Hi, is there a way to upgrade zigbee firmware on a NRF52840, using BLE? Id like to press a button a number of times on a zigbee device and enable BLE to upgrade firmware via DFU.
Hi.
You can take a look at the experimental OTA server example found here.
You have to implement a button press yourself like the one used in SDK 15.3 if you want that, it is not implemented in this example.
Andreas
When trying to do as in the server example:
nrfutil pkg generate --hw-version 52 --sd-req 0x00 --application-version 0x01020101 --application client\pca10056\blank\armgcc\_build\nrf52840_xxaa.hex --key-file priv.pem app_dfu_package.zip --zigbee True --zigbee-manufacturer-id 123 --zigbee-image-type 321 --zigbee-comment good_imag
I get "ModuleNotFoundError: No module named 'constants'"
fixed, I was using python 3
