when ble central set BLE_GAP_IO_CAPS_DISPLAY_ONLY ,i find ble central no need to send the static passkey or send one wrong static passkey,ble central can connect ble peripheral ?
so why ?
please help me!
so why ?
please help me!
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "ble_nus.h"
#include "ble_acc.h"
#include "ble_ecg.h"
#include "ble_spo2.h"
#include "ble_cmd.h"
#include "nrf_pwr_mgmt.h"
#include "app_error.h"
#include "ble.h"
#include "ble_srv_common.h"
#include "fds.h"
#include "nrf_drv_clock.h"
#include "ble_dfu.h"
#include "nrf_power.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_bootloader_info.h"
#include "SEGGER_RTT.h"
#include "avc_bluetooth.h"
#include "aco_common.h"
#include "nrf_delay.h"
#include "aco_cache.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 0 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
//about bounded
#define SEC_PARAM_BOND 0 /**< Perform bonding. */
#define SEC_PARAM_MITM 1 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 1 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
static ble_opt_t m_static_pin_option;
TiAppCacheService* ble_cache=NULL;
BLE_CMD_DEF(m_cmd, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE SPO2 service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
#pragma diag_suppress 177
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
{BLE_UUID_ECG_SERVICE, NUS_SERVICE_UUID_TYPE}
TiBleService* m_ble=NULL;
static void advertising_start(bool erase_bonds);
/**@brief Handler for shutdown preparation.
* @details During shutdown procedures, this function will be called at a 1 second interval
* untill the function returns true. When the function returns true, it means that the
* app is ready to reset to DFU mode.
* @param[in] event Power manager event.
* @retval True if shutdown is allowed by this power manager handler, otherwise false.
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_DFU:
SEGGER_RTT_printf(0,"Power management wants to reset to DFU mode.");
// YOUR_JOB: Get ready to reset into DFU mode
// If you aren't finished with any ongoing tasks, return "false" to
// signal to the system that reset is impossible at this stage.
// Here is an example using a variable to delay resetting the device.
// if (!m_ready_for_reset)
// return false;
// else
// // Device ready to enter
// uint32_t err_code;
// err_code = sd_softdevice_disable();
// APP_ERROR_CHECK(err_code);
// err_code = app_timer_stop_all();
// YOUR_JOB: Implement any of the other events available from the power management module:
// -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
// -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
// -NRF_PWR_MGMT_EVT_PREPARE_RESET
return true;
SEGGER_RTT_printf(0,"Power management allowed to reset to DFU mode.");
return true;
//lint -esym(528, m_app_shutdown_handler)
/**@brief Register application shutdown handler with priority 0.
NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
if (state == NRF_SDH_EVT_STATE_DISABLED)
// Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
//Go to system off.
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/* nrf_sdh state observer. */
NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
.handler = buttonless_dfu_sdh_state_observer,
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
* @param[in] event Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
switch (event)
case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
SEGGER_RTT_printf(0,"Device is preparing to enter bootloader mode.");
// YOUR_JOB: Disconnect all bonded devices that currently are connected.
// This is required to receive a service changed indication
// on bootup after a successful (or aborted) Device Firmware Update.
case BLE_DFU_EVT_BOOTLOADER_ENTER:
// YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
// by delaying reset by reporting false in app_shutdown_handler
SEGGER_RTT_printf(0,"Device will enter bootloader mode.");
case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
// YOUR_JOB: Take corrective measures to resolve the issue
// like calling APP_ERROR_CHECK to reset the device.
case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
NRF_LOG_ERROR("Request to send a response to client failed.");
APP_ERROR_CHECK(false);
NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
static void gap_params_init(NamePair* name_pairkey)
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *) name_pairkey->name,
strlen((char*)name_pairkey->name));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
m_static_pin_option.gap_opt.passkey.p_passkey = name_pairkey->pairkey;
err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@snippet [Handling the data received over BLE] */
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_nus Nordic UART Service structure.
* @param[in] p_data Data to be send to UART module.
