pc-ble-driver-py recipe for installing it on yocto
I am trying to install pc-ble-driver-py pypi lib into custom yocto setup. I have created recipes for it which is shown bellow
in python-pc-ble-driver-py.inc
SUMMARY = "Socket.IO integration for Flask applications"
DESCRIPTION = "A Python interface and library for pc-ble-driver. \
This allows Python applications to interface with a Nordic Semiconductor IC \
(both nRF51 and nRF52 series) over a serial port to obtain access to the full \
 serialized SoftDevice API"
HOMEPAGE = "https://github.com/NordicSemiconductor/pc-ble-driver-py"
LICENSE = "Modified BSD License"
LIC_FILES_CHKSUM = "file://README.rst;md5=0ee5c22181e071c7757e8bbf5732b8c4"
DISTUTILS_INSTALL_ARGS += " install"
SRC_URI = "https://files.pythonhosted.org/packages/70/cb/0c6c2ac9d5679a83a259ab52c580c219d188ae02bde64be27b75663a6889/pc_ble_driver_py-0.10.0.tar.gz"
SRC_URI[md5sum] = "bd3f2901cb976f02f4633af575be571e"
SRC_URI[sha256sum] = "1fdf6a0ec970e070c8e9bc92d40e986beb375c456749b57767007a9cabb3fccd"
CLEANBROKEN = "1"
PYPI_PACKAGE = "pc-ble-driver-py"
and in python-pc-ble-driver-py_0.10.0.bb
inherit pypi setuptools
require python-pc-ble-driver-py.inc
and while compile the yocto image I get such error.
ERROR: python-pc-ble-driver-py-0.10.0-r0 do_compile: python setup.py build execution failed.
ERROR: python-pc-ble-driver-py-0.10.0-r0 do_compile: Function failed: do_compile (log file is located at /home/user/projects/optart/esl/gateway/yocto/build/tmp/work/cortexa7hf-neon-vfpv4-phytec-linux-gnueabi/python-pc-ble-driver-py/0.10.0-r0/temp/log.do_compile.956)
ERROR: Logfile of failure stored in: /home/user/projects/optart/esl/gateway/yocto/build/tmp/work/cortexa7hf-neon-vfpv4-phytec-linux-gnueabi/python-pc-ble-driver-py/0.10.0-r0/temp/log.do_compile.956
Log data follows:
| DEBUG: Executing shell function do_compile
| ERROR: python setup.py build execution failed.
| /home/user/projects/optart/esl/gateway/yocto/build/tmp/sysroots/x86_64-linux/usr/bin/python-native/python: can't open file 'setup.py': [Errno 2] No such file or directory
| ERROR: Function failed: do_compile (log file is located at /home/user/projects/optart/esl/gateway/yocto/build/tmp/work/cortexa7hf-neon-vfpv4-phytec-linux-gnueabi/python-pc-ble-driver-py/0.10.0-r0/temp/log.do_compile.956)
ERROR: Task (/home/user/projects/optart/esl/gateway/yocto/sources/poky/../meta-openembedded/meta-python/recipes-devtools/python/python-pc-ble-driver-py_0.10.0.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2640 tasks of which 2639 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
No currently running tasks (2376 of 3693) 64% |############################################################# |
error: pathspec 'bitbake.lock' did not match any file(s) known to git.
error: pathspec 'gateway' did not match any file(s) known to git.
Summary: 1 task failed:
Summary: There were 6 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
I am able to install other python library with same method but having issue in pc-ble-driver-py lib
Is there any way to resolve such errors.
P.S. I tried latest 0.12.0 version first and it also had the same error. So i tried some older versions as well.
