Dear Team,
Is it or will it be possible to get an RSSI info like we used to in nRF5?
Best
Oleh
Dear Team,
Best
Oleh
For the GNSS, there is a C/N0 (carrier to noise density, more details here) field:
https://github.com/NordicPlayground/nrfxlib/blob/master/bsdlib/include/nrf_socket.h#L511
For the LTE part, you can get the RSRP (ref. signal received power) through AT command AT+CESQ, where the last number is a reference from -140 dBm. If you get "40", it would indicate -140 + 40 = -100 dBm signal.
Håkon
Hi Håkon,
nice to hearing from you again!
Thanks for the link to nrf_gnss_sv_t struct, it sounds promissing :)
A short confirmation question: will these data be available only with the fix? Or could be accessed even if no fix is (still) available?
... trying to get the RSSI while Position-Reposition the device... in-/out-door...
also, thanks for the AT+CESQ info.
Best regards
Oleh
Hi Oleh,
Likewise!
Without a fix, its not available.
Håkon
Hi Håkon,
thank you for your Reply!
... you know... it would be nice to have that available: just a Feature request ;)
Best regards
Oleh
Hi Håkon,
just a short from the field test...
I get the NMEA sentences without fix, these are not fully filled:
dump_gnss_data_frames > NMEA data
NMEA strings:
$GPGGA,000000.00,,,,,0,,99.99,,M,0,,*37
$GPGGA,000618.00,,,,,0,02,99.99,,M,0,,*3A
$GPGLL,,,,,000618.00,V,A*4A
$GPGLL,,,,,000617.00,V,A*45
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
$GPGSV,1,1,2,6,,,28,7,,,22,1*5D
$GPGSV,1,1,2,6,,,26,7,,,20,1*51
here, for the cn0 especially GPGSV is interesting, as we get sat info.
then I got PositionVelocityTime data:
dump_gnss_data_frames > PVT data
SV:6 cn0:65281 Sig:1 eL:0 Az:0 Flags:0
SV:2 cn0:15873 Sig:3 eL:1 Az:0 Flags:0
SV:4 cn0:2561 Sig:9 eL:1 Az:0 Flags:0
SV:7 cn0:11521 Sig:3 eL:1 Az:0 Flags:0
- Tracking: 4 Using: 0 Unhealthy: 0
Still no fix.... then getting more info:
$GPGSV,2,1,5,6,54,241,29,2,35,302,30,4,68,257,29,7,43,168,29,1*5A
$GPGSV,2,2,5,5,05,298,27,1*57
(so 5 sats)
and finally fix:
SV:6 cn0:10497 Sig:3 eL:13825 Az:-3840 Flags:0
SV:2 cn0:12801 Sig:3 eL:8961 Az:11776 Flags:1
SV:4 cn0:8961 Sig:9 eL:17409 Az:256 Flags:1
SV:7 cn0:10753 Sig:3 eL:11009 Az:-22528 Flags:0
SV:5 cn0:4353 Sig:3 eL:1281 Az:10752 Flags:1
- Tracking: 5 Using: 3 Unhealthy: 0
... so I find this "filling values" good, probably side-effect, but it gives some info even before fix.
Thanks and best
Oleh