* @param[in] length Length of the data.
static void cmd_data_handler(ble_cmd_evt_t * p_cmd)
ble_data tem;
if (p_cmd->type == BLE_CMD_EVT_RX_DATA)
if(p_cmd->params.rx_data.length<=240)
tem.data_len=p_cmd->params.rx_data.length;
tem.ble_id=SERVICE_CMD;
memcpy(tem.data,p_cmd->params.rx_data.p_data,tem.data_len);
cache_put(ble_cache,&tem,1);
uint32_t err_code;
ble_cmd_init_t cmd_init;
ble_dfu_buttonless_init_t dfus_init = {0};
#ifdef IsNeedDfu
err_code = ble_dfu_buttonless_async_svci_init();
dfus_init.evt_handler = ble_dfu_evt_handler;
err_code = ble_dfu_buttonless_init(&dfus_init);
// Initialize NUS.
memset(&cmd_init, 0, sizeof(cmd_init));
cmd_init.data_handler = cmd_data_handler;
err_code = ble_cmd_init(&m_cmd, &cmd_init);
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
SEGGER_RTT_printf(0,"BLE_ADV_EVT_FAST.\n");
case BLE_ADV_EVT_IDLE:
void resp_pair_request(){
ble_gap_sec_params_t sec_params;
uint32_t err_code;
memset(&sec_params,0,sizeof(ble_gap_sec_params_t));
sec_params.bond = SEC_PARAM_BOND;
sec_params.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_params.max_key_size = 16;
sec_params.min_key_size = 7;
sec_params.oob = 1;
sec_params.mitm = SEC_PARAM_MITM;
sec_params.kdist_own.enc = 1;
sec_params.kdist_own.id = 1;
sec_params.kdist_peer.enc = 1;
sec_params.kdist_peer.id = 1;
err_code=sd_ble_gap_sec_params_reply(m_conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,NULL);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
SEGGER_RTT_printf(0,"Connected");
ble_gap_sec_params_t params;
params.io_caps = BLE_GAP_IO_CAPS_NONE;
params.oob = 1;
sd_ble_gap_authenticate(m_conn_handle,¶ms);
if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BleConnect);
m_ble->ble_connect_state = BleConnect;
SEGGER_RTT_printf(0,"Disconnected");
if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BleNoConnect);
m_ble->ble_connect_state = BleNoConnect;
SEGGER_RTT_printf(0,"PHY update request.");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
SEGGER_RTT_printf(0,"BLE_GAP_EVT_SEC_PARAMS_REQUEST\n");
resp_pair_request();
case BLE_GATTC_EVT_TIMEOUT:
SEGGER_RTT_printf(0,"BLE_GATTC_EVT_TIMEOUT.");
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GAP_EVT_AUTH_STATUS:
if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS){
m_ble->ble_connect_state = BlePairSuc;
if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BlePairSuc);
SEGGER_RTT_printf(0,"pair is suc\n");
}else{
if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BlePairFaild);
sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
m_ble->ble_connect_state = BlePairFaild;
SEGGER_RTT_printf(0,"pair is faild\n");
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
SEGGER_RTT_printf(0,"Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
SEGGER_RTT_printf(0,"ATT MTU exchange completed. central 0x%x peripheral 0x%x\n",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
void idle_state_handle(void)
// UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
// nrf_pwr_mgmt_run();
SEGGER_RTT_printf(0,"advertising is started\n");
int nodic_ble_send(uint8_t *data,uint16_t data_len,uint8_t service_id)
int value=-1;
uint8_t tem_state=0;
switch(service_id)
case SERVICE_CMD:
tem_state=ble_cmd_data_send(&m_cmd,data,&data_len,m_conn_handle);
if(tem_state==NRF_SUCCESS)
value=1;
else if(tem_state==NRF_ERROR_RESOURCES||tem_state==NRF_ERROR_BUSY || tem_state==NRF_ERROR_INVALID_STATE)
value=0;
value=-1;
return value;
static void BleInit(TiBleService* ble,NamePair* name_pairkey)
timers_init();
power_management_init();
ble_stack_init();
gap_params_init(name_pairkey);
gatt_init();
services_init();
advertising_init();
conn_params_init();
advertising_start(true);
/**@brief Application main function.
