nrfutil UnicodeDecodeError
HI
    when I use nrfutil.exe to generate .zip file on win10 64bit, I got the UnicodeDecodeError.
    And :
         Python version 2.7.9 (default, Dec 10 2014, 12:28:03) [MSC v.1500 64 bit (AMD64)] on win32
        nrfutil version 3.3.2.
        SDK 15.3.0
         the example is "\examples\dfu\secure_bootloader\pca10056_uart"
         I use the command is "nrfutil pkg generate --hw-version 52 --application-version 1 --application nrf52840_xxaa.hex --sd-req 0xae --key-file private.key app_dfu_package.zip"
        but I got the UnicodeDecodeError,the error message is :
C:\packet>nrfutil pkg generate --hw-version 52 --application-version 1 --application nrf52840_xxaa.hex --sd-req 0xae --key-file private.key app_dfu_package.zip
File "nordicsemi\__main__.py", line 871, in <module>
File "site-packages\click\core.py", line 722, in __call__
File "site-packages\click\core.py", line 697, in main
File "site-packages\click\core.py", line 1066, in invoke
File "site-packages\click\core.py", line 895, in invoke
File "site-packages\click\core.py", line 535, in invoke
File "nordicsemi\__main__.py", line 580, in generate
File "nordicsemi\dfu\package.py", line 339, in generate_package
File "nordicsemi\dfu\package.py", line 486, in normalize_firmware_to_bin
File "ntpath.py", line 85, in join
UnicodeDecodeError: 'ascii' codec can't decode byte 0xcd in position 7: ordinal not in range(128)
Failed to execute script __main__
C:\packet>
The "packet" folder only two files : nrf52840_xxaa.hex and private.key
I refer to the Nordic blog :https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader.
How should I solve this problem?
  • I changed the version of nrfutil into 5.2.0(Everything else is the same as before)
    The error message is:
    File "nordicsemi\__main__.py", line 1464, in <module>
    File "click\core.py", line 764, in __call__
    File "click\core.py", line 717, in main
    File "click\core.py", line 1137, in invoke
    File "click\core.py", line 956, in invoke
    File "click\core.py", line 555, in invoke
    File "nordicsemi\__main__.py", line 867, in generate
    File "nordicsemi\dfu\package.py", line 407, in generate_package
    File "nordicsemi\dfu\package.py", line 602, in normalize_firmware_to_bin
    [15032] Failed to execute script __main__
  • Did you install nrfutil using pip or are you using the nrfutil.exe from https://github.com/NordicSemiconductor/pc-nrfutil/releases?
  • I have solved the problem.
    This is the problem with python2.7,it default encoding is ASCII,Change the encoding mode to GBK.
    But I ran into another problem when I was using the DFU USB upgrade.
    I use the command is "nrfutil dfu usb-serial -pkg .\app_dfu_package.zip -p COM8",
    It return "NordicSemiException: Extended Error 0x07: The array of supported SoftDevices for the update does not contain the FWID of the current SoftDevice". But i don`t use softdevice,My application only uses a Master Boot Record (MBR).
    Can you help me how should I solve this problem?
  • Which --sd-req did you set when you generated the app_dfu_package.zip using nrfutil? Try using 0xFFFE.
1 2 3
