I2C clock frequency problem
I am using NRF52832 development board , to which i have interfaced LIS3DSH accelerometer sensor(3.3V i2c)
when i  configure it for 1600 sampling rate and all the axis enabled , i am not able to get any data .
could anyone help with this problem.
also the I2c clock frequency, as shown in below image, while i am capturing data when i observe in oscilloscope or logic analyzer , clock frequency is showing 200 all the setting is for 400KHz.
what could be the problem for this or is there any other way i need to follow to set the clock to 400KHz.
help me ASAP...
Thank you
  • I see what you mean now, that clock is definitely set to 200kHz.
  • In this code you're still using pulldowns on your I2C lines.
    I suggest you develop your I2C related code in a separate project, without the SoftDevice, or any other unnecessary code for that matter. If the issue persists then it will be a lot easier to narrow down. If it does not, then it's most likely caused by high CPU load, blocking the I2C driver or your LIS3DSH driver from executing properly. If this is the case then you can identify when the issue arises by adding first The SoftDevice, then your BLE connections, then continue with other SW modules that you need, until the issue arises.
  • when i  configure it for 1600 sampling rate and all the axis enabled , i am not able to get any data
    Are you able to get any data at lower rates?
  • i didn't try that, is it related to that issue my main concern is why clock is not changing as i have set.
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup tw_scanner main.c
     * @ingroup nrf_twi_example
     * @brief TWI Sensor Example main file.
     * This file contains the source code for a sample application using TWI.
    #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "LIS3DSH.h"
    #include "FFT.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_gpiote.h"
    #include <stdbool.h>
    #include "nrf.h"
    #include "boards.h"
    #include "nrf_drv_timer.h"
    #include<stdio.h>
    #define APP_ERROR_CHECK1(ERR_CODE)                    \
            if (ERR_CODE != NRF_SUCCESS)                  \
            	return ERR_CODE;                            \
    /* TWI instance ID. */
    #if TWI0_ENABLED
    #define TWI_INSTANCE_ID     0
    #elif TWI1_ENABLED
    #define TWI_INSTANCE_ID     1
     /* Number of possible TWI addresses. */
     #define TWI_ADDRESSES      127
     //#define MEMS_SENSOR_WHO_AM_I_ADDR      0x0F
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    ret_code_t err_code = NRF_SUCCESS;
    uint16_t sampleCntTracker = 0x00;
    //typedef struct
    //   float fReal;
    //   float fImag;
    //}stXComplex;
    int16_t x_axis_data[SAMPLE_NUMBER] = {0x00};
    int16_t y_axis_data[SAMPLE_NUMBER] = {0x00};
    int16_t z_axis_data[SAMPLE_NUMBER] = {0x00};
     * @brief TWI initialization.
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_400K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        nrf_drv_twi_enable(&m_twi);
    ret_code_t readFromlis3dsh(uint8_t reg, uint8_t* p_dest, uint8_t bytes)
        ret_code_t err = NRF_SUCCESS;
        err = nrf_drv_twi_tx(&m_twi, I2C_MEMS_SENSOR_BUS_ADDRESS, &reg, sizeof(reg), false);
        APP_ERROR_CHECK1(err);
        err = nrf_drv_twi_rx(&m_twi, I2C_MEMS_SENSOR_BUS_ADDRESS, p_dest, bytes);
        return NRF_SUCCESS;
