or not you are calling a sleep function somewhere else?
    Simon
1 2 3 4 5 »
