MAX_RT interrupt still happens even if retransmit is off
Dear Nordic,
I met a problem while using nRF24L01+ about MAX_RT interrupt.
In my codes, I disabled RF HW retransmit (hal_nrf_set_auto_retr(0, RF_RETRANS_DELAY);) because I use our software codes to handle retransmit. Therefore, RF should not report "HAL_NRF_MAX_RT" interrupt. However, I still receive "HAL_NRF_MAX_RT" in very rare situations. I saw twice so far for a very long time.
My question is since RF module auto retransmition is off, why does nRF24L01+ still report "HAL_NRF_MAX_RT" interrupt?? Is this nRF24L01+ bug? Or how could I do to get rid of these
MAX_RT interrupt?
  • Yes, I need dynamic payload length.
    Therefore, my codes will call
    * run hal_nrf_open_pipe(HAL_NRF_PIPE0, true),
    * hal_nrf_setup_dyn_pl(ALL_PIPES)
    * hal_nrf_enable_dynamic_pl().
    and will NOT call (comment out)
    * hal_nrf_enable_ack_pl();
    Got it. thank you very much.
  • Hi
    That sounds good.
    If you have any more problems just let me know Slight smile
    Best regards
    Torbjørn
  • Hi Torbjorn,
    I follow your comments, but RF does not produce any TX_DS interrupt event anymore. The whole system cannot work.
    I just copy my codes below (remove all comments to save space). Could you please help to check what's matter.
    void radio_pl_init (uint8_t *address, hal_nrf_operation_mode_t operational_mode,
    uint8_t rfChannel, hal_nrf_datarate_t airRate)
    hal_nrf_close_pipe(HAL_NRF_ALL);
    hal_nrf_open_pipe(HAL_NRF_PIPE0, true);
    hal_nrf_set_crc_mode(HAL_NRF_CRC_16BIT);
    hal_nrf_set_address_width(HAL_NRF_AW_5BYTES);
    hal_nrf_set_address(HAL_NRF_TX, address);
    hal_nrf_set_address(HAL_NRF_PIPE0, address);
    //hal_nrf_enable_ack_pl(); // Try to enable ack payload
    if(hal_nrf_read_reg(FEATURE) == 0x00 && (hal_nrf_read_reg(DYNPD) == 0x00))
    hal_nrf_lock_unlock (); // Activate features
    //hal_nrf_enable_ack_pl(); // Enables payload in ack
    hal_nrf_enable_dynamic_pl();
    hal_nrf_setup_dyn_pl(ALL_PIPES);
    if(operational_mode == HAL_NRF_PTX)
    hal_nrf_set_operation_mode(HAL_NRF_PTX);
    hal_nrf_set_operation_mode(HAL_NRF_PRX);
    // Disable this. Use dynamic payload, so no need to set the fixed payload length.
    //hal_nrf_set_rx_pload_width((uint8_t)HAL_NRF_PIPE0, RF_PAYLOAD_LENGTH);
    hal_nrf_set_rf_channel(rfChannel);
    hal_nrf_set_power_mode(HAL_NRF_PWR_UP);
    hal_nrf_set_datarate(airRate);
    start_timer(RF_POWER_UP_DELAY);
    wait_for_timer();
    //radio_set_status (RF_IDLE);
  • Hi
    Are you able to send me the implementation of the hal_nrf_enable_dynamic_pl() function?
    In my version of the HAL library this function needs to be provided a bool argument, allowing you to enable or disable the feature.
    I realize now that I forgot to mention that you have to call  hal_nrf_enable_dynamic_ack(true) also if you want to use the noack feature.
    Below is my own test code to verify that this is working:
    hal_nrf_set_operation_mode((config->mode == APP_RADIO_MODE_PTX) ? HAL_NRF_PTX : HAL_NRF_PRX);
    nrf_delay_us(1500);
    hal_nrf_set_auto_retr(0, 500);
    hal_nrf_set_address_width(5);
    hal_nrf_setup_dynamic_payload(0x3F);
    hal_nrf_enable_dynamic_payload(true);
    hal_nrf_enable_dynamic_ack(true);
    hal_nrf_set_datarate(HAL_NRF_2MBPS);
    hal_nrf_set_rf_channel(2);
    if(config->mode == APP_RADIO_MODE_PTX)
      hal_nrf_flush_tx();
      hal_nrf_flush_rx();
      hal_nrf_set_rx_payload_width(HAL_NRF_PIPE0, 8);
    And then I send my packets using the hal_nrf_write_tx_payload_noack(..) function, which removes the ACK requirement from the packet.
    Best regards
    Torbjørn
  • Are you able to send me the implementation of the hal_nrf_enable_dynamic_pl() function?
    Here you are.
    void hal_nrf_enable_dynamic_pl(void)
    hal_nrf_write_reg(FEATURE, (hal_nrf_read_reg(FEATURE) | 0x04));
    void hal_nrf_disable_dynamic_pl(void)
    hal_nrf_write_reg(FEATURE, (hal_nrf_read_reg(FEATURE) & ~0x04));
