DFU with external QSPI memory
   I am working on project, in which we using nordic nRF52840 chip. We need to flash the app+SD+BL image file in external QSPI memory.
After prevalidation, the DFU controller starts to send flash image package, we need to receive this and need to save in external QSPI memory. Once the postvalidation is successful, then read all the flash image package stored in external QSPI memory and write it to internal flash memory.
For that we use secure bootloader example code as reference file. I need to know where i need to modify the secure bootloader code.
I noticed that after prevalidation, the flash is erased in on_data_obj_create_request() function in nrf_dfu_req_handler.c file, and flash is written in on_data_obj_write_request() under the same c file. Is that right?
Thanks & Regards
Mohammad Gouse
  • Hi Hung,
    I used blinky_pca10056_mbr.hex found in examples under nordic SDK 15.3 to generate the dfu_app_pkg.zip. I followed the below steps,
    1. In the blinky_pca10056_mbr example code, i modified the FLASH_START=0x26000, in order to place code above SD section.
    2. Then i generated the settings file,
    nrfutil settings generate --family NRF52840 --application blinky_pca10056_mbr.hex --application-version 5 --bootloader-version 2 --bl-settings-version 2 settings.hex
    Bootloader DFU Settings:
    * File: settings.hex
    * Family: NRF52840
    * Start Address: 0x000FF000
    * CRC: 0x236ED638
    * Settings Version: 0x00000002 (2)
    * App Version: 0x00000005 (5)
    * Bootloader Version: 0x00000002 (2)
    * Bank Layout: 0x00000000
    * Current Bank: 0x00000000
    * Application Size: 0x000006AC (1708 bytes)
    * Application CRC: 0x4009821F
    * Bank0 Bank Code: 0x00000001
    * Softdevice Size: 0x00000000 (0 bytes)
    * Boot Validation CRC: 0x1202D358
    * SD Boot Validation Type: 0x00000000 (0)
    * App Boot Validation Type: 0x00000001 (1)
    3. Then I merged the blinky_pca10056_mbr.hex and settings.hex into app_settings.hex
    4. Finally the dfu_app_pkg is generated,
    nrfutil pkg generate --hw-version 52 --sd-req 0x00 --application-version 5 --application app_settings.hex --key-file Test2.key app_dfu_pkg.zip
    5. I am sending the app_dfu_pkg.zip,
    nrfutil dfu usb-serial -pkg app_dfu_pkg.zip -p COM5 -b 115200
    6. The output,
    <info> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <info> app: App is valid
    <info> app: DFU mode requested via button.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <info> app: in weak nrf_dfu_init_user
    <info> app: Entering DFU mode.
    <info> app: Enter main loop
    <info> nrf_dfu_serial_usb: USB power detected
    <info> nrf_dfu_serial_usb: USB ready
    <warning> nrf_dfu_serial_usb: Could not read from CDC. Error: 0x92.
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating hash (len: 63)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <info> app: Enter nrf_dfu_cache_prepare()
    <info> app: required_size: 0xD9324.
    <info> app: single_bank: false.
    <info> app: keep_app: false.
    <info> app: keep_softdevice: false.
    <info> app: SD_PRESENT: false.
    <info> app: Bank contents:
    <info> app: Bank 0 code: 0x01: Size: 0xD9324
    <info> app: Bank 1 code: 0x00: Size: 0x0
    <info> app: pass: 0.
    <info> app: cache_address: 0xDB000.
    <info> app: cache_too_small: true.
    <info> app: keep_firmware: false.
    <info> app: delete_more: true.
    <info> app: pass: 1.
    <info> app: cache_address: 0x1000.
    <info> app: cache_too_small: false.
    <info> app: keep_firmware: true.
    <info> app: delete_more: false.
    <info> nrf_dfu_validation: Write address set to 0x00001000
    <info> nrf_dfu_req_handler: Writing valid init command to flash.
    <info> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
    <info> nrf_dfu_validation: Convert to hash to big-endian format for use in nrf_crypto
    <info> nrf_dfu_validation: Hash verification. start address: 0x1000, size: 0xD9324
    --------------------------- Hash verification succeed -----------------------
    <info> nrf_dfu_validation: Invalidating old application in bank 0.
    <info> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
    <info> app: Resetting bootloader.
    <info> app: Inside main
    <info> app: Valid App
    <info> app: Enter nrf_dfu_app_continue
    <info> app: Setting app as valid
    --------- But the Led Blink doesn't working --------------
  • I assume you don't have the softdevice ?
