BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST write error 0x07 only for a particular range of value
I am trying to write data to the nRF52 module from my custom application. I am sending few parameters bundled into a packet to the module. One of the parameters is the mV (milli volts) which is ranging from -2048 to +2048 (packed into 2 bytes of data). Issue i am having is that only for data between -30 to 0 mV, i am having this error:
<error> app: ERROR 7 [NRF_ERROR_INVALID_PARAM]
This happens at sd_ble_gatts_rw_authorize_reply() function which is returning the above error code. Would you know what can be the cause of it? Why is it not happening over other range of values?
I am using the code from ble app uart example for BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST event
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
    ble_gatts_evt_rw_authorize_request_t  req;
    ble_gatts_rw_authorize_reply_params_t auth_reply;
    req = p_ble_evt->evt.gatts_evt.params.authorize_request;
    if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
        if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
            (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
            (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
            if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
            auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
            err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                       &auth_reply);
} break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
I am using nRF52832 module, SDK v14.2 and SD v5.0 for my development.
Thank you.
    Could you elaborate on the parameters? What is the full range in mV that you are measuring? What other ranges do work? Does -100mV to -31mV work, and what is this equivalent to in bits?
     Can you please show/add more details around this function? How are you passing data to this function? Documentation is found here.
    Thank you!
    Øyvind
