Is there any UART examples by directly accessing the registers?
Based on SDK15.0.2, for NRF52832 or NRF52810, higher freedom, higher memory utilization.
There isn't one available in the SDK for UART but here is one for UARTE for nRF52840:
#include <nrf.h>
#define PIN_TXD (6)
#define PIN_RXD (8)
uint8_t hello_world[] = "Hello World!\n";
// Configure the UARTE with no flow control, one parity bit and 115200 baud rate
NRF_UARTE0->CONFIG = (UART_CONFIG_HWFC_Disabled << UART_CONFIG_HWFC_Pos) |
(UART_CONFIG_PARITY_Included << UART_CONFIG_PARITY_Pos);
NRF_UARTE0->BAUDRATE = UARTE_BAUDRATE_BAUDRATE_Baud115200 << UARTE_BAUDRATE_BAUDRATE_Pos;
// Select TX and RX pins
NRF_UARTE0->PSEL.TXD = PIN_TXD;
NRF_UARTE0->PSEL.RXD = PIN_RXD;
// Enable the UART (starts using the TX/RX pins)
NRF_UARTE0->ENABLE = UARTE_ENABLE_ENABLE_Enabled << UARTE_ENABLE_ENABLE_Pos;
// Configure transmit buffer and start the transfer
NRF_UARTE0->TXD.MAXCNT = sizeof(hello_world);
NRF_UARTE0->TXD.PTR = (uint32_t)&hello_world[0];
NRF_UARTE0->TASKS_STARTTX = 1;
// Wait until the transfer is complete
while (NRF_UARTE0->EVENTS_ENDTX == 0)
// Stop the UART TX
NRF_UARTE0->TASKS_STOPTX = 1;
// Wait until we receive the stopped event
while (NRF_UARTE0->EVENTS_TXSTOPPED == 0);
// Disable the UARTE (pins are now available for other use)
NRF_UARTE0->ENABLE = UARTE_ENABLE_ENABLE_Disabled << UARTE_ENABLE_ENABLE_Pos;
while (1)
__WFE();
regards
Jared
Thanks! But where is the receiving interrupt?
The sample codes shows only how to transmit. I suggest that you read the UARTE Receive chapter to understand how you should implement the reception.
regards
Jared
