No measurable range increase using long range bluetooth (LE coded phy)
I wanted to test the range of long range bluetooth using two nRF52840 USB dongles with the blinky example firmware of the nordic SDK 15.3 combined with softdevice version 6.1.1.
All test were made outdoors at the same location with no physical obstructions.
I adapted the central part according this tutorial: https://devzone.nordicsemi.com/nordic/short-range-guides/b/getting-started/posts/nrf52840-dongle-programming-tutorial.
Using the examples with unchanged settings I archived an range of 100 meters which is comparable to my tests with other bluetooth devices (for example a smartphone with bluetooth 4.1) which was to be expected.
Using this range as a baseline I added the option to change the connection type in the peripheral part to coded phy using the sd_ble_gap_phy_update(m_conn_handle, &phys) with
ble_gap_phys_t phys = {
   .tx_phys = BLE_GAP_PHY_CODED,
   .rx_phys = BLE_GAP_PHY_CODED,
which is triggered by the dongle button. I tested both with setting 0 (auto) and 4 (coded phy) for NRF_BLE_SCAN_SCAN_PHY in the sdk_config.h of the central part.
To confirm that the connection type in peripheral is changed successfully I checked the return value for NRF_SUCCESS. When successful the advertising LED is set to on. Additionally I added a function call to the ble_evt_handler() in central changing the RGB LED color when a connection type change request was received and the type was changed successfully.
I tested changing the connection type to coded phy with the dongle button, which was successful according to the changed LED states on both dongles.
However when I tested the range I could not measure any improvements compared to my previous tests without coded phy.
Additionally I set the tx power to 8dbm with sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, 8), again with no improvements.
Do you have any ideas what I am doing wrong here?
Thanks a lot
mort
sdk_config_central.h
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE LED Button Service central and client application main file.
 * This file contains the source code for a sample client application using the LED Button service.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "app_timer.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_lbs_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0                     /**< Scanning LED will be on when the device is scanning. */
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1                     /**< Connected LED will be on when the device is connected. */
#define LEDBUTTON_LED                   BSP_BOARD_LED_2                     /**< LED to indicate a change of state of the the Button characteristic on the peer. */
#define SCAN_INTERVAL                   0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                     0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION                   0x0000                              /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL         MSEC_TO_UNITS(7.5, UNIT_1_25_MS)    /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL         MSEC_TO_UNITS(30, UNIT_1_25_MS)     /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY                   0                                   /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT             MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Determines supervision time-out in units of 10 milliseconds. */
#define LEDBUTTON_BUTTON_PIN            BSP_BUTTON_0                        /**< Button that will write to the LED characteristic of the peer */
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                 /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define APP_BLE_CONN_CFG_TAG            1                                   /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO           3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
NRF_BLE_SCAN_DEF(m_scan);                                       /**< Scanning module instance. */
BLE_LBS_C_DEF(m_ble_lbs_c);                                     /**< Main structure used by the LBS client module. */
NRF_BLE_GATT_DEF(m_gatt);                                       /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                /**< DB discovery module instance. */
static char const m_target_periph_name[] = "Nordic_Blinky";     /**< Name of the device we try to connect to. This name is searched in the scan report data*/
/**@brief Function to handle asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function to start scanning.
static void scan_start(void)
    ret_code_t err_code;
    err_code = nrf_ble_scan_start(&m_scan);
    bsp_board_led_off(CENTRAL_CONNECTED_LED);
    bsp_board_led_on(CENTRAL_SCANNING_LED);
/**@brief Handles events coming from the LED Button central module.
static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
    switch (p_lbs_c_evt->evt_type)
        case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
            err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c,
                                                p_lbs_c_evt->conn_handle,
                                                &p_lbs_c_evt->params.peer_db);
            NRF_LOG_INFO("LED Button service discovered on conn_handle 0x%x.", p_lbs_c_evt->conn_handle);
            err_code = app_button_enable();
            // LED Button service discovered. Enable notification of Button.
            err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
        } break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
        case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
            NRF_LOG_INFO("Button state changed on peer to 0x%x.", p_lbs_c_evt->params.button.button_state);
            if (p_lbs_c_evt->params.button.button_state)
                bsp_board_led_on(LEDBUTTON_LED);
                bsp_board_led_off(LEDBUTTON_LED);
        } break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
            // No implementation needed.