    Where do you put the application to ?
    You can try to do a hex dump (nrfjprog --readcode) to read the flash after you do DFU, and compare it with when you flash only the MBR and the blinky.
  • Hi Hung,
    I assume you don't have the softdevice ?  yes correct
    Where do you put the application to ?  In blinky_pca10056_mbr project i have set the FLASH_START = 0x26000
  • Hi Hung,
    I compared the blinky_pca10056_mbr.hex with the data written into QSPI, couple of data is mismatch with hex.
    In blinky_pca10056_mbr.hex at 4th line before end of hex file as follows
    :0E1698000D0E0F10000000000338FDD8704743
    :0416A8000090D003DB
    Data from end of the QSPI file
    d e f 10 0 0 0 0 3 38 fd d8 70 47 ff ff 0 90 d0 3
    If you compare the above two extra two bytes 0xFF and 0xFF is read from QSPI, but remaining all are same.
    I dont know why 0xFF, 0xFF is there after d e f 10 0 0 0 0 3 38 fd d8 70 47.
    0 0 4 20 75 13 0 0 5d 13 0 0 5f 13 0 0 61 13 0 0 63 13 0 0 65 13 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 67 13 0 0 69 13 0 0 0 0 0 0 6b 13 0 0 6d 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 0 0 0 0 0 0 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 6f 13 0 0 0 0 0 0 0 0 0 0 6f 13 0 0 0 0 0 0 6f 13 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 35 49 36 48 a 1a 2 d0 7 22 91 43 8d 46 34 49 34 48 a 1a 6 d0 7 22 91 43 81 f3 9 88 2 22 82 f3 14 88 30 48 31 49 31 4a 0 f0 44 f8 31 48 31 49 32 4a 0 f0 3f f8 31 48 32 49 32 4a 0 f0 3a f8 32 48 32 49 33 4a 0 f0 35 f8 32 48 33 49 33 4a 0 f0 30 f8 33 48 33 49 34 4a 0 f0 2b f8 33 48 34 49 34 4a 0 f0 26 f8 34 48 34 49 0 22 0 f0 2c f8 33 48 34 49 0 22 0 f0 27 f8 33 48 33 49 9 1a 8 29 2 db 0 22 2 60 41 60 31 4a 90 47 1f 48 1f 49 88 42 5 d0 2 68 4 30 3 b4 90 47 3 bc f7 e7 0 20 86 46 ec 46 0 20 0 21 29 4a 90 47 fe e7 88 42 7 d0 52 1a 5 d0 3 78 1 30 b 70 1 31 1 3a f9 d1 70 47 88 42 2 d0 2 70 1 30 fa e7 70 47 0 0 4 20 0 e0 3 20 0 0 4 20 0 0 4 20 a8 16 0 0 8 0 0 20 c 0 0 20 d4 13 0 0 d4 13 0 0 98 16 0 0 a8 16 0 0 8 0 0 20 8 0 0 20 98 16 0 0 98 16 0 0 98 16 0 0 98 16 0 0 98 16 0 0 98 16 0 0 98 16 0 0 98 16 0 0 a6 16 0 0 ac 16 0 0 c 0 0 20 c 0 0 20 c 0 0 20 c 0 0 20 c 0 0 20 c 0 0 20 c 0 0 20 c 20 0 20 9d 13 0 0 91 14 0 0 fe e7 fe e7 fe e7 fe e7 fe e7 fe e7 fe e7 fe e7 fe e7 fe e7 70 47 0 bf 10 48 80 47 10 48 4f f0 7 1 88 43 85 46 f 48 80 47 f 48 1 68 41 f4 70 1 1 60 bf f3 4f 8f bf f3 6f 8f ff f7 32 bf a 48 b 49 b 4a 88 42 7 d0 52 1a 5 d0 3 78 1 30 b 70 1 31 1 3a f9 d1 70 47 71 13 0 0 0 0 4 20 e1 14 0 0 88 