nrf52832 how to increase duty cycle to 98%
Hi Team,
Currently we are working with nrf52832 in one of our project and now we are going through FCC for the same. I am using radio tool code(SDK 15.3) to generate the FCC images for different channels. I am able to generate waveforms when i am using radio_modulated_tx_carrier() function. But in the testing we have observed that, with these we are able to achieve only 25% duty cycle. To increase the duty cycle, i have used radio_modulated_tx_carrier_duty_cycle() function, but after introducing this function i am not seeing wave forms in the spectrum. following is the code snippet
while (true){
uint8_t txpower_ = RADIO_TXPOWER_TXPOWER_Pos4dBm;
uint8_t mode_ = RADIO_MODE_MODE_Ble_1Mbit;
uint8_t channel_start_ = 40;
uint8_t duty_cycle = 98;
radio_modulated_tx_carrier_duty_cycle(txpower_,
mode_,
channel_start_,
duty_cycle);
Kindly let us know how to increase the duty cycle to 98%.
    If you look inside the radio_modulated_tx_carrier_duty_cycle() you will see that the first thing it does is disable the radio (if it is running), so if you loop it you will just mess it up. Call it once, it uses a timer to loop itself, then call __WFE(), in the while loop:
    mode_,
    channel_start_,
    duty_cycle);
    while (true){
        __WFE();
    Andreas
  • Hi Andreas,
    If we use the radio_modulated_tx_carrier_duty_cycle() function,we are unable to see the any signal in Spectrum analyzer but if we use the radio_modulated_tx_carrier() function we are able to see the BLE signal on Spectrum Analyzer,
    Please comment on  radio_modulated_tx_carrier_duty_cycle() function. what function we can use to increase Duty cycle.
    radio_modulated_tx_carrier_duty_cycle ( or) radio_modulated_tx_carrier
    Ramesh
    Timer0_IRQ might not be enabled, try this for your main file:
     * Copyright (c) 2014-2018 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup nrf_radio_test_example_main main.c
     * @ingroup nrf_radio_test_example
     * @brief Radio Test Example application main file.
     * This file contains the source code for a sample application that uses the NRF_RADIO and is controlled through the serial port.
    #include <stdint.h>
    #include <stdbool.h>
    #include <stdio.h>
    #include "bsp.h"
    #include "nrf.h"
    #include "radio_test.h"
    #include "nordic_common.h"
    static uint8_t packet[256];
    static uint8_t mode_          = RADIO_MODE_MODE_Ble_1Mbit;
    static uint8_t txpower_       = RADIO_TXPOWER_TXPOWER_0dBm;
    static int channel_start_     = 40;
    /** @brief Function for configuring all peripherals used in this example.
    static void init(void)
        NRF_RNG->TASKS_START = 1;
    #ifndef NRF52810_XXAA
        NRF_NVMC->ICACHECNF  = NVMC_ICACHECNF_CACHEEN_Enabled << NVMC_ICACHECNF_CACHEEN_Pos;
    #endif // NRF52810_XXAA
        // Start 64 MHz crystal oscillator.
        NRF_CLOCK->TASKS_HFCLKSTART    = 1;
        // Wait for the external oscillator to start up.
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
            // Do nothing.
    /** @brief Function for the main application entry.
        init();
        NVIC_ClearPendingIRQ(TIMER0_IRQn);
        NVIC_EnableIRQ(TIMER0_IRQn);
        radio_modulated_tx_carrier_duty_cycle(txpower_, mode_, channel_start_, 98);
        while (true)
            __WFE();
    Andreas
  • Thanks Andreas for your Reply...
    we are seeing only 50% duty cycle with below function in Spectrum Analyzer,But we are passing parameter duty_cycle as 98.
    Please Let me know, how we can achieve to get exact 98% duty cycle.
    Ramesh