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral has connected (HR or RSC), initiate DB
        // discovery, update LEDs status and resume scanning if necessary. */
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
            err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
            // Update LEDs status, and check if we should be looking for more
            // peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            bsp_board_led_off(CENTRAL_SCANNING_LED);
        } break;
        // Upon disconnection, reset the connection handle of the peer which disconnected, update
        // the LEDs status and start scanning again.
            NRF_LOG_INFO("Disconnected.");
            scan_start();
        } break;
        case BLE_GAP_EVT_TIMEOUT:
            // We have not specified a timeout for scanning, so only connection attemps can timeout.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("Connection request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
            if(err_code == NRF_SUCCESS){
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
        } break;
/**@brief LED Button client initialization.
static void lbs_c_init(void)
    ble_lbs_c_init_t lbs_c_init_obj;
    lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
    err_code = ble_lbs_c_init(&m_ble_lbs_c, &lbs_c_init_obj);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
        case LEDBUTTON_BUTTON_PIN:
            err_code = ble_lbs_led_status_send(&m_ble_lbs_c, button_action);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE)
            if (err_code == NRF_SUCCESS)
                NRF_LOG_INFO("LBS write LED state %d", button_action);
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for handling Scaning events.
 * @param[in]   p_scan_evt   Scanning event.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                               BUTTON_DETECTION_DELAY);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_lbs_on_db_disc_evt(&m_ble_lbs_c, p_evt);
/**@brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
/**@brief Function for initializing the log.
static void log_init(void)
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the Power manager. */
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    // Setting filters for scanning.
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
    NRF_LOG_FLUSH();
    nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timer_init();
    leds_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    gatt_init();
    db_discovery_init();
    lbs_c_init();
    // Start execution.
    NRF_LOG_INFO("Blinky CENTRAL example started.");
    scan_start();
    // Turn on the LED to signal scanning.
    // Enter main loop.
    for (;;)
        idle_state_handle();
 * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
 * @brief Blinky Sample Application main file.
 * This file contains the source code for a sample server application using the LED Button service.
#include <stdint.h>
#include <string.h>
#include "ble_gap.h"
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "boards.h"
#include "app_button.h"
#include "ble_lbs.h"
#include "nrf_ble_qwr.h"
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
#define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
#define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scan_response_data,
/**@brief Function for assert macro callback.
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    // Initialize timer module, making it use the scheduler
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, 8);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    ble_advdata_t advdata;
    ble_advdata_t srdata;
    ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    memset(&srdata, 0, sizeof(srdata));
    srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    srdata.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    ble_gap_adv_params_t adv_params;
    // Set advertising parameters.
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
    adv_params.duration        = APP_ADV_DURATION;
    adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    adv_params.p_peer_addr     = NULL;
    adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    adv_params.interval        = APP_ADV_INTERVAL;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
        NRF_LOG_INFO("Received LED ON!");
        NRF_LOG_INFO("Received LED OFF!");
    ble_lbs_init_t     init     = {0};
    // Initialize LBS.
    init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module that
 *          are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply
 *       setting the disconnect_on_fail config parameter, but instead we use the event
 *       handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    bsp_board_led_on(ADVERTISING_LED);
            NRF_LOG_INFO("Connected");
            bsp_board_led_on(CONNECTED_LED);
            bsp_board_led_off(ADVERTISING_LED);
            NRF_LOG_INFO("Disconnected");
            bsp_board_led_off(CONNECTED_LED);
            err_code = app_button_disable();
            advertising_start();
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
        } break;
    switch (pin_no)
        case LEDBUTTON_BUTTON: ;
            err_code = sd_ble_gap_phy_update(m_conn_handle, &phys);
            NRF_LOG_INFO("Send button state change.");
            err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                err_code != NRF_ERROR_INVALID_STATE &&
                err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    // Initialize.
    log_init();
    leds_init();
    timers_init();
    buttons_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    NRF_LOG_INFO("Blinky example started.");
    // Enter main loop.
    for (;;)