ed 0 e0 98 16 0 0 8 0 0 20 8 0 0 20 7 4b 1b 5c 1f 2b 86 bf 3 f0 1f 3 5 49 4f f0 a0 41 1 22 2 fa 3 f3 c1 f8 8 35 70 47 0 bf 98 16 0 0 0 3 0 50 8 b5 0 20 ff f7 e8 ff 1 20 ff f7 e5 ff 2 20 ff f7 e2 ff 3 20 bd e8 8 40 ff f7 dd bf 0 0 a 4b 18 5c 1f 28 8a bf 9 4b 4f f0 a0 43 0 f0 1f 0 d3 f8 4 25 1 21 81 40 21 ea 2 0 a 40 c3 f8 8 5 c3 f8 c 25 70 47 0 bf 98 16 0 0 0 3 0 50 c2 7 10 b5 4 46 c d5 4f f0 a0 43 3 22 c3 f8 34 27 c3 f8 38 27 c3 f8 3c 27 c3 f8 40 27 ff f7 c5 ff a3 7 a d5 4f f0 a0 43 c 22 c3 f8 2c 27 c3 f8 30 27 c3 f8 60 27 c3 f8 64 27 10 bd 0 0 70 b5 1 20 9 4d ff f7 db ff 45 f0 1 5 0 24 20 46 ff f7 bb ff 4f f4 fa 76 4f f4 7a 40 a8 47 1 3e fa d1 1 34 3 2c f2 d1 f0 e7 a0 16 0 0 5 4b 1b 68 8 2b 1 bf 4 4b 18 68 b0 fa 80 f0 40 9 18 bf 0 20 70 47 30 1 0 10 34 1 0 10 8 b5 4f f0 80 43 0 22 c3 f8 c 21 c3 f8 10 21 c3 f8 38 25 4f f0 80 52 3 f5 40 43 d2 f8 4 14 c3 f8 20 15 d2 f8 8 14 c3 f8 24 15 d2 f8 c 14 c3 f8 28 15 d2 f8 10 14 c3 f8 2c 15 d2 f8 14 14 c3 f8 30 15 d2 f8 18 14 c3 f8 34 15 d2 f8 1c 14 c3 f8 40 15 d2 f8 20 14 c3 f8 44 15 d2 f8 24 14 c3 f8 48 15 d2 f8 28 14 c3 f8 4c 15 d2 f8 2c 14 c3 f8 50 15 d2 f8 30 14 c3 f8 54 15 d2 f8 34 14 c3 f8 60 15 d2 f8 38 14 c3 f8 64 15 d2 f8 3c 14 c3 f8 68 15 d2 f8 40 14 c3 f8 6c 15 d2 f8 44 24 c3 f8 70 25 ff f7 9c ff 10 b1 38 4b 38 4a 1a 60 ff f7 96 ff 18 b1 37 4b fb 22 c3 f8 18 25 ff f7 8f ff 48 b1 34 49 35 4b a 68 1b 68 22 f0 f 2 3 f0 f 3 13 43 b 60 ff f7 82 ff 18 b1 30 4b 4f f4 0 72 1a 60 4f f0 80 43 d3 f8 0 24 d2 7 44 bf 6f f0 1 2 c3 f8 0 24 2a 4a d2 f8 88 30 43 f4 70 3 c2 f8 88 30 bf f3 4f 8f bf f3 6f 8f 4f f0 10 23 d3 f8 0 22 0 2a 3 db d3 f8 4 32 0 2b 2f da 20 4b 1 22 c3 f8 4 25 d3 f8 0 24 0 2a fb d0 4f f0 10 22 12 21 c2 f8 0 12 d3 f8 0 24 0 2a fb d0 4f f0 10 23 12 22 c3 f8 4 22 15 4b 1a 46 d3 f8 0 14 0 29 fb d0 0 21 c3 f8 4 15 d2 f8 0 34 0 2b fb d0 bf f3 4f 8f d 49 e 4b ca 68 2 f4 e0 62 13 43 cb 60 bf f3 4f 8f 0 bf fd e7 a 4b b 4a 1a 60 8 bd 8c 56 0 40 48 81 3 0 0 f0 0 40 e4 e 0 40 58 2 0 10 40 96 2 40 0 ed 0 e0 0 e0 1 40 4 0 fa 5 8 0 0 20 0 90 d0 3 d e f 10 0 0 0 0 3 38 fd d8 70 47 ff ff 0 90 d0 3
    This makes the hash verification fails.blinky_pca10056_mbr.hex
  • Hi Mohammad,
    I'm sorry for late response, I was on vacation last week.
    If you don't have the example, the application is supposed to start at address 0x1000. I'm not sure why you set the Flash Start to 0x26000
    You may want to check how the last packet is written to QSPI.
    But please clarify how you have "  Hash verification succeed " did you remove the hash checking ?
