I am using "asset tracker" project in nRF9160 DK.
I want to update asset tracker application through HTTP.
So i migrated changes of "asset tacker" in main function of "http_application_update" project and added necessary files for gps and accelerometer to the project.
In "prj.conf" file of "http_application_update" project i added following
CONFIG_WATCHDOG=y CONFIG_WDT_NRFX=y CONFIG_NRFX_WDT=y CONFIG_SPI=y CONFIG_SPI_NRFX=y CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8 CONFIG_SPI_3=y CONFIG_SPI_3_NRF_SPIM=y CONFIG_SERIAL=y CONFIG_UART_NRFX=y CONFIG_UART_2_NRF_UARTE=y CONFIG_NEWLIB_LIBC=y
In "nrf9160_pca10090ns.overlay" file of "http_application_update" i added following
&spi3 {
status = "ok";
sck-pin = <13>;
mosi-pin = <11>;
miso-pin = <12>;
spi-max-frequency = <4000000>;
&wdt{
status = "ok";
&uart2 {
status = "ok";
current-speed = <9600>;
tx-pin = <21>;
rx-pin = <22>;
rts-pin = <24>;
cts-pin = <25>;
After adding above changes "http_application_update" project is compiled with no error.
Now i made change to the "spm" project as below
I added following in "prj.conf" file
CONFIG_TRUSTED_EXECUTION_SECURE=y CONFIG_IS_SPM=y CONFIG_SPM_NRF_UARTE2_NS=y
I added following in the "nrf9160_pca10090.overlay" file.
/* needed to get the NRF_UARTE2 defined */
&uart2 {
status = "ok";
tx-pin = <21>;
rx-pin = <22>;
rts-pin = <24>;
cts-pin = <25>;
&spi3 {
status = "ok";
sck-pin = <13>;
mosi-pin = <11>;
miso-pin = <12>;
&wdt{
status = "ok";
After making above changes i compiled "http_application_update" project and programmed the board with "merge.hex" file.
There at power on i am getting following print on UART.
***** Booting Zephyr OS v1.14.99-ncs1 *****<CR><LF> [00:00:00.003,723] <ESC>[0m<inf> mcuboot: Starting bootloader<ESC>[0m<CR><LF> [00:00:00.012,359] <ESC>[0m<inf> mcuboot: Primary image: magic=unset, copy_done=0x3, image_ok=0x3<ESC>[0m<CR><LF> [00:00:00.023,712] <ESC>[0m<inf> mcuboot: Scratch: magic=unset, copy_done=0x50, image_ok=0x3<ESC>[0m<CR><LF> [00:00:00.034,515] <ESC>[0m<inf> mcuboot: Boot source: primary slot<ESC>[0m<CR><LF> [00:00:00.045,684] <ESC>[0m<inf> mcuboot: Swap type: none<ESC>[0m<CR><LF> [00:00:00.473,876] <ESC>[0m<inf> mcuboot: Bootloader chainload address offset: 0xc000<ESC>[0m<CR><LF> [00:00:00.483,856] <ESC>[0m<inf> mcuboot: Jumping to the first image slot<ESC>[0m<CR><LF> ***** Booting