SAADC scan mode of 3 channels --> buffer order swap
I already read all the forum posts about this buffer order swap problem of the SAADC. Especially this one: https://devzone.nordicsemi.com/f/nordic-q-a/20291/offset-in-saadc-samples-with-easy-dma-and-ble/79053#79053
I tried to implement the PPI solution, but I am not able to bring this to work. I have still a swap in the order every second call of the callback function. Can anyone help me?
This is pretty much my firmware (without BLE stuff at the moment):
I'm using a compare event of the RTC to trigger the sample task in scan mode. Another compare event is used to enable the ppi channel again after disabling it after 10 samples per channel. The reason for that is that I want to sample at a high frequency but only 10 samples per second. The second PPI channel is used for the fix from the link above.
PPI:
    ret_code_t err_code;
    uint32_t rtc_compare_event_addr = nrf_drv_rtc_event_address_get(&rtc, NRF_RTC_EVENT_COMPARE_0);//nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
    err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel_1);
	err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel_2);
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel_1,
                                          rtc_compare_event_addr,
                                          saadc_sample_task_addr);
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel_2, nrf_saadc_event_address_get(NRF_SAADC_EVENT_END), nrf_saadc_task_address_get(NRF_SAADC_TASK_START));
    err_code = nrf_drv_ppi_channel_enable(m_ppi_channel_2);
SAADC:
#define SAMPLES_IN_BUFFER 10
#define ADC_CHANNEL_COUNT 3
    ret_code_t err_code = nrf_drv_ppi_channel_enable(m_ppi_channel_1);
void saadc_sampling_event_disable(void)
    ret_code_t err_code = nrf_drv_ppi_channel_disable(m_ppi_channel_1);
		int value = 0;
		int i;
		//Event is triggered when buffer is full! Not when one conversion is done!
		////https://devzone.nordicsemi.com/f/nordic-q-a/14777/ble_app_proximity-saadc-channel-data#post-id-85497
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER*ADC_CHANNEL_COUNT); //Set buffer so the SAADC can write to it again. This is either "buffer 1" or "buffer 2"
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER*ADC_CHANNEL_COUNT; i++)
					NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
					switch(i%3)
						case 0: battery_voltage_sum = battery_voltage_sum + p_event->data.done.p_buffer[i];
						case 1: thermistor_1_sum = thermistor_1_sum + p_event->data.done.p_buffer[i];
						case 2: thermistor_2_sum = thermistor_2_sum + p_event->data.done.p_buffer[i];
				measDone = 1;
        m_adc_evt_counter++;
				//stop sampling until Compare 1 Event of RTC
				saadc_sampling_event_disable();
void saadc_init(void)
		//Source for battery measurement:
		//https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/measuring-lithium-battery-voltage-with-nrf52
		//Sampling frequeny should be 1Hz-10Hz for high saadc input resistance value! Otherwise voltage devider will be affected by the input reistance!
		//Total time < Sum(CH[x].tACQ+tCONV), x=0..enabled channels (Source: Datasheet)
		//Total time < #Channels*(40us + 2us)
		//3 Channels: 126us --> max sampling rate = 1/126uS = 7.94kHz --> set RTC Compare Event (PPI) to this frequency
		//Configure SAADC
		nrf_drv_saadc_config_t  config = NRF_DRV_SAADC_DEFAULT_CONFIG;
		config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;
		//Initialize SAADC
    err_code = nrf_drv_saadc_init(&config, saadc_callback);
		//Configure SAADC channel 0
		nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
		channel_config.gain = NRF_SAADC_GAIN1_4;
		channel_config.acq_time = SAADC_CH_CONFIG_TACQ_3us; //needed for maximum source resistance of 800kOhm (Datasheet) --> 40us. With additional C --> 3us
		//channel_config.burst = NRF_SAADC_BURST_ENABLED;
		//Initialize SAADC channel 0
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
	  //Configure SAADC channel 1
		channel_config.pin_p = NRF_SAADC_INPUT_AIN0;
	 	channel_config.reference = NRF_SAADC_REFERENCE_VDD4;
		//Initialize SAADC channel 1
    err_code = nrf_drv_saadc_channel_init(1, &channel_config);
		//Configure SAADC channel 2
		channel_config.pin_p = NRF_SAADC_INPUT_AIN1;
		//Initialize SAADC channel 2
    err_code = nrf_drv_saadc_channel_init(2, &channel_config);
		//Set SAADC buffer 1. The SAADC will start to write to this buffer
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER*ADC_CHANNEL_COUNT);
		//Set SAADC buffer 2. The SAADC will write to this buffer when buffer 1 is full. This will give the applicaiton time to process data in buffer 1.
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER*ADC_CHANNEL_COUNT);
RTC:
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
		static int i = 2;
    if (int_type == NRF_DRV_RTC_INT_COMPARE0)
        //nrf_gpio_pin_toggle(LED);
				//nrf_drv_rtc_counter_clear(&rtc);
				//reactivate compare irq!
				nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * i++,true);
		else if (int_type == NRF_DRV_RTC_INT_COMPARE1)
				nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 1,true);
				nrf_drv_rtc_cc_set(&rtc,1,COMPARE_COUNTERTIME * 1000,true);
				i = 2;
    else if (int_type == NRF_DRV_RTC_INT_TICK)
        rtcCounter++;
static void lfclk_config(void)
    ret_code_t err_code = nrf_drv_clock_init();
static void rtc_config(void)
	uint32_t err_code;
	//Initialize RTC instance
	nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
	config.prescaler = 32; // fRTC [kHz] = 32.768 / (PRESCALER + 1 ) = 1kHz
	//config.prescaler = 4095; // fRTC [kHz] = 32.768 / (PRESCALER + 1 ) --> 8Hz (minimum because prescsaler is 12bit)
	err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
	//Enable tick event & interrupt
	nrf_drv_rtc_tick_enable(&rtc,true);
	//Set compare channel 0 to trigger interrupt after COMPARE_COUNTERTIME seconds
	err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 1,true); //1kHz
	//Set compare channel 1 to trigger interrupt after COMPARE_COUNTERTIME seconds
	err_code = nrf_drv_rtc_cc_set(&rtc,1,COMPARE_COUNTERTIME * 1000,true); //1Hz
	//Power on RTC instance
	nrf_drv_rtc_enable(&rtc);
void timer_handler(nrf_timer_event_t event_type, void * p_context)
Main:
	/* Configure board. */
	bsp_board_leds_on();
	bsp_board_init(BSP_INIT_BUTTONS);
	lfclk_config();
	rtc_config();
    saadc_init();
	saadc_sampling_event_init();
	while(1)
        if(measDone == 1)
Thank you all and best regards!
Manuel
  • Thanks haakonsh. But this is intended. I'm using oversampling on three channels. Therfore I will have three values (each is an average of 256 samples) in the buffer after DONE event.
    I also found this: https://devzone.nordicsemi.com/f/nordic-q-a/48462/questions-on-saadc-calibration-gain-best-use
    Same code as I have except that I have three channels and I'm using higher oversampling. But it is still not working.
    My console output:
    Event number 6 is the calibration measurement which is always the same three values? Is this normal? And after this, the values start jumping.
    I checked over your code and found an issue with how you trigger the tasks.
    You need to write '1' to the tasks in order to trigger the task. In your code you do this:
    NRF_SAADC->TASKS_START;
    While you should do this:
    NRF_SAADC->TASKS_START = 1;
    I see that this is what Håkon posted below as well.
    Effectively, the workaround is in implemented, and you will get stuck waiting for events that will never arrive.
    Jørgen
  • Hi Jorgen,
    Sorry for the late answer. I have now implemented your suggestion and here is my new code:
    PPI:
    SAADC:
    	nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true);
    	int value = 0;
    	int i;
    		if((m_adc_evt_counter % SAADC_CALIBRATION_INTERVAL) == 0)       //Evaluate if offset calibration should be performed. Configure the SAADC_CALIBRATION_INTERVAL constant to change the calibration frequency
                nrf_drv_saadc_abort();                                      // Abort all ongoing conversions. Calibration cannot be run if SAADC is busy
                m_saadc_calibrate = true;                                   // Set flag to trigger calibration in main context when SAADC is stopped
    		for (i = 0; i < ADC_CHANNEL_COUNT; i++)
    			//NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
    			switch(i%4)
    				case 0: thermistor_1_sum = p_event->data.done.p_buffer[i];
    				case 1: thermistor_2_sum = p_event->data.done.p_buffer[i];
    				case 2: battery_voltage_sum = p_event->data.done.p_buffer[i];
    		if(m_saadc_calibrate == false)
                err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, ADC_CHANNEL_COUNT); //Set buffer so the SAADC can write to it again. This is either "buffer 1" or "buffer 2"
    			measDone = 1;
    		nrf_gpio_pin_clear(THERMISTOR_VREF);
    	else if (p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
    		nrf_saadc_task_trigger(NRF_SAADC_TASK_STOP);
    		while(NRF_SAADC->EVENTS_STOPPED == 0);
    		NRF_SAADC->EVENTS_STOPPED = 0;
            err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], ADC_CHANNEL_COUNT);             //Set buffer so the SAADC can write to it again.
            err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], ADC_CHANNEL_COUNT);             //Need to setup both buffers, as they were both removed with the call to nrf_drv_saadc_abort before calibration.
            NRF_LOG_INFO("SAADC calibration complete !");                                              //Print on UART
    		battery_voltage_sum = 0;
    		voltage_sum = 0;
    		thermistor_1_sum = 0;
    		thermistor_2_sum = 0;
        //Configure SAADC
        config.resolution = NRF_SAADC_RESOLUTION_14BIT;
        config.oversample = SAADC_OVERSAMPLE_OVERSAMPLE_Over256x;
        //config.low_power_mode = true;
        //Initialize SAADC
        channel_config.acq_time = SAADC_CH_CONFIG_TACQ_40us;
    RTC:
    		nrf_gpio_pin_set(THERMISTOR_VREF);
            rtcCounter++;
    	uint32_t err_code;
    	err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true); //1Hz
    Main:
    	NRF_POWER->DCDCEN = 1;	//Enabling the DCDC converter for lower current consumption
    	lfclk_config();
    	rtc_config();
    	nrf_gpio_cfg_output(THERMISTOR_VREF);
        saadc_init();
    	while(1)
            if(m_saadc_calibrate == true)
    			// Disable the PPI triggering of the sample task
    			while(nrf_drv_saadc_calibrate_offset() != NRF_SUCCESS); //Trigger calibration task
    			while(!NRF_SAADC->EVENTS_CALIBRATEDONE);
    			NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
    			NRF_SAADC->EVENTS_STARTED = 0;
    			while(!NRF_SAADC->EVENTS_STARTED);
    			// Enable the PPI triggering of the sample task
    			m_saadc_calibrate = false;
            if(measDone == 1)
                //LOG VALUES
    Indeed it works much better now! But still, in the first measurement after a calibration, there is a false value in the first buffer index. Here is the RTT output (error is marked yellow):
    I am still not able to solve this problem...
    Thank you and best regards,
    Manuel
  • Why do you trigger the START task in main after calibration? This should be done by nrf_drv_saadc_buffer_convert() in the CALIBRATEDONE event in the handler, so there should be no need to trigger this manually. You should also be able to restart the PPI/sampling event from the callback, after setting up the new buffers.
