GPS/LTE_M/NB-IoT nRF91
Dear,
I am using :
ncs: v0.4.0
SES 4.16
firmware: mfwnrf916007029alpha
Hardware: nRF9160 DK v: 0.8.5
I want to do:
1. Enable and get GPS position ("AT\%XSYSTEMMODE=0,0,1,0") and data from BMP280 sensor  --> store it in data_pack
2. Turnoff GPS and Enable LTE_M: ("AT\%XSYSTEMMODE=1,0,0,0") & use HTTP POST to post data_pack to my webserver
3. Switch to NB-IoT: ("AT\%XSYSTEMMODE=0,1,0,0") & use HTTP POST to post data_pack to my webserver
Is it posiblie to do like that now?
I know: "The current modem firmware, v0.7.0-29-alpha, allows you to choose the system mode via command %XSYSTEMMODE, but it does not support them concurrently, meaning that you cannot have GPS + NB-IoT, or GPS + CAT M1, enabled simultaneously at this time."  https://devzone.nordicsemi.com/f/nordic-q-a/48077/gps-http-post
I can switch: AT\%XSYSTEMMODE=0,0,1,0/AT\%XSYSTEMMODE=1,0,0,0/AT\%XSYSTEMMODE=0,1,0,0 but I couldn't POST data to my webserver.
Do you have any suggestions?
hng
  • Dear
    I am using ncs: v0.4.0 , so lte_link_control is lit differently from your link. I will try to update and try again
    Thanks
    Regards
    hng
  • Dear
    I added the option:
             CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    to avoid auto connect LTE when GPS is connecting.
    Then, I found the position from gps, then enable LTE:
               AT+CFUN=4 (lte_lc_normal())/AT\%XSYSTEMMODE=1,0,0,0/AT+CFUN=1
         connect to LTE: lte_lc_init_and_connect();
    then, i get LTE signal: +COPS: 0,2,"24201",7
    then, I POSTed my webserver. but I received nothing!!!
    Sending data to webserver
    getaddrinfo err: 0
    send err: 166
    client_fd: -1
    bind err: -1
    connect err: -1
    I added the header files, then you can review easy now.
    Could you plz help me
    GPS_LTE_June21.7z
    hng
    Your code prints "client_fd: -1", which indicates that the socket is not allocated. Looking through the code, it seems that you do not close your sockets after you're done, for instance in nRF_offGPS_onLTE. For every created socket(), there should be a corresponding close(). This also goes for the getaddrinfo(), which should also have a corresponding freeaddrinfo() within the same scope.
    Håkon
  • Dear
    Thanks so much
    I could  :
    (1) GPS position
    (2) LTE-M connection
    (3) http post with LTE-M to my webserver
    I tried to release the LTE-M socket() after posting and run loop (1)-(2)-(3) again. But, I couldn't connect to gps socket again.
    void app_http_post(char *PostString)
    	//int err;
            printk("Sending data to webserver\n");
            struct sockaddr_in local_addr;
    	struct addrinfo *res;
    	local_addr.sin_family = AF_INET;
    	local_addr.sin_port = htons(0);
    	local_addr.sin_addr.s_addr = 0;
    	int err = getaddrinfo(HTTP_HOST, NULL, NULL, &res);
    	printk("getaddrinfo err: %d\n\r", err);
    	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
            char send_buf[MAXLINE + 1];
    	int send_data_len_post = snprintf(send_buf,
    				         500, /*total length should not exceed MTU size*/
    				         POST_TEMPLATE, HTTP_PATH,
    				         HTTP_HOST, strlen(PostString),
    				         PostString);
    	printk("send err: %d\n\r", send_data_len_post);
    	int client_fd = socket(AF_INET, SOCK_STREAM, 0);
    	printk("client_fd: %d\n\r", client_fd);
    	err = bind(client_fd, (struct sockaddr *)&local_addr, sizeof(local_addr));
    	printk("bind err: %d\n\r", err);
           	err = blocking_connect(client_fd, (struct sockaddr *)res->ai_addr,sizeof(struct sockaddr_in));
    	printk("connect err: %d\n\r", err);
            int numbytes = blocking_send(client_fd, send_buf, send_data_len_post, 0);
            printk("send err: %d\n\r", numbytes);
            freeaddrinfo(res); // free getaddrinfo(HTTP_HOST, NULL, NULL, &res);
            k_sleep(1000);
            printk("Close socket \n\r");
           	close(client_fd); // close the socket
    and : lte_lc_offline();
    but, I couldnt connect to GPS socket
    fd = nrf_socket(NRF_AF_LOCAL, NRF_SOCK_DGRAM, NRF_PROTO_GNSS);
    the source code:
    GPS_LTE_June25.7z
    The second time, it will return:
    Could not init socket (err: -1)
  • Hi hng,
    We have an issue when switching back and forth several times in the current modem fw v0.7.0-29. We have reported this internally to our designers and developers, and they are working on fixing this issue.
    Håkon