Zephyr OS v1.14.99-ncs1 *****<CR><LF> Flash region<HT> <HT> Domain<HT> <HT> Permissions<CR><LF> 00 0x00000 0x08000 <HT> Secure<HT> <HT> rwxl<CR><LF> 01 0x08000 0x10000 <HT> Secure<HT> <HT> rwxl<CR><LF> 02 0x10000 0x18000 <HT> Non-Secure<HT> rwxl<CR><LF> 03 0x18000 0x20000 <HT> Non-Secure<HT> rwxl<CR><LF> 04 0x20000 0x28000 <HT> Non-Secure<HT> rwxl<CR><LF> 05 0x28000 0x30000 <HT> Non-Secure<HT> rwxl<CR><LF> 06 0x30000 0x38000 <HT> Non-Secure<HT> rwxl<CR><LF> 07 0x38000 0x40000 <HT> Non-Secure<HT> rwxl<CR><LF> 08 0x40000 0x48000 <HT> Non-Secure<HT> rwxl<CR><LF> 09 0x48000 0x50000 <HT> Non-Secure<HT> rwxl<CR><LF> 10 0x50000 0x58000 <HT> Non-Secure<HT> rwxl<CR><LF> 11 0x58000 0x60000 <HT> Non-Secure<HT> rwxl<CR><LF> 12 0x60000 0x68000 <HT> Non-Secure<HT> rwxl<CR><LF> 13 0x68000 0x70000 <HT> Non-Secure<HT> rwxl<CR><LF> 14 0x70000 0x78000 <HT> Non-Secure<HT> rwxl<CR><LF> 15 0x78000 0x80000 <HT> Non-Secure<HT> rwxl<CR><LF> 16 0x80000 0x88000 <HT> Non-Secure<HT> rwxl<CR><LF> 17 0x88000 0x90000 <HT> Non-Secure<HT> rwxl<CR><LF> 18 0x90000 0x98000 <HT> Non-Secure<HT> rwxl<CR><LF> 19 0x98000 0xa0000 <HT> Non-Secure<HT> rwxl<CR><LF> 20 0xa0000 0xa8000 <HT> Non-Secure<HT> rwxl<CR><LF> 21 0xa8000 0xb0000 <HT> Non-Secure<HT> rwxl<CR><LF> 22 0xb0000 0xb8000 <HT> Non-Secure<HT> rwxl<CR><LF> 23 0xb8000 0xc0000 <HT> Non-Secure<HT> rwxl<CR><LF> 24 0xc0000 0xc8000 <HT> Non-Secure<HT> rwxl<CR><LF> 25 0xc8000 0xd0000 <HT> Non-Secure<HT> rwxl<CR><LF> 26 0xd0000 0xd8000 <HT> Non-Secure<HT> rwxl<CR><LF> 27 0xd8000 0xe0000 <HT> Non-Secure<HT> rwxl<CR><LF> 28 0xe0000 0xe8000 <HT> Non-Secure<HT> rwxl<CR><LF> 29 0xe8000 0xf0000 <HT> Non-Secure<HT> rwxl<CR><LF> 30 0xf0000 0xf8000 <HT> Non-Secure<HT> rwxl<CR><LF> 31 0xf8000 0x100000 <HT> Non-Secure<HT> rwxl<CR><LF> <CR><LF> SRAM region<HT> <HT> Domain<HT> <HT> Permissions<CR><LF> 00 0x00000 0x02000<HT> Secure<HT> <HT> rwxl<CR><LF> 01 0x02000 0x04000<HT> Secure<HT> <HT> rwxl<CR><LF> 02 0x04000 0x06000<HT> Secure<HT> <HT> rwxl<CR><LF> 03 0x06000 0x08000<HT> Secure<HT> <HT> rwxl<CR><LF> 04 0x08000 0x0a000<HT> Secure<HT> <HT> rwxl<CR><LF> 05 0x0a000 0x0c000<HT> Secure<HT> <HT> rwxl<CR><LF> 06 0x0c000 0x0e000<HT> Secure<HT> <HT> rwxl<CR><LF> 07 0x0e000 0x10000<HT> Secure<HT> <HT> rwxl<CR><LF> 08 0x10000 0x12000<HT> Non-Secure<HT> rwxl<CR><LF> 09 0x12000 0x14000<HT> Non-Secure<HT> rwxl<CR><LF> 