ESB module stops transmitting payloads
I have been encountering a rather latent bug in a  product that we are developing. It consists of a custom nRF52832 board, that is connected to an nRF52-DK via ESB, and the DK relays the payloads to a computer via serial UART. Both sides use SDK v15.0.0.
The problem arises very randomly. What happens is that after some time we repeatedly get `NRF_ERROR_NO_MEM` when calling `nrf_esb_write_payload`. It seems like the ESB module isn't processing the TX fifo anymore, and the whole communication channel comes to a halt. I've stopped the application in the debugger when this happens, and indeed `m_tx_fifo.count` is 8 (full), and more interestingly `m_nrf_esb_mainstate` is `NRF_ESB_STATE_PTX_RX_ACK`.
The modules are set up to ack on every packet, and occasionally the PRX side sends payloads along with the ack.
Furthermore, this seems to be more apparent with increased payload lengths. Initially, we were sending payloads of ~100 bytes. Reducing it down to 40 bytes, we didn't notice this error.
Some of our attempts to recover from this state are:
  • Manually starting TX with `nrf_esb_start_tx`, but that doesn't work since t he module isnt in the idle state.
  • Flushing the TX queue, but it just fills right back up since the module doesn't transmit any payloads.
  • Re-initializing the ESB module on the PTX side by calling `nrf_esb_init` again, but that just results in the same error right away.
This is how the config is set up for the PTX side:
nrf_esb_config_t nrf_esb_config = NRF_ESB_DEFAULT_CONFIG;
nrf_esb_config.protocol           = NRF_ESB_PROTOCOL_ESB_DPL;
nrf_esb_config.bitrate            = NRF_ESB_BITRATE_2MBPS;
nrf_esb_config.event_handler      = event_handler;
nrf_esb_config.mode               = NRF_ESB_MODE_PTX;
nrf_esb_config.selective_auto_ack = false;
nrf_esb_config.tx_output_power    = NRF_ESB_TX_POWER_4DBM;
And this is the PRX side:
nrf_esb_config.payload_length     = 8;
nrf_esb_config.mode               = NRF_ESB_MODE_PRX;
nrf_esb_config.event_handler      = nrf_esb_event_handler;
Looking at it now, I can see that there is a discrepancy in the `payload_length` field of the config. Does this field have any effect if using `NRF_ESB_PROTOCOL_ESB_DPL`?
