Serial comm stops after 8-10h.
I have developed a custom board with NRF52810 (Rigado), a standalone CAN controller (500 kbaud) and serial communication (57600 baud).
The SW is based on the BLE_APP_UART from SDK 15.3.0, SoftDevice S112, modified with SPI support. The custom board is flashed using the nrf52832 DK and Segger.
The NR52810 runs without external LF crystal (RC only).
The CAN controller uses SPI @4MHz and easy DMA. SPI_DEFAULT_CONFIG_IRQ_PRIORITY set to 3 (from default 6).
The serial communication is for receiving 10Hz GPS data.
The data from the SPI and serial comm are served by interrupt service routines (one for SPI and one for serial comm), and the data are put into global static structs.
The CAN data (from SPI) is transmitted over BLE each 40ms and data from the serial comm is transmitted over BLE each 100ms (app_timers reading the global static structs). Approx 100 bytes in each payload.
Everything is running fine for approx. 8-10h.
However, after 8-10h the serial communication stops (does not receive). The CAN/SPI communication and transmit over BLE runs as normal.
Power cycling my custom board does not help. Sometimes a reflash is needed in order to get the serial comm up and running again. Sometimes it is enough to just attach the nrf52832 DKs VDD, GND, SWD IO and SWD CLK pins to the corresponding pins on my custom board.
Any suggestions to why my serial comm stops after 8-10h?
Any suggestions to why power cycling does not result in a clean boot, resetting the serial comm?
  • Are you using any dynamic memory allocation? I'm also developing firmware for a custom board built with the nRF52810. I had an error where after sending 39 packets exactly (using UART), the data being transmitted would remain exactly the same (I.E. packets 0 - 39 had variance, packets 40 - n = packet 39). Realized I had been forgetting to free a PPI instance I allocate at regular intervals, essentially causing segfault or undefined memory overflow behavior. Fixed the bug and application now works fine for as long as I want it to be running.
  • Thanks for the response. No, I am not using any dynamic memory allocation.
    Do you get any error codes in the application when the serial interface stops working? Are you using app_uart_fifo, like it is used in ble_app_uart, or do you use another library/driver for UART?
    Can you provide the state of the registers in the UART(E) peripheral when the device is in the error state? Have you checked the UART lines with a logic analyzer, before and after the issue occurs, to see if there are any changes to the communication between the device?
    Jørgen
  • Thanks for your response.
    UART config as in ble_app_uart using app_uart_fifo:
      static volatile ret_code_t err_code;
        app_uart_comm_params_t static comm_params =
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
        comm_params.baud_rate = useBaudRate;
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    UART event handler:
    //    static uint8_t data_array[BLE_NUS_MAX_DATA_LEN];  //BLE_NUS_MAX_DATA_LEN ~244 bytes
        static uint8_t data_array[128];
        static uint8_t index = 0;
        uint8_t  indexLastReceived = 0;
        uint8_t  status            = _EMPTY;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                UNUSED_VARIABLE(app_uart_get(&data_array[index])); //typecast to void
                indexLastReceived = index;  //save current received
                index++;                    //prepare next char
                if (index >= sizeof(data_array))
                  index=0;
                if (data_array[indexLastReceived] == '\n')
                     //NRF_LOG_DEBUG("GPS data received");
                     index = 0; //prepare next char
                     data_array[indexLastReceived] = '\0'; //replace \n with \0 to make NULL-terminated received msg
                     if (sd_mutex_acquire(&p_GPSmutex)==NRF_SUCCESS) //allocate struct
                        //Read GPS data
                        status = gps_location(&gpsDataReader, data_array); //decode GPS data and parse to the shared static struct gpsDataReader
                        if (status == NMEA_GPGGA)
                            gpsDataUpdated = true;
                            timeoutCounter = 0;
                        sd_mutex_release(&p_GPSmutex);
                     } //end mutex
                } //endif data_array[indexLastUsed]
                //APP_ERROR_HANDLER(p_event->data.error_communication);
                app_uart_flush();
                index = 0;  //=> skip all received chars
                serialCommErrCounter++;
            case APP_UART_FIFO_ERROR:
                //APP_ERROR_HANDLER(p_event->data.error_code);
                app_uart_flush();
    At error events, I (temporarily) call app_uart_flush() instead of the app_error_handler(). When debugging (using ses) with brake point at the app_uart_communication_error, I get to many overruns. I guess it is because the debugger have problems keeping up. The GPS device is continuously pushing data to the serial port (no flow control)...
    Have not verified with a scope yet that the GPS device stops pushing data, but I doubt that.
    Remains to capture the UART(E) registers when the serial comm stops.
  • Alright awesome. I was unaware that I was, but realized initializing a PPI channel allocates memory behind the scenes.