    ret_code_t writeTolis3dsh(uint8_t* const data, uint8_t bytes)
        err = nrf_drv_twi_tx(&m_twi, I2C_MEMS_SENSOR_BUS_ADDRESS, data, sizeof(data), false);
        return NRF_SUCCESS;
    bool verifyLis3dshAccelerometer()
        uint8_t verify = 0x00;
        readFromlis3dsh(MEMS_SENSOR_WHO_AM_I_ADDR, &verify, sizeof(verify));
        if(verify == MEMS_SENSOR_WHO_AM_I_VALUE)
            return true;
        return false;
    ret_code_t noOfSamplesStoredinfifo(uint8_t* samplesCnt)
        err = readFromlis3dsh(MEMS_SENSOR_FIFO_SRC_ADDR, samplesCnt, sizeof(uint8_t));
        APP_ERROR_CHECK(err);
    ret_code_t wakeUpStateMachineConfiguration()
        uint8_t toSend[2] = {0x00};
        toSend[0] = MEMS_SENSOR_CTRL_REG1_ADDR;
        toSend[1] = 0x01;
        err = writeTolis3dsh(toSend, sizeof(toSend));
        toSend[0] = MEMS_SENSOR_CTRL_REG3_ADDR;
        toSend[1] = 0x48;
        toSend[0] = MEMS_SENSOR_CTRL_REG4_ADDR;
        toSend[1] = 0x97;/* 1.6k sampling rate is selected*/
        toSend[0] = MEMS_SENSOR_CTRL_REG5_ADDR;
        toSend[1] = 0x00;
        toSend[0] = THRS1_1;
        toSend[1] = 0x65;
        toSend[0] = ST1_1;
        toSend[1] = 0x05;
        toSend[0] = ST1_2;
        toSend[1] = 0x11;
        toSend[0] = MASK1_B;
        toSend[1] = 0xFC;
        toSend[0] = MASK1_A;
        toSend[1] = 0xFC;
        toSend[0] = SETT1;
        toSend[1] = 0x01;
        /* FIFO mode selection */
        memset(toSend, 0x00, sizeof(toSend));
        toSend[0] = MEMS_SENSOR_CTRL_REG6_ADDR;
        toSend[1] |= (FIFO_ENABLE | AUTO_ADDRESS_INCREMENT);
        return NRF_SUCCESS;
    int16_t two_compl_to_int16(uint16_t two_compl_value)
        int16_t int16_value = 0;
        /* conversion */
        if (two_compl_value > 32768) {
            int16_value = (int16_t)(-(((~two_compl_value) & (uint16_t)(0xFFFF)) + (uint16_t)(1)));
        } else {
            int16_value = (int16_t)(two_compl_value);
        return int16_value;
    ret_code_t ReadOutputRegistersOfAccelerometerNew()
        uint8_t vibData[120] = {0x00};
        err = readFromlis3dsh(MEMS_SENSOR_OUT_X_L_ADDR, &vibData[0], sizeof(vibData));
        for(uint16_t i = 0, j = 0; (j < SAMPLE_READ_ONE_ITERATION) && (i < (uint16_t)(SAMPLE_READ_ONE_ITERATION*6)) ; i = (uint16_t)(i+6), j++)
            x_axis_data[sampleCntTracker + j] = two_compl_to_int16(((uint16_t)vibData[i+1]<<8) | (uint16_t)vibData[i]);
            y_axis_data[sampleCntTracker + j]= two_compl_to_int16(((uint16_t)vibData[i+3]<<8) | (uint16_t)vibData[i+2]);
            z_axis_data[sampleCntTracker + j] = two_compl_to_int16(((uint16_t)vibData[i+5]<<8) | (uint16_t)vibData[i+4]);
            x_axis_data[sampleCntTracker + j] = (int16_t)(x_axis_data[sampleCntTracker + j] * LIS3DSH_2G_SENSITIVITY);
            y_axis_data[sampleCntTracker + j] = (int16_t)(y_axis_data[sampleCntTracker + j] * LIS3DSH_2G_SENSITIVITY);
            z_axis_data[sampleCntTracker + j] = (int16_t)(z_axis_data[sampleCntTracker + j] * LIS3DSH_2G_SENSITIVITY);
        sampleCntTracker = (uint16_t)(sampleCntTracker + SAMPLE_READ_ONE_ITERATION);
        return NRF_SUCCESS;
    uint32_t timeCapture = 0x00;
    uint32_t time_ticks = 0x00;
    const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
    void startTimer()
        uint32_t time_ms = 8000; //Time(in miliseconds) between consecutive compare events.
