Graceful recovery from Bluetooth errors
After long use of BLE communication I sometimes get return code 8 from sd_ble_gatts_hvx.
My questions:
1. This return code is cryptic. Is it associated with defined BLE communication scenarios?
2. What is the graceful way to handle critical error? How can the softdevice be rebooted without rebooting the whole processor?
Daniel
  • This return code is cryptic
    Have you tried looking up its description in the source code?
    Error code 8 is NRF_ERROR_INVALID_STATE. This is returned by sd_ble_gatts_hvx() in these situations (from API doc):
     * @retval ::NRF_ERROR_INVALID_STATE One or more of the following is true:
     *                                   - Invalid Connection State
     *                                   - Notifications and/or indications not enabled in the CCCD
     *                                   - An ATT_MTU exchange is ongoing
    This error likely occurred because of an invalid state in your application (see API doc snippet above), so the first thing you should do is try to avoid this from happening in the first place. Secondly, you can opt to handle the NRF_ERROR_INVALID_STATE by some specific code, instead of using the default error handler which is called when an APP_ERROR_CHECK is called with a value other than NRF_SUCCESS. It could be something like this:
        err_code = sd_ble_gatts_hvx(...);
        if (err_code == NRF_ERROR_INVALID_STATE)
            // Application specific handling of NRF_ERROR_INVALID_STATE
            // Default error check
    It is possible to uninitialize the SoftDevice by first stopping all BLE activity, and then call sd_softdevice_disable(), and then call sd_softdevice_enable() to re-enable it. I do not see any good reason for doing so in this case though.
  • This is returned by sd_ble_gatts_hvx() in these situations
    It is really bad and unhelpful - though all too common - to have a single error code with multiple meanings!
    Disappointed
    A particularly bad example of this is NRF_ERROR_INVALID_PARAM - which neither identifies which parameter is invalid, nor how it is invalid.
    Disappointed
    EDIT
    From only the other week, see:
    devzone.nordicsemi.com/.../192273
  • Einar,
    Thanks for your prompt and elaborated answer.
    I don't understand what an invalid connection state means. It is most likely that the error occurs in some cases when the phone is reconnecting with the nrf52840 device or, maybe when connection is lost in the middle of transmission.
    Can you advise how to overcome this without softdevice disable/enable?
    Thanks again,
    Daniel
    Here "Invalid Connection State" means that the connection is no longer alive. If that is the case, then you should have gotten a BLE_GAP_EVT_DISCONNECTED event before.
    Don't call sd_ble_gatts_hvx() when not connected. It does not make sense and is not allowed.
