Is there an example of using sd_ble_gattc_write() to do a long write?
I'm assuming I need to use BLE_GATT_OP_PREP_WRITE_REQ and BLE_GATT_OP_EXEC_WRITE_REQ.
devzone.nordicsemi.com/.../a00914.html shows using sd_ble_gattc_write() to do a "GATTC Characteristic or Descriptor Value Long Write", but this MSC isn't present in the 7.1.0 soft device.
I tried just writing the 28 bytes using sd_ble_gattc_write() and got back NRF_ERROR_DATA_SIZE. When I tried to do two BLE_GATT_OP_PREP_WRITE_REQs back to back I got a NRF_ERROR_BUSY on the second write.
Having to wait for the BLE_GATTC_EVT_WRITE_RSP event before doing additional writes is really going to complicate the code.
In this case I'm trying to implement the ANCS get app attributes command that requires writing a null terminated utf-8 string that is pretty much always >20bytes.
I am looking forward to a future softdevice that supports larger MTUs and fragmentation/reassembly, so needing long writes is much less likely.
