nrf9160 DK - Issue with building GPS sample
I am currently trying to build the GPS sample from the latest Code Version. I am using SES on a Windows machine. After starting the build process I have got the following error:
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/syscall_macros.h’
Building ‘zephyr/CMakeFiles/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘offsets.c’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/offsets.h’
Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘main.c’
    nrf_socket.h: No such file or directory
Build failed
Checking the SDK source I have found the nrf_socket.h in "nrfxlib\bsdlib\include"
Could you please help!
Thanks!