10 0x14000 0x16000<HT> Non-Secure<HT> rwxl<CR><LF> 11 0x16000 0x18000<HT> Non-Secure<HT> rwxl<CR><LF> 12 0x18000 0x1a000<HT> Non-Secure<HT> rwxl<CR><LF> 13 0x1a000 0x1c000<HT> Non-Secure<HT> rwxl<CR><LF> 14 0x1c000 0x1e000<HT> Non-Secure<HT> rwxl<CR><LF> 15 0x1e000 0x20000<HT> Non-Secure<HT> rwxl<CR><LF> 16 0x20000 0x22000<HT> Non-Secure<HT> rwxl<CR><LF> 17 0x22000 0x24000<HT> Non-Secure<HT> rwxl<CR><LF> 18 0x24000 0x26000<HT> Non-Secure<HT> rwxl<CR><LF> 19 0x26000 0x28000<HT> Non-Secure<HT> rwxl<CR><LF> 20 0x28000 0x2a000<HT> Non-Secure<HT> rwxl<CR><LF> 21 0x2a000 0x2c000<HT> Non-Secure<HT> rwxl<CR><LF> 22 0x2c000 0x2e000<HT> Non-Secure<HT> rwxl<CR><LF> 23 0x2e000 0x30000<HT> Non-Secure<HT> rwxl<CR><LF> 24 0x30000 0x32000<HT> Non-Secure<HT> rwxl<CR><LF> 25 0x32000 0x34000<HT> Non-Secure<HT> rwxl<CR><LF> 26 0x34000 0x36000<HT> Non-Secure<HT> rwxl<CR><LF> 27 0x36000 0x38000<HT> Non-Secure<HT> rwxl<CR><LF> 28 0x38000 0x3a000<HT> Non-Secure<HT> rwxl<CR><LF> 29 0x3a000 0x3c000<HT> Non-Secure<HT> rwxl<CR><LF> 30 0x3c000 0x3e000<HT> Non-Secure<HT> rwxl<CR><LF> 31 0x3e000 0x40000<HT> Non-Secure<HT> rwxl<CR><LF> <CR><LF> Peripheral<HT> <HT> Domain<HT> <HT> Status<CR><LF> 00 NRF_P0<HT> <HT> Non-Secure<HT> OK<CR><LF> 01 NRF_CLOCK<HT> <HT> Non-Secure<HT> OK<CR><LF> 02 NRF_RTC1<HT> <HT> Non-Secure<HT> OK<CR><LF> 03 NRF_NVMC<HT> <HT> Non-Secure<HT> OK<CR><LF> 04 NRF_UARTE1<HT> <HT> Non-Secure<HT> OK<CR><LF> 05 NRF_UARTE2<HT> <HT> Non-Secure<HT> OK<CR><LF> 06 NRF_IPC<HT> <HT> Non-Secure<HT> OK<CR><LF> 07 NRF_VMC<HT> <HT> Non-Secure<HT> OK<CR><LF> 08 NRF_FPU<HT> <HT> Non-Secure<HT> OK<CR><LF> 09 NRF_EGU1<HT> <HT> Non-Secure<HT> OK<CR><LF> 10 NRF_EGU2<HT> <HT> Non-Secure<HT> OK<CR><LF> 11 NRF_TWIM2<HT> <HT> Non-Secure<HT> OK<CR><LF> 12 NRF_SPIM3<HT> <HT> Non-Secure<HT> OK<CR><LF> 13 NRF_TIMER0<HT> <HT> Non-Secure<HT> OK<CR><LF> 14 NRF_TIMER1<HT> <HT> Non-Secure<HT> OK<CR><LF> 15 NRF_TIMER2<HT> <HT> Non-Secure<HT> OK<CR><LF> 16 NRF_SAADC<HT> <HT> Non-Secure<HT> OK<CR><LF> 17 NRF_GPIOTE1<HT> <HT> Non-Secure<HT> OK<CR><LF> <CR><LF> SPM: NS image at 0x14200<CR><LF> SPM: NS MSP at 0x20026580<CR><LF> SPM: NS reset vector at 0x1e2d9<CR><LF> SPM: prepare to jump to Non-Secure image.<CR><LF> <NUL>
So SPM is not being able to jump to the "asset tracker" application.
can you help me solve the issue ?
Smitesh Mali
