ENABLE_TRACE
I have a Segger J-Trace Pro and am attempting to enable trace debugging of my application. I have a custom board that breakout out the appropriate Trace Clk and Trace Data[] signals. I have been reviewing the code to enable the ETM trace functionality. There seems to be support as part of the HAL:
https://github.com/NordicPlayground/fw-nrfconnect-zephyr/blob/master/ext/hal/nordic/nrfx/mdk/system_nrf9160.c#L164
The first issue was NRF_TAD_S->CLOCKSTART = TAD_CLOCKSTART_START_Msk not being defined. I found the definitions in both the manual and this file:
http://developer.nordicsemi.com/nRF_MDK/MDK_8_25_0/BSD/Files/nrf9160_bitfields.h
Then, ran into an issue with, (GPIO_PIN_CNF_MCUSEL_TND << GPIO_PIN_CNF_MCUSEL_Pos)
https://github.com/NordicPlayground/fw-nrfconnect-zephyr/blob/master/ext/hal/nordic/nrfx/mdk/system_nrf9160.c#L41
I could not find a definition for GPIO_PIN_CNF_MCUSEL_TND  anywhere including the nrf9160 product specification manual. Could you assist me in configuring the Trace properly to work with J-Trace and the Segger Ozone debugger?
Thank you,
Jonathan Mohlenhoff
  • Hi Jonathan,
    Unfortunately, the support for this feature is limited at this moment in time.
    Please contact your RSM for more details with regards to roadmap questions, if you do not know how that is then you can send me a direct message on Devzone and I will help you out.
    Best Regards,
    Martin L.
  • Looks like there was an update in the latest nRF MDK (8.26.0) that looks relevant:
     - In system_nrf9160.c, fixed ENABLE_TRACE sequence.
    I should be able to test it out by end of this week. Nino from Segger technical support has also been instrumental at figuring out how to enable J-Trace with the nRF9160.
  • I have tested this in the latest release of nRF Connect SDK, v1.2.0 and was able to get ARM ETM working. I added the ENABLE_TRACE define for the SPM and had to disable GCC optimization for the SystemInit function of system_nrf9160.c:
    #pragma GCC push_options
    #pragma GCC optimize ("O0")
    void SystemInit(void)
    #pragma GCC pop_options
    I believe the issue has to do with this section of code requiring order of execution:
                *((uint32_t *)(0xE0053000ul)) = 0x00000001ul;
                *((uint32_t *)(0xE005AFB0ul))  = 0xC5ACCE55ul;
                *((uint32_t *)(0xE005A000ul)) &= 0xFFFFFF00ul;
                *((uint32_t *)(0xE005A004ul))  = 0x00000009ul;
                *((uint32_t *)(0xE005A000ul))  = 0x00000303ul;
                *((uint32_t *)(0xE005AFB0ul))  = 0x00000000ul;
                *((uint32_t *)(0xE005BFB0ul))  = 0xC5ACCE55ul;
                *((uint32_t *)(0xE005B000ul)) &= 0xFFFFFF00ul;
                *((uint32_t *)(0xE005B004ul))  = 0x00003000ul;
                *((uint32_t *)(0xE005B000ul))  = 0x00000308ul;
                *((uint32_t *)(0xE005BFB0ul))  = 0x00000000ul;
                *((uint32_t *)(0xE0058FB0ul)) = 0xC5ACCE55ul;
                *((uint32_t *)(0xE0058000ul)) = 0x00000000ul;
                *((uint32_t *)(0xE0058004ul)) = 0x00000000ul;
                *((uint32_t *)(0xE0058FB0ul)) = 0x00000000ul;
    Following the tracing sample from Segger helped configuring Ozone for streaming trace, https://wiki.segger.com/nRF91_Series_Devices.
    Next, get Ozone to be Zephyr RTOS aware. I will mark this as solved, thanks Nordic and Segger!