TiBleService* ble_open(uint8_t ble_id,BleCallBack callBack,IiTimeAdapter* aco_timer,NamePair* name_pairkey)
nrf_delay_ms(100);
TiBleService* ble=malloc(sizeof(TiBleService));
if(ble)
ble->cache_ble = cache_open(100,sizeof(ble_data));
ble->callBack = callBack;
ble->aco_timer = aco_timer;
ble_cache = ble->cache_ble;
ble->ble_id = ble_id;
BleInit(ble,name_pairkey);
m_ble=ble;
return ble;
void ble_close(TiBleService* ble)
if(ble)
cache_close(ble->cache_ble);
free(ble);
ble=NULL;
void ble_evolve(TiBleService* ble)
if(ble == NULL) return ;
if(ble->ble_connect_state == BleConnect)
ble->aco_timer->read(ble->aco_timer->owner,&ble->BlePairCurTime);
(aco_timer_pre_sub_cur(ble->aco_timer,ble->BlePairPreTime,ble->BlePairCurTime)> BlePairTime) ? sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION):0;
ble->BlePairPreTime = ble->BlePairCurTime;
* Author: shenyancheng
* Date: 2017-09-08
* @brief Function for ble recv.
* @param[out] sdata recv (reference ble_data structure).
* @param[in] ble reference TiBleService structure.
* @param[in] length recv length(ble_data num).
* @return uint8_t real length(ble_data num)
uint8_t nordic_ble_recv(TiBleService* ble,ble_data* sdata,uint8_t length)//RECV
return cache_get(ble->cache_ble,sdata,length);
* Date: 2017-09-08
* @brief Function for ble mac addr.
* @param[out] addr reference ble_gap_addr_t.
* @return void none.
void nordic_ble_get_addr(ble_gap_addr_t* addr)
sd_ble_gap_addr_get(addr);
bool BleUpdatePairKey(uint8_t* PairKey,uint8_t PairKeyLength)
if(PairKey == NULL) return false;
uint32_t err_code=NRF_SUCCESS;
m_static_pin_option.gap_opt.passkey.p_passkey = PairKey;
err_code = sd_ble_opt_set(BLE_GAP_KP_NOT_TYPE_PASSKEY_CLEAR, &m_static_pin_option);
return err_code == NRF_SUCCESS ? true:false;
bool BleUpdateName(uint8_t* name,uint8_t nameLength)
uint32_t err_code = NRF_SUCCESS;
if(name == NULL ) return false;
sd_ble_gap_adv_stop( m_advertising.adv_handle);
err_code = sd_ble_gap_device_name_set(&sec_mode,(const uint8_t *)name, nameLength);
advertising_init();
* Date: 2017-09-08
* @brief Function for disconnect ble.
* @param[in] ble reference TiBleService.
void nordic_ble_disconnect(TiBleService* ble)
if(ble == NULL || m_conn_handle ==BLE_CONN_HANDLE_INVALID) return ;
thie is my ble peripheral code !
You should let the peer manager handle the security events, but you have not initialized it in your code. I'd recommend you to use the ble_app_hrs example as a reference on how to set-up the peer manager in your project.
Also, the following events are handled by the peer manager and should be removed from ble_evt_handler() in main.c
- BLE_GAP_EVT_SEC_PARAMS_REQUEST
- BLE_GATTS_EVT_SYS_ATTR_MISSING
- BLE_GAP_EVT_AUTH_STATUS
Relevant post on how to enable passkey pairing with PM: https://devzone.nordicsemi.com/f/nordic-q-a/39600/static-passkey-implementation-in-central-code
this is only ble peripheral side code.
so no need peer manager module
All of our peripheral examples which support pairing/bonding use the peer manager.
