rx_buf size
I am interfacing sim 808 which is a uart based module with my nrf device.
The default buffer size is 256, can i increase this buffer size? If so how?
Also how do I clear my rx_buf?
sometimes while executing the code a file named app_error_weak.c opens and the execution terminates, Why does this happen?
  • What SDK are you using?
    And what modules/drivers are you using for the UART?
    That means your code has hit an error or Hard Fault, and you've reached the error handler.
    The error handler contains a breakpoint, so you IDE stops the execution and shows you the current location - which is in app_error_weak.c
  • nRF5_SDK_15.3.0_59ac345 this is the SDK I am using.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    these are all my included files
  • The list of includes doesn't really help: they could be included but not used; and, as shown some of them are conditional.
    You modules/drivers are you using for the UART ?
    How to properly post source code:
  •  These are the uart libraries used
     These are the drivers
    this the part of code where the size of the buffers are defined
    #define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
              NRF_UART_BAUDRATE_9600
    #else
              NRF_UARTE_BAUDRATE_115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
    but if i try to change the buffer size it opens the error file previously mentioned
