Command line Make example project for nRF52 DK
I'm trying to build the "blinky" example found in nRF5_SDK_15.3.0_59ac345/examples/peripheral/blinky/pca10040e/blank/armgcc
Actually the pca10040e directory contains 'blank' and 'mbr' directories, I just went with blank but I've no idea what the difference is and which I should be using. I went with 'blank' and tried a 'make' command. Everything compiled but the linker is missing a library. I've installed both the  nRF5_SDK_15.3.0 and s132 packages but searching my machine and there's no occurrences of either libc_nano* or libg_nano. I'm not sure if those libs are target, as in Nordic nRF52 specific or arm specific, in which case they should have been installed with my arm-none-eabi-gcc packages?
/usr/lib64/gcc/arm-none-eabi/7/ld: cannot find -lc_nano
/usr/lib64/gcc/arm-none-eabi/7/ld: cannot find -lg_nano
So should I be making in 'blank' or 'mbr' and where should I install libs from?
    The library should be included in the toolchain. Did you download the toolchain from this site https://developer.arm.com/tools-and-software/open-source-software/developer-tools/gnu-toolchain/gnu-rm/downloads?
    This is how I would set up the toolchain on Linux
    1. Find the recommended toolchain release in the SDK release notes. Is GCC ARM Embedded 7.2018q2.update for SDK 15.3.0
    2. Download the pre-compiled version from ARM and move the extracted toolchain directory to /usr/local/ so it matches the path set in nRF5_SDK_15.3.0_59ac345/components/toolchain/gcc/Makefile.posix
     Use "blank" if you intend to run the app without a bootloader. A typical memory layout with bootloader, app, and MBR would look like this: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/lib_bootloader.html?cp=5_1_3_5_0_7#lib_bootloader_memory
  • Oops, I already have the gcc toolchain for arm installed from the package manager on my linux distro. I'll use the one distributed with the SDK and try that.
    Thanks for your help
  • So I managed to build the blinky project from the command line. And flash it to the target dev board by copying the hex file to the mounted drive. I'll have to come back to that as if I designed by own board that's not how this would work. I have a JLink so I'd have to connect to the JTAG header and user a command line program to flash.
    I'll come back to that but for the moment if I wanted to create a template C project I've now got this script to pull necessary files from the blinky project. My question is that if I wanted instead to create an empty C++ project, what is required. I've tried changing the Makefile.common to specify -std=c++17 instead of -std=c99, and changing to $(CXX) but there's more to it then that as you need the standard library.
    #!/bin/bash
    SDK_ROOT=/home/john/Install/Nordic/nRF5SDK/nRF5_SDK_15.3.0_59ac345
    if [ $# -ne 1 ]; then
        echo "usage: $0 <target>"
        exit 1
    fi
    target=$1
    if [ -f $target ]; then
        echo "Error - Target file exists"
        exit 2
    fi
    if [ -d $target ]; then
        echo "Error - Target directory exists"
        exit 2
    fi
    # Create the target directory
    mkdir -p $target/src
    # Copy in Blinkey Makefile and Makefile.common
    cp $SDK_ROOT/examples/peripheral/blinky/pca10040e/blank/armgcc/Makefile $target
    cp $SDK_ROOT/components/toolchain/gcc/Makefile.common $target
    sed -e "s/blinky_pca10040e/$target/" \
        -e "s;SDK_ROOT := ../../../../../..;SDK_ROOT := $SDK_ROOT;" \
        -e "s;PROJ_DIR := ../../..;PROJ_DIR := .;" \
        -e "s/blinky_gcc_nrf52.ld/gcc_nrf52.ld/" \
        -e 's;(PROJ_DIR);(PROJ_DIR)/src;' \
        -e 's;SDK_CONFIG_FILE := ../config/sdk_config.h;SDK_CONFIG_FILE := sdk_config.h;' \
        -e 's;$(TEMPLATE_PATH)/;;' \
        -e '/..\/config/d' \
        $target/Makefile > $target/Makefile.tmp
    rm $target/Makefile
    mv $target/Makefile.tmp $target/Makefile
    # Copy in the linker script from blinkey project
    cp $SDK_ROOT/examples/peripheral/blinky/pca10040e/blank/armgcc/blinky_gcc_nrf52.ld $target/gcc_nrf52.ld
    # Populate the src directory with the config header file and a main
    cp $SDK_ROOT/examples/peripheral/blinky/pca10040e/blank/config/sdk_config.h $target/src
    echo "int main(int argc, char **argv){}" > $target/src/main.c
  • Our SDK has limited support for C++, unfortunately. I don't have experience with it myself but seen from other forum threads that macros, etc need to be ported in order to be C++ compliant. That said, you can specify the C++ compiler flags by using the CXXFLAGS variable in your project Makefile. It should not be necessary to modify Makefile.common.
