Hi there, I have set my SAADC to have an acquisition time of 3us, however when I toggle a pin before and after calling
nrfx_saadc_sample_convert
I measure the time of one sample to be closer to 34us. Can you tell me why this is so?
I don't require a timer like in the SAADC example, as I only need to do a bunch of measurements in rapid succession. Should I be using the oversampling/burst modes? I can't exactly figure out how they work...
My setup code:
ret_code_t err_code;
nrf_drv_saadc_config_t saadc_config;
nrf_saadc_channel_config_t we_channel_config;
nrf_saadc_channel_config_t batt_channel_config;
//Configure SAADC
saadc_config.low_power_mode = false; //Enable low power mode.
saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT; //Set SAADC resolution to 12-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^12=2048 (when input voltage is 3.6V for channel gain setting of 1/6).
saadc_config.oversample = SAADC_OVERSAMPLE_OVERSAMPLE_Bypass; //Disable Oversample
saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;
//Initialize SAADC
err_code = nrfx_saadc_init(&saadc_config, NULL);
Working Electrode Channel
//Configure SAADC Working Electrode Measurement Channel
we_channel_config.reference = NRF_SAADC_REFERENCE_INTERNAL; //Set internal reference 0.6V
we_channel_config.gain = NRF_SAADC_GAIN1_5; //Set input gain to 1/5. The maximum SAADC input voltage is then (0.6)/(1/5) = 3V
we_channel_config.acq_time = NRF_SAADC_ACQTIME_3US; //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
we_channel_config.mode = NRF_SAADC_MODE_DIFFERENTIAL; //Set SAADC as differential, as we want to compare it to the analog reference
we_channel_config.burst = NRF_SAADC_BURST_DISABLED;
we_channel_config.pin_p = PS_ADC_INPUT; //Input is working electrode pin
we_channel_config.pin_n = REF_ADC_INPUT; //Negative pin is the analog reference
we_channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED; //Disable pullup resistor on the input pin
we_channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED; //Disable pulldown resistor on the input pin
//Initialize SAADC Working Electrode Measurement Channel
err_code = nrfx_saadc_channel_init(WE_SAADC_CHANNEL, &we_channel_config); //Initialize SAADC channel 0 with the channel configuration
My measurement code: I intend to increase the NUMBER_OF_SAMPLES
int32_t get_adc_value()
int avg_adc = 0;
nrf_saadc_value_t saadc_value;
nrf_gpio_cfg_output(P1_PIN);
nrf_gpio_pin_set(P1_PIN); //TOGGLE PIN TO MEASURE TIME
//do conversion
for(int i = 0; i < NUMBER_OF_SAMPLES; i++){
err_code = nrfx_saadc_sample_convert(WE_SAADC_CHANNEL, &saadc_value);
avg_adc += saadc_value;
// NRF_LOG_DEBUG("ADC value %d: %d", i, saadc_value);
if (err_code != NRF_SUCCESS)
NRF_LOG_DEBUG("ADC error %d occured", err_code);
nrf_gpio_pin_clear(P1_PIN); //TOGGLE PIN TO MEASURE TIME
avg_adc /= NUMBER_OF_SAMPLES;
return avg_adc;
Thanks
