Keil - Debugger set two breakpoints at same address
I'm getting started with the ble_app_hrs_s110_pca10028 (nRF51 PCA10028) example in the nRF51_SDK_7.1.0_372d17a_packs.zip SDK. See the tags for my hardware setup. I'm using Keil version 5.11 (5.12 download was corrupt last I checked).
If I set a breakpoint at line 631 in main.c (inside the BLE Event connected handler), Keil breaks at that point. However, when I click Step Over, I get this error:
"Debugger problem discovered: The debugger has set two breakpoints at the same addess 0x00019F7A"
Anyone else run into this? Is this a bad place to put a breakpoint? Is Keil confused by the next line being a macro? This is after I turned optimization off -O0.
