Dears,
I am using DK PCA10028 (V1.2.2). Start developing from SDK_12.3.0\examples\ble_peripheral\experimental_ble_app_blinky.
All system configuration keep the same (ADC interrupt priority is 3).
After add ADC sampling by soft-timer event to sample 8 channels ADC0~ADC7 every 1000 ms.
Whenever BLE connected, system soon turn to dis-connected. The return dis-connected reason is 0x08 (BLE_HCI_CONNECTION_TIMEOUT)
static void adc_config(void)
ret_code_t ret_code;
nrf_drv_adc_config_t config = NRF_DRV_ADC_DEFAULT_CONFIG;
ret_code = nrf_drv_adc_init(&config, adc_event_handler);
APP_ERROR_CHECK(ret_code);
nrf_drv_adc_channel_enable(&m_channel_config0);
nrf_drv_adc_channel_enable(&m_channel_config1);
nrf_drv_adc_channel_enable(&m_channel_config2);
nrf_drv_adc_channel_enable(&m_channel_config3);
nrf_drv_adc_channel_enable(&m_channel_config4);
nrf_drv_adc_channel_enable(&m_channel_config5);
nrf_drv_adc_channel_enable(&m_channel_config6);
nrf_drv_adc_channel_enable(&m_channel_config7);
I've try to change CONN_SUP_TIMEOUT from MSEC_TO_UNITS(4000, UNIT_10_MS) to BLE_GAP_CP_CONN_SUP_TIMEOUT_MAX , or increase MAX_CONN_INTERVAL still disconnected.
The only way I can make system keep connected is NOT to sample 8 channels, only sample 1 channel is fine (But if set to 2 channels, system still disconnected soon after connected)
Is there any way or what parameter setting to make system keep BLE connected with 8 channels ADC sampling?