        err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, NULL);
        time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms);
        nrf_drv_timer_extended_compare(
             &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
        nrf_drv_timer_enable(&TIMER_LED);
    ret_code_t accelerometerDataAcquisition_SR_1_6_0_0(uint16_t sampleCount)
        uint8_t fifoSamples = 0x00;
        //startTimer();
        //nrf_delay_ms(50);
        //timeCapture = nrfx_timer_capture(&TIMER_LED, 0);
        //nrf_delay_us(ACC_DELAY_2_0);
        //nrf_delay_us(10000);
        //startTimer();
        err = noOfSamplesStoredinfifo(&fifoSamples);
        for(uint16_t it_cnt = 0x00; it_cnt < (sampleCount)/20; it_cnt++)
            if(it_cnt)
                nrf_delay_us(SEC_IT_DELAY_ODR_1_6_0_0);
            err = ReadOutputRegistersOfAccelerometerNew();
    //    err = FFT(N_DIRECTION_FFT, N_POINT_FFT, x_axis_data);
    //    if(err != SUCCESS)
    //        return NRF_ERROR_INVALID_DATA;
    //    err = FFT(N_DIRECTION_FFT, N_POINT_FFT, y_axis_data);
    //    err = FFT(N_DIRECTION_FFT, N_POINT_FFT, z_axis_data);
        return NRF_SUCCESS;
    void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
        NRF_LOG_INFO("INTERRUPT OCCURED");
        NRF_LOG_FLUSH();
    ret_code_t wakeUpStateMachineInterruptConfiguration(void)
        nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
        in_config.pull = NRF_GPIO_PIN_PULLUP;
        err = nrf_drv_gpiote_in_init(WAKE_UP_INT_PIN, &in_config, in_pin_handler);
        nrf_drv_gpiote_in_event_enable(WAKE_UP_INT_PIN, true);
        return err;
    //void timer_initializations()
    //const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
    int8_t address = 0x00;
    ret_code_t configureLis3dshAccelerometer()
        uint8_t reg[2] = {0x00};
        reg[0] = MEMS_SENSOR_CTRL_REG4_ADDR;
        reg[1] |= DATARATE_1600;
        err = writeTolis3dsh(&reg[0], sizeof(reg));
        reg[1] |= XYZ_ENABLE;
        reg[0] = MEMS_SENSOR_CTRL_REG3_ADDR;
        reg[1] = 0x00;
        reg[0] = MEMS_SENSOR_CTRL_REG5_ADDR;
        reg[1] |= FILTER_BW_800;
        reg[1] |= FULLSCALE_2;
        reg[1] |= (0x02 | SERIALINTERFACE_4WIRE);
        reg[0] = MEMS_SENSOR_CTRL_REG6_ADDR;
        reg[1] |= (FIFO_ENABLE | AUTO_ADDRESS_INCREMENT);
        reg[0] = MEMS_SENSOR_FIFO_CTRL_ADDR;
        //reg[1] |= FIFO_STREAM_MODE;
        reg[1]  = 0x54;
        uint8_t no = 0x00;
        err = noOfSamplesStoredinfifo(&no);
        bool detected_device = false;
        twi_init();
        detected_device = verifyLis3dshAccelerometer();
        if(!detected_device)
              return 0;
        err = configureLis3dshAccelerometer();
        err = accelerometerDataAcquisition_SR_1_6_0_0(SAMPLE_NUMBER);
        for(int i = 0 ; i < 10 ; i++)
            printf("\t%d\t%d\t%d\n",x_axis_data[i],y_axis_data[i],z_axis_data[i]);
            NRF_LOG_FLUSH();
        printf("GVR Sensor Moule Advertising.....");
        while(1)
    //         nrf_pwr_mgmt_run();
    The above code is without softdevice enabled still the same issue, as u can see in line 129 400k is set
