printf only sends a single byte?
I'm attempting to use the app_trace module. I've set it up as follows:
    // Setup tracing. Also sets up UART.
    app_trace_init();
    app_trace_log("Starting...\r\n");
I'm using PuTTY to connect (to COM5 in my case) with the following parameters: Speed: 115200 Data bits: 8 Stop bits: 1 Parity: None Flow control: None
These should match the settings that the trace module uses in the 7.1 SDK.
My issue is that app_trace_log() sends only a single byte over the serial line ("S" in my case). Any other calls to app_trace_log() also send only the first byte of the string.
  • hi,Peter:
    app_trace_init()/app_trace_log() of SDK9.0 i test , it is ok.. in your code, please add while(1) code. otherwise, when you are printing, the main is ended. so you just print the fist char of your message...
    notice: when your print a lots of message , please give some time deleay using nrf_delay_ms(),
    int main(void) {
    // Setup tracing. Also sets up UART. app_trace_init();
    while(1){ ; // just wait..
  • hi,Peter:
    int main(void) {
