MAX_RT interrupt still happens even if retransmit is off
Dear Nordic,
I met a problem while using nRF24L01+ about MAX_RT interrupt.
In my codes, I disabled RF HW retransmit (hal_nrf_set_auto_retr(0, RF_RETRANS_DELAY);) because I use our software codes to handle retransmit. Therefore, RF should not report "HAL_NRF_MAX_RT" interrupt. However, I still receive "HAL_NRF_MAX_RT" in very rare situations. I saw twice so far for a very long time.
My question is since RF module auto retransmition is off, why does nRF24L01+ still report "HAL_NRF_MAX_RT" interrupt?? Is this nRF24L01+ bug? Or how could I do to get rid of these
MAX_RT interrupt?
  • Hi
    How many packets did you send in that time, when you got 2 or 3 packets with MAX_RT?
    I have put up a small test and will leave it over the weekend, to see if I can record any MAX_RT interrupts. So far I have sent over 15000 packets and I have only seen TX_DS interrupts.
    I do have one question, why the 0x1C and 0x1D registers are set?
    These features don't work when ACK's are disabled, and are usually set to 0 in this case.
    Best regards
    Torbjørn
  • > How many packets did you send in that time, when you got 2 or 3 packets with MAX_RT?
    When MAX_RT happens, RF is sending packet every 250ms, i.e., 4 packets every 1 second  for reporting a periodically information. The period is lasting for about 1 ~ 2 hours.
    I just adopt the sample codes of dynamic payload, and Nordic sample codes change 0x1C and 0x1D registers in `radio_pl.c`. Copy the codes as follows:
    * Changed from esb/radio_esb.c *
    * Enables: *
    * - ACK payload *
    * - Dynamic payload width *
    * - Dynamic ACK *
    hal_nrf_enable_ack_pl(); // Try to enable ack payload
    // When the features are locked, the FEATURE and DYNPD are read out 0x00
    // even after we have tried to enable ack payload. This mean that we need to
    // activate the features.
    if(hal_nrf_read_reg(FEATURE) == 0x00 && (hal_nrf_read_reg(DYNPD) == 0x00))
    hal_nrf_lock_unlock (); // Activate features
    hal_nrf_enable_ack_pl(); // Enables payload in ack
    hal_nrf_enable_dynamic_pl(); // Enables dynamic payload
    hal_nrf_setup_dyn_pl(ALL_PIPES); // Sets up dynamic payload on
  • Hi
    This might explain the problem. Using features like ACK payload, dynamic payload length or dynamic ACK are not compatible with clearing the EN_AA register (ie disabling ACK's).
    Either you have to enable ACK's through the EN_AA register and use these features, or you have to disable these features completely.
    If you want to disable ACK's while using the dynamic payload length feature you should enable ACK in the EN_AA register and enable the dynamic ACK feature, so that you can send packet without ACK even if EN_AA is enabled.
    I did some testing on my own, and after a million packets I don't see a single MAX_RT interrupt occur, but in my testing I didn't enable ack payload and dynamic payload length.
    Best regards
    Torbjørn
  • If you want to disable ACK's while using the dynamic payload length feature you should enable ACK in the EN_AA register and enable the dynamic ACK feature, so that you can send packet without ACK even if EN_AA is enabled
    Based on your comments, so my codes need to change as follows, right? (Please help to confirm).
      hal_nrf_open_pipe(HAL_NRF_PIPE0, true);  // Then open pipe0, w/autoack  -> Harry: enable EN_AA Ack
      // hal_nrf_enable_ack_pl(); // Try to enable ack payload -> Harry: comment out two lines of these codes
    However, I have one question. Since I don't want ACK, why can I disable EN_AA as well, i.e.,
      hal_nrf_open_pipe(HAL_NRF_PIPE0, false);
  • Hi
    Do you need dynamic payload length or not?
    If you don't need dynamic payload length you can just run hal_nrf_open_pipe(HAL_NRF_PIPE0, false), and make sure not to run hal_nrf_enable_ack_pl(), hal_nrf_enable_ack_pl(), hal_nrf_enable_dynamic_pl() or hal_nrf_setup_dyn_pl(ALL_PIPES).
    If you need dynamic payload length the only way to achieve this is to run hal_nrf_open_pipe(HAL_NRF_PIPE0, true), hal_nrf_setup_dyn_pl(ALL_PIPES) and hal_nrf_enable_dynamic_pl().
    The reason for this is that enabling the pipe with EN_AA = 0 removes the 9 bit PCF field in the payload which is used to support the dynamic payload length, ACK payload and dynamic ACK features.
    In the documentation this might be referred to as either Shockburst mode (EN_AA = 0), or Enhanced Shockburst mode (EN_AA = 1).
    Best regards
    Torbjørn
