wake up from sleep mode using NFC not working with softdevice
I want to put my custom board to sleep mode after writing some data through NFC and wake up from sleep through NFC. I have successfully write data through nfc. To wake up from system off mode I have referred https://devzone.nordicsemi.com/f/nordic-q-a/25712/sending-via-nfc-after-nfc-wake-up-on-sd132 and wake_up_nfc example from sdk library. I have used SDK 15.2.0 and softdevice s132 V6.1.0. My custom board went to sleep mode but it didn't  wake up from sleep  when i kept nfc reader(SmartPhone) near to custom board.
my snippet of code as follows. This is not complete code.
void  nfc_init()
   uint32_t  err_code;
    /* Initialize FDS. */
    err_code = ndef_file_setup();
    /* Set up NFC */
    err_code = nfc_t4t_setup(nfc_callback, NULL);
    /* Run Read-Write mode for Type 4 Tag platform */
    err_code = nfc_t4t_ndef_rwpayload_set(m_ndef_msg_buf, sizeof(m_ndef_msg_buf));
    /* Start sensing NFC field */
    err_code = nfc_t4t_emulation_start();
static void initial_setup(void)
	// Initialize.
    uint32_t err_code;
	// Initialize NFC
		nfc_init();
	//read data from fds
	ndef_file_read();
	ble_stack_init();
	gap_params_init();
    timers_init();
    power_management_init();
	advertising_update();
	timers_start();
	// Start execution.
    advertising_start();
main()
initial_setup();
 for (;; )
		if (m_system_off_mode_on)
		m_system_off_mode_on = false;
		// Set NFC as wake up Source
		NRF_NFCT->TASKS_SENSE = 1;
        nrf_delay_ms(100);
        // Enter System OFF mode.
        sd_power_system_off();
    idle_state_handle();
		//	power_manage();
Thanks in Advance
