fds_record_update write the flash in a random way
I'm having an issue about the FDS. Indeed, i want to update some structures already saved in flash so i call the following function : fds_record_update. I can see the event FDS_EVT_UPDATE that passes through my handler. I reset my device a few seconds after having updated the flash but sometime my data seems to be not registered as it should be whereas other time all is working fine.
I don't know what i'm missing. I try to save a value just before reseting. To do that, i call system_reset, here is my code :
void system_reset(eRESET_ID reset_id, uint32_t timeout_ms) {
    uint32_t err_code;
    uint8_t _reset_id = (uint8_t)reset_id;
    NRF_LOG_INFO("");
    NRF_LOG_INFO("*** System reset asked in %d ms ***",timeout_ms);
    NRF_LOG_INFO("\r\n");
    // Check reset_id before reseting
    if (reset_id < RESET_ID_NUMBER) {
        ret_code_t ret = update_PERIPH_CFG(ID_RESET_ID,&_reset_id);
        if (timeout_ms == 0) {
            // Reset immediatly
            NVIC_SystemReset();
        else {
            // Reset in the timer callback
            err_code = app_timer_start(reset_timer,APP_TIMER_TICKS(timeout_ms),NULL);
ret_code_t update_PERIPH_CFG(int target_data, void * data)
    fds_record_desc_t desc = {0};
    fds_find_token_t  tok  = {0};
    ret_code_t rc;
    int time_out = 0;
    if (fds_record_find(ACTIVATED_CFG_FILE, ACTIVATED_CFG_REC_KEY, &desc, &tok) == FDS_SUCCESS)
        // modication is possible here/
        switch ( target_data )
            case ID_ADHERENCE_SENSOR: //Activated adherence sensor
                periph_cfg.adherence_activated = *((bool *)data);
                NRF_LOG_INFO("save:%d",periph_cfg.adherence_activated);
            case ID_ALS_MAX44009:  //Activated ALS
                periph_cfg.ALS_MAX44009_activated = *((bool *)data);
            case ID_CLEAR_STATE:
                //periph_cfg.clear_state_of_lens = *((uint8_t *)data);
                memcpy(&periph_cfg.clear_state_of_lens,data,sizeof(periph_cfg.clear_state_of_lens));
            case ID_RST_NUMB_WTH_BT:
                //periph_cfg.ResetNumberWithButton = *((uint8_t *)data);
                memcpy(&periph_cfg.ResetNumberWithButton,data,sizeof(periph_cfg.ResetNumberWithButton));
            case ID_RESET_ID:
                //periph_cfg.reset_id = *((uint8_t *)data);
                memcpy(&periph_cfg.reset_id,data,sizeof(periph_cfg.reset_id));
        // Write the updated record to flash.
        do
            rc = fds_record_update(&desc, &m_periph_cfg);
            time_out++;
        } while ((rc != FDS_SUCCESS) && (time_out < 10));
        //APP_ERROR_CHECK(rc);
        fds_gc();
        return rc;
        return FDS_ERR_NOT_FOUND;
At startup i try to get the same structure and sometime the value has not been saved as it should be ...
If you have any idea feel free to share.
Aurélien
