nrfx_spim example + ble_app_uart example
Previously I  have merged spi with ble_app_uart on NRF52832 based ISP1507 test board . It has performed successfully which was enough to carryout the evaluation phase. Now I am working on my custom board with ISP1507.
I have noticed that the SPI module is deprecated and SPIM which uses DMA is suggested instead. Now I am trying to merge nrfx_spim (board 10056 only) and ble_app_uart using SDK15.3. However I have encountered some errors which I have not been able to overcome.
I  have added the nrfx_spim.c file to the nRF_Drivers folder, enabled NRFX_SPIM_ENABLED and NRFX_SPIM0_ENABLED from the configuration wizard. The error I get is;
 error: #20: identifier "NRFX_SPIM0_INST_IDX" is undefined
static const nrfx_spim_t spi =
RFX_SPIM_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
If I change the spi instance say from 0 to 2, I get the same error for 2. I have gone through the forum and found some related posts. One of them suggests commenting SPI_ENABLED lines which I tried. It did not change anything. The other one was saying the legacy related lines in the sdk_config.h should be commented. I am not sure what I should comment in the file. If this is the solution, can you please tell me what I should comment? If not, please give me some guidance about how I can progress from here.
As a note; the IDE gives an error "fatal error: 'sdk_config.h' file not found" error in the nrfx_config.h file. However compilation does not give me any errors regarding this. I have read that IDE has bug that causes this. So I am ignoring it. Do you agree?
Den
