Using the Secure DFU from SDK 14.2 I managed to integrate the NUS peripheral example to have access to an UART pipe in parallel to the DFU when running the boot loader. Now I would like to port this to SDK 15.3 and I run into trouble when adding the UART code. For debugging purposes I based my project on the pca10040_ble_debug example, using the pca10040 dev board.
I managed to make the NUS service work without any problem with same principle as before, basically extending ble_dfu_transport_init() inside nrf_dfu_ble.c with yet another service. naturally I had to add some additional libraries, defines, and include path as well:
#include "ble_nus.h"
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);
switch( p_evt->type){
case BLE_NUS_EVT_RX_DATA:
NRF_LOG_DEBUG("Received some NUS data");
uint32_t ble_dfu_transport_init(nrf_dfu_observer_t observer)
uint32_t err_code = NRF_SUCCESS;
ble_nus_init_t nus_init;
// Initialize NUS Service.
Now, I continue by integrating the UART and this is when I run into trouble. This is what I reused from NUS peripheral example
#include "boards.h"
#include "app_uart.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define UART_TX_BUF_SIZE (256)
#define UART_RX_BUF_SIZE (256)
void app_uart_event_handle(app_uart_evt_t * p_event)
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
NRF_LOG_DEBUG("Received some UART Data");
case APP_UART_FIFO_ERROR:
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
app_uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
When I Build and Debug I get the following debug output with errors:
<info> app: Inside main <debug> app: In nrf_bootloader_init <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()... <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend. <debug> nrf_dfu_settings: Using settings page. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <info> nrf_dfu_settings: Backing up settings page to address 0x7E000. <debug> nrf_dfu_settings: Writing settings... <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000 <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 0 <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 0 <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20009E2C, len=896 bytes), queue usage: 1 <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 0 <debug> app: Enter nrf_bootloader_fw_activate <info> app: No firmware to activate. <info> app: Boot validation failed. No valid app to boot. <debug> app: DFU mode because app is not valid. <info> nrf_bootloader_wdt: WDT is not enabled <debug> app: in weak nrf_dfu_init_user <debug> app: timer_stop (0x20005808) <debug> app: timer_activate (0x20005808) <info> app: Entering DFU mode. <debug> app: Initializing transports (found: 1) <debug> nrf_dfu_ble: Initializing BLE DFU transport <debug> nrf_dfu_ble: Setting up vector table: 0x00072000 <debug> nrf_dfu_ble: Enabling SoftDevice. <debug> app: Failed to initialize transport 0, error 4096 <error> app: Could not initalize DFU transport: 0x00001000 <error> app: Received an error: 0x00000003!
I am not sure from where the error origins. However, the ble_dfu_transport_init() function inside nrf_dfu_ble.c exits after evaluating the err_code from nrf_sdh_enable_request();
NRF_LOG_DEBUG("Enabling SoftDevice.");
VERIFY_SUCCESS(err_code);
Now, if I comment out APP_UART_FIFO_INIT(.) this error disappear and main loop is entered.
... <debug> nrf_dfu_ble: Using default advertising name <debug> nrf_dfu_ble: Advertising... <debug> nrf_dfu_ble: BLE DFU transport initialized. <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend. <debug> app: Enter main loop
