Unable to run apps; debug stops at "SPM: prepare to jump into Non-Secure image".
I did have a working development board.  I was working to disable serial and disable as much as possible to get the power usage down.  It seemed to be working (although I did not have debug but I could watch the board usage in my Otii).  Now I have performed an update of the development tools after the release of the latest firmware in May.  I can build the new sample applications and SPM, they seem to work but I still have no debug output.  I'm sure I have 'undone' everything I did to disable the serial debug, but my applications don't output debug text.
When I reset the board I can see the SPM lines, but then nothing after that.
What am I doing wrong, and how can I get my debug back?
This is all I get:
***** Booting Zephyr OS v1.14.99-ncs1-3-g3c4f27282002 *****
Flash region            Domain          Permissions
00 0x00000 0x08000      Secure          rwxl
01 0x08000 0x10000      Secure          rwxl
02 0x10000 0x18000      Secure          rwxl
03 0x18000 0x20000      Secure          rwxl
04 0x20000 0x28000      Secure          rwxl
05 0x28000 0x30000      Secure          rwxl
06 0x30000 0x38000      Secure          rwxl
07 0x38000 0x40000      Non-Secure      rwxl
08 0x40000 0x48000      Non-Secure      rwxl
09 0x48000 0x50000      Non-Secure      rwxl
10 0x50000 0x58000      Non-Secure      rwxl
11 0x58000 0x60000      Non-Secure      rwxl
12 0x60000 0x68000      Non-Secure      rwxl
13 0x68000 0x70000      Non-Secure      rwxl
14 0x70000 0x78000      Non-Secure      rwxl
15 0x78000 0x80000      Non-Secure      rwxl
16 0x80000 0x88000      Non-Secure      rwxl
17 0x88000 0x90000      Non-Secure      rwxl
18 0x90000 0x98000      Non-Secure      rwxl
19 0x98000 0xa0000      Non-Secure      rwxl
20 0xa0000 0xa8000      Non-Secure      rwxl
21 0xa8000 0xb0000      Non-Secure      rwxl
22 0xb0000 0xb8000      Non-Secure      rwxl
23 0xb8000 0xc0000      Non-Secure      rwxl
24 0xc0000 0xc8000      Non-Secure      rwxl
25 0xc8000 0xd0000      Non-Secure      rwxl
26 0xd0000 0xd8000      Non-Secure      rwxl
27 0xd8000 0xe0000      Non-Secure      rwxl
28 0xe0000 0xe8000      Non-Secure      rwxl
29 0xe8000 0xf0000      Non-Secure      rwxl
30 0xf0000 0xf8000      Non-Secure      rwxl
31 0xf8000 0x100000     Non-Secure      rwxl
SRAM region             Domain          Permissions
00 0x00000 0x02000      Secure          rwxl
01 0x02000 0x04000      Secure          rwxl
02 0x04000 0x06000      Secure          rwxl
03 0x06000 0x08000      Secure          rwxl
04 0x08000 0x0a000      Secure          rwxl
05 0x0a000 0x0c000      Secure          rwxl
06 0x0c000 0x0e000      Secure          rwxl
07 0x0e000 0x10000      Secure          rwxl
08 0x10000 0x12000      Non-Secure      rwxl
09 0x12000 0x14000      Non-Secure      rwxl
10 0x14000 0x16000      Non-Secure      rwxl
11 0x16000 0x18000      Non-Secure      rwxl
12 0x18000 0x1a000      Non-Secure      rwxl
13 0x1a000 0x1c000      Non-Secure      rwxl
14 0x1c000 0x1e000      Non-Secure      rwxl
15 0x1e000 0x20000      Non-Secure      rwxl
16 0x20000 0x22000      Non-Secure      rwxl
17 0x22000 0x24000      Non-Secure      rwxl
18 0x24000 0x26000      Non-Secure      rwxl
19 0x26000 0x28000      Non-Secure      rwxl
20 0x28000 0x2a000      Non-Secure      rwxl
21 0x2a000 0x2c000      Non-Secure      rwxl
22 0x2c000 0x2e000      Non-Secure      rwxl
23 0x2e000 0x30000      Non-Secure      rwxl
24 0x30000 0x32000      Non-Secure      rwxl
25 0x32000 0x34000      Non-Secure      rwxl
26 0x34000 0x36000      Non-Secure      rwxl
27 0x36000 0x38000      Non-Secure      rwxl
28 0x38000 0x3a000      Non-Secure      rwxl
29 0x3a000 0x3c000      Non-Secure      rwxl
30 0x3c000 0x3e000      Non-Secure      rwxl
31 0x3e000 0x40000      Non-Secure      rwxl
Peripheral              Domain          Status
00 NRF_P0               Non-Secure      OK
01 NRF_CLOCK            Non-Secure      OK
02 NRF_RTC1             Non-Secure      OK
03 NRF_NVMC             Non-Secure      OK
04 NRF_UARTE1           Non-Secure      OK
05 NRF_UARTE2           Non-Secure      OK
06 NRF_IPC              Non-Secure      OK
07 NRF_VMC              Non-Secure      OK
08 NRF_FPU              Non-Secure      OK
09 NRF_EGU1             Non-Secure      OK
10 NRF_EGU2             Non-Secure      OK
11 NRF_TWIM2            Non-Secure      OK
12 NRF_SPIM3            Non-Secure      OK
13 NRF_TIMER0           Non-Secure      OK
14 NRF_TIMER1           Non-Secure      OK
15 NRF_TIMER2           Non-Secure      OK
16 NRF_SAADC            Non-Secure      OK
17 NRF_GPIOTE1          Non-Secure      OK
SPM: NS image at 0x40000
SPM: NS MSP at 0x20020958
SPM: NS reset vector at 0x4126d
SPM: prepare to jump to Non-Secure image.
    Are you sure you didn't succeed in disabling serial in your application? Have you tried debugging to see where, or if, you're stuck in firmware? How does your prj.conf look like?
    What happens if you run any other sample, like simple_mqtt / at_client or similar?
    Håkon
  • Hi,  This is a new application.  I have tried the GPS, simple_mqtt and another app I can't think of.  They compile and go onto the board, but I see no serial.  I haven't changed the proj.conf files apart from to add "CONFIG_SERIAL=y" when I saw nothing from the board.
    I'm really confused!  And it's stopping me doing any work with the board now..
  • This could be due to the "merged.hex" - where the spm (previously named secure_boot) assumes that the application resides from 0x8000 and upwards. Or the other way around in this scenario; your spm assumes that the application is on 0x40000, while the application is flashed from 0x8000.
    The current SES for NCS v4.16 does not handle these merged projects very well, but will do this when v4.17 comes out.
    If you go into your build folder in cmd.exe, and write "ninja flash", do you then get a merged.hex file that will be flashed onto your device?
    Håkon
  • Aha!  I have a working application!  So I can't use Segger for deploying onto my board until it's updated?
