I'm in trouble because I can't get my expected Logs in WireShark with nRF51822.
[Enviroment]
・I use "User Guide v2.2" and I installed according to this document.
・My PC is Win10.
・Paring way is "Just Work"
・The distance from tablet(OS = android) and BLE device is less than 5cm.
(nRF51822 is located between tablet and BLE machine, 3 devices are very near )
[Case in Detail]
Tablet and BLE device can be connected each other.
And tablet can get the data from the BLE device.
But I cannot get my expected logs.
In this process, the follwing ATT logs should be seen in WireShark.
Only No1 Log can be seen, there are no another (No2 ~No6) logs.
(1) Master Read Request ← only this log can be seen.
(2) Slave Read Response
(3) Master Write Request
(4) Slave Write Response
(5) Master Indicate Request
(6) Slave Indicate Response
[sample Log In WireShark]
I'll show you a part of logs below.
in Line 4 , this Master Log stands for "Read Request".
<WireShark Log>
Master_0x1b5a5142 Control Opcode: LL_VERSION_IND
Slave_0x1b5a5142 Control Opcode: LL_FEATURE_RSP
Master_0x1b5a5142 Control Opcode: LL_CONNECTION_UPDATE_REQ
Master_0x1b5a5142 Sent Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
Slave_0x1b5a5142 Rcvd Exchange MTU Request, Client Rx MTU: 240
Slave_0x1b5a5142 L2CAP Fragment Start
Master_0x1b5a5142 Control Opcode: Unknown
[Question]
(1) Why can't I get the Log ?
I have read many website about this issue, but I cannot get any information to solve.
please show me reason and solution.
If you need more information don't hesitate asking to me.
I'll send you information and Logs and so on you need.
(2) In fact, I have one more trouble related with this log problem.
As is often the case with me, I cannot get any ATT Protocol logs even Master Read Request Log.
there are many "bad MIC" logs.
Why is it occured ?
I've tried the same way as I had gotton the log including "Master Read Request".
In most case, it's occured.
Sometime, I've been able to get the "Master Read Request" Log.
<WireShark Log>
Slave_0x129360ad Control Opcode: LL_VERSION_IND
Master_0x129360ad Control Opcode: LL_FEATURE_REQ
Master_0x129360ad Control Opcode: LL_VERSION_IND
Slave_0x129360ad Control Opcode: LL_FEATURE_RSP
Slave_0x129360ad Control Opcode: LL_ENC_RSP
Slave_0x129360ad Control Opcode: LL_START_ENC_REQ
Slave_0x129360ad Encrypted packet decrypted incorrectly (bad MIC)
Master_0x129360ad Encrypted packet decrypted incorrectly (bad MIC)
[Finally]
I'm really appreciate for your reading my question.
I hope your reply.
I'm looking forward to get the expected Logs.
